bolted a beam to the top of the spring and extended the beam back to the
rear bungee gear fuselage hard points. That eliminates all that rocking
torque on the carry throughs and also looks rather macho. I'd guess that
his spring gear is the strongest and most forgiving arrangement of all
Rebel landing gears!
Jeff Micheal wrote:
Steve,
At minimum I would recommend the installation of the Crush Tube or Block, as
others have done. From my experience and what I've seen over the years is
that you WILL have a gear failure (Fus0005 will collapse). It might not
fail at the first gofer mound you hit or hole you fall in, but in inevitable
will happen (Fus0005 will fail without a crush tube or block).
Jeff
On Tue, Oct 6, 2009 at 8:47 AM, <srwhitenect@dcsol.com> wrote:
With the saddles on one end and the angle on the other end of the 5/16
bolts
plus the angle covering the side, it will most likely snap the bolt before
crushing the fuse five. I had trouble with the clearance of the tubes
inside
the fuse 5 anyways and felt that they were very slight to begin with. A
solid
bushing would do a better job of providing the strength they were looking
for.
Steve
On 10/5/2009 10:37 PM, westcoastkitplanes@gmail.com wrote to rebel-
builders:
-> Steve,
-> One question, why NO Crush Tubes ? Did you put something else in place
-> them ?
-> Jeff
-> On Mon, Oct 5, 2009 at 10:14 PM, <srwhitenect@dcsol.com> wrote:
-> > My two cents worth. Built the spring gear as pr manuel plus the angle
on
-> > top
-> > of the fuse 5. No cursh tubes. Angle well riveted to fuse 5. Out side
holes
-> > for
-> > the saddles are 3/8" further into the fuse 5's for better edge
distance.
-> > Distances given in the manuel got me too close to the end of the
tubes.
-> > Angle was 2024-T3 .250 2 X 2 and can't remember the length but was a
bit
-> > longer than specified. Am registered at 1800 lbs gross. Removed the
spring
-> > gear (at 131 hrs) which was a 67 lb change over for floats. All spring
gear
-> > bolts were at torque, showed no signs of working or chafeing on the
shafts.
-> > Have had my share of bump and goes. Will be the ultimate test later
this
-> > week after removing the floats, reinstalling the wheels and taking off
from
-> > a
-> > very short sand turf beach. Maybe quite lucky thus far but I do keep
it in
-> > mind when I think of where I'd go for a forced landing.
-> > Steve W 637R
