[rebel-builders] Moose: Rudder attach idea: rod-end bearings
Posted: Sun Feb 19, 2012 8:49 pm
Good eye on the bolts in the picture Drew. I didn't notice it myself until
yesterday when I was sharpening up the pictures in Photoshop. I'll have to
ask the A&P that did the plane for this guy why he didn't use drilled
bolts/castle nuts.
Ted
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Drew
Dalgleish
Sent: Sunday, November 29, 2009 9:23 AM
Subject: Re: [rebel-builders] Moose: Rudder attach idea: rod-end bearings
Hi Ted Just checked the pictures and I thought I'd add most Canadian
inspectors will insist on drilled bolts and castle nuts anywhere that
there's a posibility of the bolt turning.
At 05:29 PM 28/11/2009 -0700, you wrote:
bolts/castle nuts.
Ted
Dalgleish
(Heim/Aurora)Posted two pictures to area "103 - S/M-Rudder" showing rod end
accomplishbearings used by a friend on his Harmon Rocket. Might be able to
Drewa similar installation on the Moose/Super Rebel/Rebel rudder.
Parts can be had from Aircraft Spruce (search on "bearing" and you'll get a
whole page of options).
Also RBC Aerospace Bearings (phone: 866-722-2376) out of Washington has the
same parts, albeit less expensive, than Aircraft Spruce. Website:
http://rbcbearings.com/bbre-aerospace/index.htm
Part # is MS21151 for external thread version & part # MS21153 for internal
thread version.
Ted
