[rebel-builders] RE: =?ISO-8859-1?Q?Re=3A_=5Brebel=2Dbuilder
bernard.liagre
[rebel-builders] RE: =?ISO-8859-1?Q?Re=3A_=5Brebel=2Dbuilders=5D_He
Post by bernard.liagre » Sun Feb 19, 2012 8:46 pm
I took good notes Walter , and I control this
thank you
Bernard
On 11/13/2009 6:53 PM, walter.klatt@shaw.ca wrote to rebel-builders:
-> Bernard, another point about the cowl, if you go with the Murphy fiberglass
-> one. Get a 2.5 inch (instead of the standard 2.0 inch one) spacer on your
-> Sensenich prop. This will give more clearance on your inlets and help with
-> your cooling. And as has been said here many times before, be sure to
make
-> the exit area much larger, to avoid serious cooling problems on amphibs
with
-> this cowl. And if you can, make the inlets a little larger, too, top to
-> bottom of the two halves. Even 1 inch will make a big difference.
-> Walter
-> -----Original Message-----
-> bernard.liagre@dcsol.com
-> Sent: November 13, 2009 4:04 PM
-> Subject: Re: [rebel-builders] RE:
-> =?ISO-8859-1?Q?Re=3A_=5Brebel=2Dbuilders=5D_He
-> thank you Walter
-> I'll listen to your experience, I confess that I do not know much and I want
-> to
-> do well.
-> I am very happy to be back with you on this site
-> Now it is 01 hours in France, I must sleep a little, but unfortunately for
-> you
-> tomorrow I'll have other issues
