ones are the same material as the main ones on the side.
However, don't install the top one in the centre of the window like I did,
because the fronts like to lift away at higher speeds. I had to install
velcros on the front to fix that. Best to install it closer to the front.
Shannon
Sent: December 10, 2009 6:44 PM
Subject: [rebel-builders] doubler
Hi Brian,
I'm not sure I understand what you're referring to. Or rather, I'm sure I
don't. :-) Perhaps it would help if you gave me the (URL) link to the
photo on my site that you noticed...? Happy to answer if I can, once we get
on the same page, er, photo. :-)
Ron
On Thu, Dec 10, 2009 at 6:10 PM, Brian Bridgewater <ecomind@ymail.com>wrote:
inTo Ron Shannon Hello Ron I have Rebel 274R I was just browsing
your foto's and noticed a doubler installed to the rear of the door frame
veryfront of the ailron box as im just repairing my wing root attachment point
just above I wandered if this is a known mod as I found this area to be
weak when deriveting, hope you don't mind me asking regards Brian.
