routing is as-per MAM circa early 1990's.
On trips--- I always take-off on both tanks then in level flight turn off
the passenger side and run on the left side till the engine sputters then
turn the left side off before turning the right side on so I don't have fuel
pushed back in to the left tank. With judicious leaning I can run 2.5 on ea.
side and have never run longer than 4.2 airtime (Wilkesboro NC to Lakeland
FL) . My thought is, beyond the monitored use of a functioning time-piece I
know closely how much air time/fuel is in the tanks.
I've never had a no-restart condition from this method in a Rebel.
Local flying both tanks stay on and I'm at the pumps by the time indicators
are between half and quarter.
Not recommending anything here just giving my experience and would like to
hear pro's and con's I may not have considered. .........Angus
Sent: Tuesday, December 22, 2009 6:04 PM
Subject: Re: [rebel-builders] Fuel slector valves
I believe the tank venting design will have an influence on this switching
procedure. Not to reopen a subject that's been covered quite a bit (see
archives) I think with dual vents and full cross vent (and perhaps other
configurations) it may be possible to run one tank dry before switching as
Drew suggests -- if you're so inclined. Personally, I wouldn't
intentionally
cause an in flight shutdown except in an emergency scenario where fuel
reserves absolutely had to be managed that tightly. Your mileage may
vary --
literally. :-)
Ron
254R
On Tue, Dec 22, 2009 at 2:41 PM, Drew Dalgleish
<drewjan@cabletv.on.ca>wrote:
Hi Walter I wonder if that problem could be unique to your plane cuz I
often run the pilots side tank empty to help balance my plane and get
maximum range. I think I usually turn off the empty tank before turning
on
the one with fuel in it and I've never expreienced any delay in the
engine
restarting.
As for floor mounted valves consider where you place it so that if you
ever
install floats you will be able to easily crawl through to the other side
for docking, pumping out, refueling etc.
At 11:27 AM 22/12/2009 -0800, you wrote:running one tank dry while flying. The sequence for closing and openingAnd with only the top mounted independent valves, be very careful when
valves is very critical to avoid an air lock. I know this from first hand
experience and am able to replicate the issue on the ground.run one tank dry, with the other full tank closed, you must first openWe've discussed it before on the list, but here is the sequence. When
you
full tank before you close the dry one. Otherwise, your engine will quit,
and you will not be able to keep it running. It will restart, but then
keep
quitting on you.full one can't flow fast enough. It flows just enough to start yourThe problem is that air gets trapped when you close the empty one, and
engine,
but it will keep quitting on you. If you keep the empty one open, the
locked air will vent up through it, and allow the good tank to feed down
the carb. Once it is feeding OK, and the air is out, then you can close
empty one.the ground when I first did it.It took me a while to figure this out when it happened. Luckily, I was
onlocked in the lines above to the tanks.With floor mounted valves you avoid this problem, as the air can't getDrewWalter
