[rebel-builders] Accessing the list archives.
Hans Kuck
Post by Hans Kuck » Sun Feb 19, 2012 5:36 pm
Thanks Mike
cheers
Hans 640E
On Thu, Oct 1, 2009 at 8:45 AM, Mike Davis <mike.davis@dcsol.com> wrote:
Hans,
At the bottom of every list message you will see the following block of
information... you can just click on the link on the first line to get to
the archive website, use the username and password on the second line.
Once you've logged in, click on "List Archives" on the red bar across the
top of the page. Once this page loads click on "Rebel Archives" which will
expand the listing showing both the Rebel Builders list archives and the
Rebel Ramble list archives.
If you want to search through the archives for something specific I suggest
searching the "Message Body" as you have the best chance there. You can't
always count on the subject reflecting the message content, and poster's
addresses change.
Sent: Thursday, October 01, 2009 7:30 AM
Subject: Re: [rebel-builders] Re: Cooling with the speed cowl
Hi Walter, thanks for the helpful info. How do I get into the
archives???I
have a 2" spacer. As you say temps are a problem in the climb
cheers
Hans
640E
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
Hans Kuck
Mike how do I get the Pics, I got into the archives alright
cheers
Hans
Hans,
addresses change.
archives???I
cheers
Hans
640E
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
Post by Mike Davis » Sun Feb 19, 2012 5:36 pm
Click on "Files" in that red bar across the top... you will then see an area
for each aircraft, further divided into components/areas, i.e. elevator,
rudder, control systems, etc.
Sent: Friday, October 02, 2009 7:21 AM
Subject: Re: [rebel-builders] Accessing the list archives.
cheers
Hans
Hans,
will
suggest
can't
addresses change.
archives???I
cheers
Hans
640E
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
