[rebel-builders] Pro Seal removal
Post by Wayne G. O'Shea » Sun Feb 19, 2012 8:54 pm
Do you still have the electric carving knife out from Christmas Hjalmar?
Might be able to carve some off. lol
From: "Hjalmar Bardslokken" <bardslokkenh@videotron.ca>
Sent: Monday, December 28, 2009 10:37 AM
Subject: Re: [rebel-builders] Sore Arm
thanks Nig will try some
Hb Rebel 308
Sent: Monday, December 28, 2009 8:02 AM
Subject: RE: [rebel-builders] Sore Arm
Hi Hjalmar
I used MEK to remove some PRC1422 after having removed as much as
possible
with a sharp modelling knife (without touching the ali skin)
It's hard work and only do it in a well fumigated and ventilated area.
The
fumes smell nice (to me anyway :-) but are potentially lethal !!!!
Nig
745E
Hjalmar Bardslokken
Sent: 28 December 2009 07:31
Have a probleme with PRC
The guys that started to build the floats I bought used Prc in excess. Is
there a solvent I could use (without damaging) to get rid of the extra
PRC..
thanks in advance
HB
Sent: Saturday, December 26, 2009 12:43 AM
Great idea... many a good pre-heat box has been made from a multi fuel
burner.. an ammunition box and some SCAT hose !
Sent: Saturday, December 26, 2009 12:39 AM
Ted Waltman
Post by Ted Waltman » Sun Feb 19, 2012 8:54 pm
Sounds like you've used the Nyroc blades Roger (snap on link:
http://buy1.snapon.com/catalog/item.asp ... =77339&gro
up_ID=20032) They sure seem similar in concept/use to phenolic scrapers
(link: http://www.yardstore.com/search.htm).
I bought a bunch of the roloc bristle pads that Jeff suggested as they were
25% off at MSC Direct last week. I have a pro-seal removal project that I'm
in the midst of (persistent, small though annoying leak in one tank). I'll
post my thoughts on the use of the bristle pads if I get a relatively warm
day to work in the hangar.
I'm still thinking dynamite as one person suggested is the best way <grin>.
rogerk@dcsol.com
Sent: Monday, December 28, 2009 5:50 PM
Subject: Re: [rebel-builders] Pro Seal removal
hi Guys
I found an amazing product from Snap On ... they are called Nyroc blades
for this sort of removal. They work a treat and don't damage the aluminium.
Not to expensive either ...
Hope that helps, it worked for me.
Roger K
210SR
On 12/28/2009 11:53 AM, bardslokkenh@videotron.ca wrote to rebel-builders:
-> Oh yes and plenty of turkey to go
-> Cheers,Merry Christmas and a Happy (New Year) flying
-> Hjalmar
-> From: "Wayne G. O'Shea" <oifa@irishfield.on.ca>
-> Sent: Monday, December 28, 2009 11:55 AM
-> Subject: Re: [rebel-builders] Pro Seal removal
-> > Do you still have the electric carving knife out from Christmas
Hjalmar?
-> > Might be able to carve some off. lol
-> > ----- Original Message -----
-> > From: "Hjalmar Bardslokken" <bardslokkenh@videotron.ca>
-> > To: <rebel-builders@dcsol.com>
-> > Sent: Monday, December 28, 2009 10:37 AM
-> > Subject: Re: [rebel-builders] Sore Arm
-> >> thanks Nig will try some
-> >> Hb Rebel 308
-> >> ----- Original Message -----
-> >> From: "N.Smith" <admin@airnig.co.uk>
-> >> To: <rebel-builders@dcsol.com>
-> >> Sent: Monday, December 28, 2009 8:02 AM
-> >> Subject: RE: [rebel-builders] Sore Arm
-> >>> Hi Hjalmar
-> >>> I used MEK to remove some PRC1422 after having removed as much as
-> >>> possible
-> >>> with a sharp modelling knife (without touching the ali skin)
-> >>> It's hard work and only do it in a well fumigated and ventilated
area.
-> >>> The
-> >>> fumes smell nice (to me anyway :-) but are potentially lethal !!!!
-> >>> Nig
-> >>> 745E
-> >>> -----Original Message-----
-> >>> From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of
-> >>> Hjalmar Bardslokken
-> >>> Sent: 28 December 2009 07:31
-> >>> To: rebel-builders@dcsol.com
-> >>> Subject: Re: [rebel-builders] Sore Arm
-> >>> Have a probleme with PRC
-> >>> The guys that started to build the floats I bought used Prc in
excess.
-> >>> Is
-> >>> there a solvent I could use (without damaging) to get rid of the
extra
-> >>> PRC..
-> >>> thanks in advance
-> >>> HB
-> >>> ----- Original Message -----
-> >>> From: "Wayne G. O'Shea" <oifa@irishfield.on.ca>
-> >>> To: <rebel-builders@dcsol.com>
-> >>> Sent: Saturday, December 26, 2009 12:43 AM
-> >>>> Great idea... many a good pre-heat box has been made from a multi
fuel
-> >>>> burner.. an ammunition box and some SCAT hose !
-> >>>> ----- Original Message -----
-> >>>> From: <kpierson@dcsol.com>
-> >>>> To: <rebel-builders@dcsol.com>
-> >>>> Sent: Saturday, December 26, 2009 12:39 AM
-> >>>> Subject: Re: [rebel-builders] Sore Arm
-> >>>>> Thanks Jeff, I needed that
-> >>>>> Keith P.
-> >>>>> On 12/25/2009 2:10 AM, westcoastkitplanes@gmail.com wrote to rebel-
-> >>>>> builders:
-> >>>>> -> Well Keith, take a break........ here's a couple of pats on the
-> >>>>> back
-> >>>>> for
-> >>>>> -> ya.... PAT PAT Well Done (lol).
-> >>>>> -> Have a Safe & Happy Holiday Season.
-> >>>>> -> Cheers,
-> >>>>> -> Jeff
-> >>>>> -> On Thu, Dec 24, 2009 at 9:20 PM, <kpierson@dcsol.com> wrote:
-> >>>>> -> > I purchased an old (well not that old) gas clothes dryer, tore
-> >>>>> the
-> >>>>> burner
-> >>>>> -> > out, bought a squirrel cage fan, and built a metal box to
mount
-> >>>>> it
-> >>>>> in
-> >>>>> and
-> >>>>> -> > turned it into an engine preheater.
-> >>>>> -> > I am amazed at how well it works, actually I am amazed that it
-> >>>>> works
-> >>>>> at
-> >>>>> -> > all.
-> >>>>> -> > The problem is the older I get the harder it is to pat my self
on
-> >>>>> the
-> >>>>> back!
-> >>>>> -> > Keith P. 318R
-> >>>>> -> > List archives located at: https://mail.dcsol.com/login
-> >>>>> -> > username "rebel" password "builder"
-> >>>>> -> > Unsubscribe: rebel-builders-unsubscribe@dcsol.com
-> >>>>> -> > List administrator: mike.davis@dcsol.com
-> >>>>> List archives located at: https://mail.dcsol.com/login
-> >>>>> username "rebel" password "builder"
-> >>>>> Unsubscribe: rebel-builders-unsubscribe@dcsol.com
-> >>>>> List administrator: mike.davis@dcsol.com
-> >>>> List archives located at: https://mail.dcsol.com/login
-> >>>> username "rebel" password "builder"
-> >>>> Unsubscribe: rebel-builders-unsubscribe@dcsol.com
-> >>>> List administrator: mike.davis@dcsol.com
-> >>> List archives located at: https://mail.dcsol.com/login
-> >>> username "rebel" password "builder"
-> >>> Unsubscribe: rebel-builders-unsubscribe@dcsol.com
-> >>> List administrator: mike.davis@dcsol.com
-> >> List archives located at: https://mail.dcsol.com/login
-> >> username "rebel" password "builder"
-> >> Unsubscribe: rebel-builders-unsubscribe@dcsol.com
-> >> List administrator: mike.davis@dcsol.com
Hjalmar Bardslokken
Post by Hjalmar Bardslokken » Sun Feb 19, 2012 8:54 pm
Hjalmar
Hb Rebel 308
Hi Hjalmar
possible
The
Nig
745E
Hjalmar Bardslokken
Is
PRC..
thanks in advance
HB
rogerk
Post by rogerk » Sun Feb 19, 2012 8:54 pm
hi Guys
Roger K
210SR
-> Hjalmar
-> > Do you still have the electric carving knife out from Christmas Hjalmar?
-> >> Hb Rebel 308
-> >>> Hi Hjalmar
-> >>> possible
-> >>> It's hard work and only do it in a well fumigated and ventilated area.
-> >>> The
-> >>> Nig
-> >>> 745E
-> >>> The guys that started to build the floats I bought used Prc in excess.
-> >>> Is
-> >>> there a solvent I could use (without damaging) to get rid of the extra
-> >>> PRC..
-> >>> HB
-> >>>> Great idea... many a good pre-heat box has been made from a multi fuel
-> >>>>> Keith P.
-> >>>>> builders:
-> >>>>> back
-> >>>>> for
-> >>>>> -> Cheers,
-> >>>>> -> Jeff
-> >>>>> the
-> >>>>> burner
-> >>>>> -> > out, bought a squirrel cage fan, and built a metal box to mount
-> >>>>> it
-> >>>>> in
-> >>>>> and
-> >>>>> works
-> >>>>> at
-> >>>>> -> > all.
-> >>>>> -> > The problem is the older I get the harder it is to pat my self on
-> >>>>> the
-> >>>>> back!
rogerk
Yes Ted, these blades are one of those tools that I wish I had discovered
earlier as they work so well.
The kit I bought was :
http://buy1.snapon.com/catalog/item.asp ... ir=catalog
Which was the best value with a good combination of widths.
You can go crazy and buy the vibrator for them and the sharpener but
you would need to be using them a lot to justify it.
Good luck with it, I know it's an awful job.
Roger K
On 12/29/2009 4:56 AM, ted@vafm.org wrote to rebel-builders:
-> Sounds like you've used the Nyroc blades Roger (snap on link:
-> http://buy1.snapon.com/catalog/item.asp ... =77339&gro
-> up_ID=20032) They sure seem similar in concept/use to phenolic scrapers
-> (link: http://www.yardstore.com/search.htm).
-> I bought a bunch of the roloc bristle pads that Jeff suggested as they were
-> 25% off at MSC Direct last week. I have a pro-seal removal project that I'm
-> in the midst of (persistent, small though annoying leak in one tank). I'll
-> post my thoughts on the use of the bristle pads if I get a relatively warm
-> day to work in the hangar.
-> I'm still thinking dynamite as one person suggested is the best way <grin>.
-> Ted
-> -----Original Message-----
-> rogerk@dcsol.com
-> Sent: Monday, December 28, 2009 5:50 PM
-> hi Guys
-> I found an amazing product from Snap On ... they are called Nyroc blades
-> for this sort of removal. They work a treat and don't damage the aluminium.
-> Not to expensive either ...
-> Hope that helps, it worked for me.
-> Roger K
-> 210SR
-> On 12/28/2009 11:53 AM, bardslokkenh@videotron.ca wrote to rebel-builders:
-> -> Oh yes and plenty of turkey to go
-> -> Cheers,Merry Christmas and a Happy (New Year) flying
-> -> Hjalmar
-> -> ----- Original Message -----
-> -> From: "Wayne G. O'Shea" <oifa@irishfield.on.ca>
-> -> To: <rebel-builders@dcsol.com>
-> -> Sent: Monday, December 28, 2009 11:55 AM
-> -> Subject: Re: [rebel-builders] Pro Seal removal
-> -> > Do you still have the electric carving knife out from Christmas
-> Hjalmar?
-> -> > Might be able to carve some off. lol
-> -> > ----- Original Message -----
-> -> > From: "Hjalmar Bardslokken" <bardslokkenh@videotron.ca>
-> -> > To: <rebel-builders@dcsol.com>
-> -> > Sent: Monday, December 28, 2009 10:37 AM
-> -> > Subject: Re: [rebel-builders] Sore Arm
-> -> >> thanks Nig will try some
-> -> >> Hb Rebel 308
-> -> >> ----- Original Message -----
-> -> >> From: "N.Smith" <admin@airnig.co.uk>
-> -> >> To: <rebel-builders@dcsol.com>
-> -> >> Sent: Monday, December 28, 2009 8:02 AM
-> -> >> Subject: RE: [rebel-builders] Sore Arm
-> -> >>> Hi Hjalmar
-> -> >>> I used MEK to remove some PRC1422 after having removed as much as
-> -> >>> possible
-> -> >>> with a sharp modelling knife (without touching the ali skin)
-> -> >>> It's hard work and only do it in a well fumigated and ventilated
-> area.
-> -> >>> The
-> -> >>> fumes smell nice (to me anyway :-) but are potentially lethal !!!!
-> -> >>> Nig
-> -> >>> 745E
-> -> >>> -----Original Message-----
-> -> >>> From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of
-> -> >>> Hjalmar Bardslokken
-> -> >>> Sent: 28 December 2009 07:31
-> -> >>> To: rebel-builders@dcsol.com
-> -> >>> Subject: Re: [rebel-builders] Sore Arm
-> -> >>> Have a probleme with PRC
-> -> >>> The guys that started to build the floats I bought used Prc in
-> excess.
-> -> >>> Is
-> -> >>> there a solvent I could use (without damaging) to get rid of the
-> extra
-> -> >>> PRC..
-> -> >>> thanks in advance
-> -> >>> HB
-> -> >>> ----- Original Message -----
-> -> >>> From: "Wayne G. O'Shea" <oifa@irishfield.on.ca>
-> -> >>> To: <rebel-builders@dcsol.com>
-> -> >>> Sent: Saturday, December 26, 2009 12:43 AM
-> -> >>>> Great idea... many a good pre-heat box has been made from a multi
-> fuel
-> -> >>>> burner.. an ammunition box and some SCAT hose !
-> -> >>>> ----- Original Message -----
-> -> >>>> From: <kpierson@dcsol.com>
-> -> >>>> To: <rebel-builders@dcsol.com>
-> -> >>>> Sent: Saturday, December 26, 2009 12:39 AM
-> -> >>>> Subject: Re: [rebel-builders] Sore Arm
-> -> >>>>> Thanks Jeff, I needed that
-> -> >>>>> Keith P.
-> -> >>>>> On 12/25/2009 2:10 AM, westcoastkitplanes@gmail.com wrote to rebel-
-> -> >>>>> builders:
-> -> >>>>> -> Well Keith, take a break........ here's a couple of pats on the
-> -> >>>>> back
-> -> >>>>> for
-> -> >>>>> -> ya.... PAT PAT Well Done (lol).
-> -> >>>>> -> Have a Safe & Happy Holiday Season.
-> -> >>>>> -> Cheers,
-> -> >>>>> -> Jeff
-> -> >>>>> -> On Thu, Dec 24, 2009 at 9:20 PM, <kpierson@dcsol.com> wrote:
-> -> >>>>> -> > I purchased an old (well not that old) gas clothes dryer, tore
-> -> >>>>> the
-> -> >>>>> burner
-> -> >>>>> -> > out, bought a squirrel cage fan, and built a metal box to
-> mount
-> -> >>>>> it
-> -> >>>>> in
-> -> >>>>> and
-> -> >>>>> -> > turned it into an engine preheater.
-> -> >>>>> -> > I am amazed at how well it works, actually I am amazed that it
-> -> >>>>> works
-> -> >>>>> at
-> -> >>>>> -> > all.
-> -> >>>>> -> > The problem is the older I get the harder it is to pat my self
-> on
-> -> >>>>> the
-> -> >>>>> back!
-> -> >>>>> -> > Keith P. 318R
-> -> >>>>> -> > List archives located at: https://mail.dcsol.com/login
-> -> >>>>> -> > username "rebel" password "builder"
-> -> >>>>> -> > Unsubscribe: rebel-builders-unsubscribe@dcsol.com
-> -> >>>>> -> > List administrator: mike.davis@dcsol.com
-> -> >>>>> List archives located at: https://mail.dcsol.com/login
-> -> >>>>> username "rebel" password "builder"
-> -> >>>>> Unsubscribe: rebel-builders-unsubscribe@dcsol.com
-> -> >>>>> List administrator: mike.davis@dcsol.com
-> -> >>>> List archives located at: https://mail.dcsol.com/login
-> -> >>>> username "rebel" password "builder"
-> -> >>>> Unsubscribe: rebel-builders-unsubscribe@dcsol.com
-> -> >>>> List administrator: mike.davis@dcsol.com
-> -> >>> List archives located at: https://mail.dcsol.com/login
-> -> >>> username "rebel" password "builder"
-> -> >>> Unsubscribe: rebel-builders-unsubscribe@dcsol.com
-> -> >>> List administrator: mike.davis@dcsol.com
-> -> >> List archives located at: https://mail.dcsol.com/login
-> -> >> username "rebel" password "builder"
-> -> >> Unsubscribe: rebel-builders-unsubscribe@dcsol.com
-> -> >> List administrator: mike.davis@dcsol.com
-> -> > List archives located at: https://mail.dcsol.com/login
-> -> > username "rebel" password "builder"
-> -> > Unsubscribe: rebel-builders-unsubscribe@dcsol.com
-> -> > List administrator: mike.davis@dcsol.com
-> List archives located at: https://mail.dcsol.com/login
