[rebel-builders] Fibre glass rudder tip 818R
Posted: Sun Feb 19, 2012 5:50 pm
I found that the two halves took a lot of cutting and fitting to make them fit both the elevator and rudder tips.
Grit your teeth and go at it.
Ron Stahla
Hotmail: Powerful Free email with security by Microsoft.
http://clk.atdmt.com/GBL/go/171222986/direct/01/
Ron Stahla
Date: Sat, 12 Dec 2009 22:59:16 -0900
Subject: [rebel-builders] Fibre glass rudder tip 818R
Hi all,
I'm just starting to get my first tip under way and find I can't make
it fit. In order to fit the leading edge rib at the front, and to
accommodate the taper of the rudder at the rear I need to trim off the
joining flange/s and would then have a butt joint between the two halves,
which I would reinforce with fibreglass tape.
Have I missed something? or would anyone care to comment? I've done
some searches and have found some negative remarks but not much detail.
Any input would be appreciated. Cheers Mike
