Derlin bearing block fit
Posted: Sun Feb 19, 2012 8:41 pm
Hi,
I've been working on the elevator controls where I'm mounting the
CC-68 in the RP-13 bearing blocks on the aft horizontal bulkhead. The
bearing blocks are a really tight fit. So, do I just enlarge the
holes in the bearings or should I start by removing the paint on the
CC-68 where it goes into the bearing. Does the paint wear off anyway?
I guess what I want to avoid is enlarging the bearing for a good fit
and then having the paint wear off and making the fit to loose. I'll
be having the same issue with the rudder pedals.
Thanks much,
Joel
Thanks much,
Joel
