[rebel-builders] Rebel - Fus-5 Question
Post by Bob Patterson » Sun Feb 19, 2012 8:36 pm
Hi Richard !
I just checked out a couple of Rebels with spring gear - the nuts
are indeed forward. I suspect the reason might be that the forward
FUS-5's have a large chunk of the end cut off to fit the taper of the
front FUS-70's (which you should have, to replace the old FUS-10's,
if you still have those). Cutting the angle might leave you with
half-holes left ....
You should have a good read through the archives, and study
the photos of spring gear fixes .... If you do the machined solid
inserts into the FUS-5's, then you won't be using the larger
holes too often anyway. If you can cut the front angles, and
still have the holes with proper edge distance, then it likely
won't matter whether they are front or back ...
Also, there are factory Service Bulletins for Spring Gear Mods -
check under the Elite Tech Support pages ...
bobp@prosumers.ca
responsibility of the reader.
On Monday 05 October 2009 02:55, Richard E. Swan wrote:
Thanks for the response Mr. Patterson.
I have the spring gear, on a project that hasn't flown yet. In studying
the plans to get an idea of what to order for the new skins, and how to go
about it, I just happened to see that my plans called for drilling out the
ends of the rear tubes to install the three bolts (each side) that fasten
both forward and rear tube with their respective upright in the cage
assembly. When I looked at what I have on hand with the project, I noticed
that both forward tube ends have been drilled out for the three bolt that
orient with the nut to the rear.
Sent: Sunday, October 04, 2009 9:48 PM
Subject: Re: [rebel-builders] Rebel - Fuse 5 Question
Hi Richard !
I'm not sure what the problem is, if yours is already correct ...
just leave it.
If you have the bungee gear, I dont think it will matter much,
because somewhere in there, they even allowed the FUS-5's to
be cut in half lengthwise .... not that many do that anymore ...
If you have the spring gear, then there are a whole lot of other
considerations ....
bobp@prosumers.ca
persons. Any action taken as a result of the contents of this email is
totally the responsibility of the reader.
On Monday 05 October 2009 02:09, Richard E. Swan wrote:
Rebel builders/flyers:
I'm slowly rebuilding an older Rebel project (have removed all belly
skins
below the cabin because of corrosion), and I have a couple of questions
on
the forward Fuse #5 item.
Obviously I'd like to not have to drill out the several rivets on top
of the forward tube (fastening the forward cabin floor down), plus not
have to replace the forward tube.
If I do need to drill out the rivets and replace the forward Fuse #5,
is this tube 6061 or 6063?
thanks for any help!
Richard
Conway, Arkansas
Post by Wayne G. O'Shea » Sun Feb 19, 2012 8:36 pm
If I had a Rebel's cabin floor completely open.... the only mod I would be
considering to the existing spring gear would be getting rid of it and
installing the bungee style gear.
Sent: Sunday, October 04, 2009 11:21 PM
Subject: Re: [rebel-builders] Rebel - Fus-5 Question
Hi Richard !
bobp@prosumers.ca
go
noticed
that
Hi Richard !
just leave it.
considerations ....
bobp@prosumers.ca
Jeff Micheal
Post by Jeff Micheal » Sun Feb 19, 2012 8:36 pm
And then throw away the bungee's, replace with *Compression Spring Gear
Struts** ( Right Wayne ??)
On Sun, Oct 4, 2009 at 8:36 PM, Wayne G. O'Shea <oifa@irishfield.on.ca>wrote:
Hi Richard !
bobp@prosumers.ca
persons.
go
fasten
noticed
that
A
not
Post by Wayne G. O'Shea » Sun Feb 19, 2012 8:37 pm
Well of course Jeff..... :O)
From: "Jeff Micheal" <westcoastkitplanes@gmail.com>
Sent: Monday, October 05, 2009 1:21 AM
be
Hi Richard !
bobp@prosumers.ca
persons.
fasten
A
not
Post by Bob Patterson » Sun Feb 19, 2012 8:37 pm
Me too !!! My thoughts exactly ....
bobp@prosumers.ca
Hi Richard !
bobp@prosumers.ca
studying the plans to get an idea of what to order for the new skins,
and how to go
fasten both forward and rear tube with their respective upright in the
cage assembly. When I looked at what I have on hand with the project, I
noticed
that
