Cooling with the speed cowl
WALTER KLATT
Post by WALTER KLATT » Sun Feb 19, 2012 5:36 pm
If you search back in the archives, there has been lots of discussion in the past about improving cooling with the fibreglass cowl. You need to open the bottom exit, and if that is not enough, then open the inlets a bit as well.
On my new 360 install, I managed to achieve good cooling without having to change the inlets. But on my previous one, I ended up opening the inlets before I had good cooling.
Float flying in the mountains in hot weather where you had to do long climbs was the big problem.
Also, having at least a 2.5 inch prop spacer helps, as then you can pull the cowl forward enough to allow more air past those front cylinders. In my previous install, I had only a 1.75 spacer which I think was part of the problem with the small inlets.
Date: Thursday, October 1, 2009 7:38 am
Subject: Re: [rebel-builders] Float Deck rail tape
To all Elite Builders,
I have just recently finished my Elite 640E and have flown the
first 25
hours. Engine temps are within limits but are to high for my
liking. I am
interested in building the 4 Piece Piper Style Cowling for the Elite.
Are there any plans, instructions, material list, good advise
etc out there.
What else can one do to reduce eng. temps with the regular
"speed cowl" form
MAM?
any help would be appreciated
cheers
Hans
On Wed, Sep 30, 2009 at 2:55 PM, Wayne G. O'Shea
<oifa@irishfield.on.ca>wrote:
I don't follow the "tape" Garry. Nothing I remember being there.
wayne
Sent: Wednesday, September 30, 2009 5:18 PM
Subject: [rebel-builders] Float Deck rail tape
On my floats the deck rail have some tape helping seal them
from the
deck.
Anyone know what it is?
Garry
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
