[rebel-builders] net weight difference with floats
Posted: Sun Feb 19, 2012 8:54 pm
It depends on whether you have the spring gear or the lighter bungee gear,
and of course if you vary from the minimum MAM specified pump, lines, and
struts. I believe it is around 225 pounds extra for the spring gear, and 250
extra for the bungee gear.
I think most if not all Elites use the spring gear, so you could probably
count on at least 225 pounds, 250 if you use heavier lines and other
options.
Palmer
Sent: January 1, 2010 12:13 PM
Subject: [rebel-builders] net weight difference with floats
Does anyone out there have the net weight difference between an Elite on
wheels and on 1800 MAM amphibs?
Bob
773E
options.
Palmer
Bob
773E
