Page 1 of 3
[rebel-builders] control cable thimble
Posted: Sun Feb 19, 2012 8:49 pm
I'm at a lose as to why this was directed to me??.. and not the Moose
builders/fliers in general.
Sent: Wednesday, December 09, 2009 4:07 PM
Subject: [rebel-builders] control cable thimble
Wayne G O'shea
Wayne, on the elevator control cables (moose) murphy used a machined
grooved steel insert inside the thimble for the elevator. Insert rotates
in the thimble .I would use this if it wasn't hid. this is a perfect
setup for rust corrosion and seizure and rotation on the bolt .I know its
there but if someone acquires the aircraft they don't. What did you change
this to .
thanks
Doug Wilson
by doug wilson
I guess You can't answer or don't know .I figured you had seen enough dum shit you might know and have changed it.ANYBODY ELSE CARE TO TAKE A STAB AT IT.
thanks Doug
Subject: Re: [rebel-builders] control cable thimble
Date: Wed, 9 Dec 2009 16:14:51 -0500
Wayne G O'shea
this to .
thanks
Doug Wilson
Windows Live: Friends get your Flickr, Yelp, and Digg updates when they e-mail you.
http://go.microsoft.com/?linkid=9691817
by Jeff Micheal
Doug,
Is your concern that the insert rotates or that the thimble and insert are
dissimilar metals ?
Jeff
IT.
thanks Doug
Wayne G O'shea
rotates
its
change
this to .
thanks
Doug Wilson
e-mail you.
by Ted Waltman
Doug,
I'm thankful Wayne is both willing and able to any many questions on the
list. I believe many folks chip in with answers when they have some
insight--and I certainly appreciate each and everyone's contribution.
I believe the part you are referring to is an AN111-4 (in the case of the
Moose) cable bushing as called for on page 35 of Chapter 12, section 95. If
this is indeed the part you are referring to cable bushings, to my knowledge
at least, are intended to rotate on the bolt. The thimble should be
squeezed tightly enough by the cable/nicopress assembly such that the cable
bushing does not rotate. If the cable bushing is rotating, one likely does
not have a tight enough/proper nicopress assembly.
AC 43.13, figure 7-14 shows a proper thimble/nicopress configuration.
Aircraft Spruce, if you search on AN111, says "Used in the same manner as
AN100 cable thimble." I've seen references (e.g. Wicks Aircraft Catalog,
page 49) where one uses a cable bushing to "...help eliminate thimble
elongation under load, thus maintaining correct cable length and tension."
Hope the above information is what you're looking for. I'd be happy to look
up further references pointing to the appropriate use of cable bushings in
this type installation.
Ted Waltman
Moose N384JP
Denver, CO
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of doug
wilson
Sent: Wednesday, December 09, 2009 2:32 PM
To: rebel
Subject: RE: [rebel-builders] control cable thimble
IT.
thanks Doug
Wayne G O'shea
its
change
this to .
thanks
Doug Wilson
e-mail you.
I think I'll just carry on with life around here and do what all the other
"pro" builders that follow the list seem to be doing. Keeping their
knowledge to themselves or charging you for it.
I don't need this kinda shit. Enjoy your builds guys.
To: "rebel" <rebel-builders@dcsol.com>
Sent: Wednesday, December 09, 2009 4:31 PM
AT IT.
thanks Doug
Wayne G O'shea
rotates
its
change
this to .
thanks
Doug Wilson
e-mail you.
by Jeff Micheal
It's OK Wayne........ Just ask me anything, I won't charge you.... LOL. Life
to short to let it bother you Bud.
Jeff
On Wed, Dec 9, 2009 at 5:00 PM, Wayne G. O'Shea <oifa@irishfield.on.ca>wrote:
AT IT.
thanks Doug
e-mail you.
by doug wilson
My concern is about the whole planes surface controls.No bearing or proper bushing.Bolts through aluminum,steel bushing in brass.Planes in 1946 had better technology.When you look at every link and joint for the controls this thing is dangerous.And where I am concerned on this thimble,it is hidden, if there is no lube between the insert and bolt.The insert will eventually cut the bolt .There is constant pressure on the cable 30lbs. so wear on the bolt is hard to define .If it was anything but steel to steel I would not be overly concerned but to the unwary and left out in the elements and no lube I repeat dangerous I lost rudder one time on a real plane(180) ,it wasn't fun flying it with the doors .I never lost a elevator I guess that is why I am still here.Another concern Chapter 12 pge. 3 tangs attached to torque tube I used a offset No. 80 real chain link not something you can bend by hand.All bushing running in brass were made out of stainless.For insert i wish to replace it wit
h a sealed ball bearing
1/4 inch bore if anyone has done it I would appreciate where you got it.I will Sleeve the outer race and machine a cable groove around it
And by the way no offence wayne i give my information for free so nobody dies .What do you charge for your professionalism if you don't know say so .
Date: Wed, 9 Dec 2009 15:48:46 -0800
Doug,
dissimilar metals ?
Jeff
IT.
thanks Doug
rotates
its
change
e-mail you.
Ready. Set. Get a great deal on Windows 7. See fantastic deals on Windows 7 now
http://go.microsoft.com/?linkid=9691818
Posted: Sun Feb 19, 2012 8:50 pm
Nope life's too short to put up with it... I know that all too well right
now.
There's a handfull of guys on the list with a combined 200+ years of
building experience that try to help other builders along with their
quest.... and we get flip off remarks from those that have never built
before. Anyone notice that there are less and less responses from this
"handfull". I'm gonna go join them and use the extra time to spend on the
couch with the wife.. or building project X in the shop.
From: "Jeff Micheal" <westcoastkitplanes@gmail.com>
Sent: Wednesday, December 09, 2009 8:36 PM
Life
Jeff
other
dum
STAB
AT IT.
thanks Doug
e-mail you.
by Keith Leitch
Hmmmm, also....if I would have upset someone on here be it intentional or unintentional....I would have at least offered an apology. Life is way too damned short to cause a rift over such stupid shit!!!
by NormIsler
There is one in every crowd.
(Unfortunately)
All the help and advice from all sources IS appreciated by those on the
list, even the infrequent participants.
(Just because we don't post often doesn't mean we don't read and learn
every day.)
Don't let one ungracious comment spoil all the good this list does!
Thanks.
Norm
Elite 702E
by Nancy Puff
ooooooooo what is project X Wayne?
Sent: Wednesday, December 09, 2009 5:45 PM
now.
Life
Jeff
other
by gleeso1
(Unfortunately)
every day.)
Thanks.
Norm
Elite 702E
Well said Norm,
John Gleeson
Rebel 804 downunder.
Posted: Sun Feb 19, 2012 8:54 pm
by art_spangler
As I was browsing through the forum, this particular blog caught my attention. What was
said that was so offensive? I too would like to know Wayne's opinion on the mickey
mouse control system, seeing as how Wayne is a premium builder, it looks like thats why
this builder clearly asked him the question. That poor guy, we will probably never hear
from him again! He sounds like he has a good grasp on catching very poor engineering,
because I too am running into the same problem with the pivot points.
Sincerely,
Art Spangler
Texas
On 12/11/2009 2:03 PM, im_planecrazy@yahoo.com wrote to rebel-builders:
-> Hmmmm, also....if I would have upset someone on here be it intentional or
by Ron Shannon
Art,
After things like this have subsided, It is best to let them go by, rather
than resurrect something that was interpreted as offensive by some, and in
this case, perhaps many. Where offense has been taken, if the issue is
resurrected and dissected over and over -- offense will be taken again,
sooner or later, by someone. If you really must have an answer on the
offensiveness, feel free to write me direct - OFF LIST - and I'll not be shy
about sharing my take on the matter, in private. Similarly, if the original
writer really didn't understand what was offensive, there's no reason he
can't write directly to Wayne -- OFF LIST - offering an apology, whether the
offense was understood or not.
As to the substantive question, regarding thimbles, if you read the thread
further, as I recall you'll find at least one good answer. If not, I'm sure
someone will answer that question, if possible, but IMHO, it will not serve
the group to dredge up and/or debate personal reactions on the list. Let's
not.
254R
attention. What was
mickey
like thats why
probably never hear
engineering,
Sincerely,
Art Spangler
Texas
by Walter Klatt
Hey, guys, this is Xmas. Let's just be thankful we have this list and guys
like Wayne who is super knowledgeable about the Rebel and the Murphy
products. It is also very unfair to Wayne, just because of his knowledge and
his business to ask or expect him to provide all the answers.
Most of us who have been around for a while owe a lot to Wayne for all his
help, plus he is a really great guy too, if you ever get to meet him in
person. The newbies should read the archives a bit so they get a better
appreciation of this, and hopefully give a little more respect where it is
due.
So hope you don't take offense to this post, but I couldn't sit back when I
saw this. This has been a great list for helping us better enjoy flying and
building our airplanes. Let's keep it this way.
Sent: December 24, 2009 11:47 AM
attention. What was
mickey
like thats why
never hear
engineering,
Sincerely,
Art Spangler
Texas
damned short to
