Starters
Posted: Fri Feb 17, 2012 11:27 pm
Hi All
We have a Toyota truck starter and a Nippondenso alternator from a Honda
car on the 0-290 on our Rebel.Also we have a Power-surge 12v garden tractor
battery way back in the tail and vented out the bottom of the fus. So far
it all works quite well and has been trouble free.
I recently completed a number of structural up-grades to the air frame and
have been very pleased with the results.The impetus for the work was a
deformed fus 40 when the 2bulkheads at the rear drag strut deformed where
they are notched. Anyway,while I had it that far apart to solid rivet
doublers on each side of the offending bulkheads I did a ton of other stuff
so I would'nt have to go in there again.Including making new .032 lower
rear corner wraps,fus 40,pie-shaped doublers under the rear of the
door,front lower corner wrap doublers,.040 door sill,and .032 witchs-hats
in 5 places on each side. By the time I finished I had consumed most of a
sheet of .032 .
Plus a bunch of things to enable the amphib/land-gear transition to go
smoother.
Best Regards, Angus
P.S. Sorry about your cowl Bob.My wife always says to me,"Take a deep
breath,its nothing that money can't fix".
sheet of .032 .
smoother.
Best Regards, Angus
