haven't found with tank rivets. I don't recall ever having a standard
Avdel/Avex rivet stem breaking prematurely. I sure seem to be at maybe 5%
or 10% rate of having tank rivet mandrels break on me though.
Sent: Friday, October 09, 2009 1:23 PM
Subject: Re: [rebel-builders] tank rivets
Might or might not mean anything but I use a regulator to drop air
pressure to minimum and have never had a 6402 or 6403 mandrel break off.
0 out of 22,000 is good odds. I have had a couple of the longer 6406
ones break off.
Garry Wright wrote:
months.Thanks Ray. I've never had a problem with mandrels breaking off ---
yet.... The broken off ones were done by others and I suspect,
because of the awkwardness of the typical location that it might be side
loading on the puller. A straight pull doesn't seem to generate that
problem.
Garry
ray.mason@dcsol.com wrote:Mattic is very good to deal with. I have used them the last couple of
The tank rivets are not AVEX as AVEX doesn't make a closed rivet and I am
tonot sure who makes them for Mattic. I also have had problems with the
mandrels breaking. I think the main problem for this is that the hole is
thetight. I found if you pull them manually they don't break as much, but
best way would probably re drill the hole if the rivit is hard to get in.
