[rebel-builders] Aileron Movement in Elite and the FAR's
Posted: Sun Feb 19, 2012 8:50 pm
by tlmcclary@juno.com
Nig,
The sections are too long to type here. Go to www.faa.gov and there is a tab to take you to the regs. 23.157 Rate of Roll says "using a favorable combination of controls" and not ailerons specifically. 23.455 Ailerons but the requirements lead you a circle so you need to be a lawyer to understand.
Terry
R666
---------- Original Message ----------
Subject: [rebel-builders] Aileron Movement in Elite and the FAR's
Date: Thu, 10 Dec 2009 16:05:20 -0000
Hi All
Anyone know the FAR or Canadian requirements on aileron movement or effect ?
The UK rules say 30 degrees bank to 30 degrees bank in less than 5 seconds
in both directions at an airspeed equivalent to 1.3 Vs. If this can not be
achieved a higher approach speed will be mandated.
Nig
745E
____________________________________________________________
Home Mortgage
Don't pay a high mortgage rate. Click to find an affordable mortgage.
http://thirdpartyoffers.juno.com/TGL214 ... AQcwAAAAA=
