[rebel-builders] Float Wheel Well reinforcement
Posted: Sun Feb 19, 2012 8:32 pm
At 07:41 AM 10/09/2009 -0600, you wrote:
well side skin had wrinkled and was starting to crack. Other than that I
haven't done anything. I took some pics when I switched to die springs from
the dounuts so if I can find them it might show. On your other post my
wheel gear die springs just hang out in the wind.
Hi Gary I had to put in a triangular doubler to reinforce where the wheelDrew,
I think it was you that Walter said had done a reinforcement of the
main wheel mounts in your floats. Is that correct? If so, do you have
pics of what you did?
Garry
C-FOKM
