[rebel-builders] Sicka Flex
Posted: Sun Feb 19, 2012 5:41 pm
Jason
I did everything in gray/aluminum color sikkaflex 1A from Patene
masonry/building supply in Guelph. I used standard 300ml caulking
cartridges at around cdn$7.00 ea. I think they actually sell more of it
in the larger "sausages". I used 15 or 18 tubes of the stuff but there
is a fair bit of waste. It has a use before date of up to a year or so.
Other options are the marine polyurethanes but they are 3 times the cost
and harder to find around here.
There are several other polyurethanes from other manufacturers that I'm
pretty sure are equivalent but I stuck with the sikkaflex 1A since it is
the only one mentioned by name on this list.
Rebecca Brownell wrote:
This message is more directed at Ken but any input is welcome.Ken,did
you do all sealant of your floats with the sika flex?Is there only one
product by that name and where did you get it?I'm assuming it only
comes in the standard caulking tube size?I'm about ready for some
soon,thought I'd double check.
Jason
817R
