[rebel-builders] Rebel- Bell crank CC-47-2 Modified
Charlie Eubanks
Post by Charlie Eubanks » Sun Feb 19, 2012 5:37 pm
Hi Bob
Flap quadrant is not drilled yet so I can do 6-12 & 18 degrees if that what
I need. Thanks for the help
Sent: Monday, October 05, 2009 10:21 AM
Subject: Re: [rebel-builders] Rebel- Bell crank CC-47-2 Modified
[quote]
Hi Charlie !
Should be better, anyway ....
Not sure if that 15 was a typo - the max flapperon deflection
is 18 degrees - 3 positions of 6, 12, and 18 are standard ...
you will want the max....
bobp@prosumers.ca
responsibility of the reader.
On Monday 05 October 2009 12:58, Charlie Eubanks wrote:
[quote]Bob, Craig and Jeff M.
I took your suggestion Bob and just drilled an additional
Post by Bob Patterson » Sun Feb 19, 2012 5:37 pm
Hi Charlie !
bobp@prosumers.ca
