Flaperon Drain Grommets
Posted: Sun Feb 19, 2012 8:36 pm
Hello Rebel Group:
Checked the archives for this subject with no joy, so I thought that I would tap into the group for some ideas, suggestions and answers.
A fellow Rebel Builder and myself (with no previous fabric experience) were discussing installing the Flaperon Drain Grommets, and that if a grommet in every bay at the trailing edge, low point was necessary. Is this a bit overkill? Can one just burn with a soldering iron, a small 1/ 8 inch hole in each trailing edge end rib (at the void) and call it good? Maybe adding single drain grommet at the inboard bay at the low point of each flaperon? Both of these Rebels will be going on floats eventually.
At this time we are leaning toward the small (1/8 inch) holes at the trailing edge root rib and adding a single grommet at the low point (inboard) at each flaperon, but still open for suggestions.
Any thoughts?
Thanks in advance.
Over-and-out . . .
Terry Dazey
Lake Tapps, WA
R662
Any thoughts?
Thanks in advance.
Over-and-out . . .
Terry Dazey
Lake Tapps, WA
R662
