inspectors will insist on drilled bolts and castle nuts anywhere that
there's a posibility of the bolt turning.
At 05:29 PM 28/11/2009 -0700, you wrote:
DrewPosted two pictures to area "103 - S/M-Rudder" showing rod end (Heim/Aurora)
bearings used by a friend on his Harmon Rocket. Might be able to accomplish
a similar installation on the Moose/Super Rebel/Rebel rudder.
Parts can be had from Aircraft Spruce (search on "bearing" and you'll get a
whole page of options).
Also RBC Aerospace Bearings (phone: 866-722-2376) out of Washington has the
same parts, albeit less expensive, than Aircraft Spruce. Website:
http://rbcbearings.com/bbre-aerospace/index.htm
Part # is MS21151 for external thread version & part # MS21153 for internal
thread version.
