0 320 engine mounts / cowling
Posted: Fri Feb 17, 2012 8:27 pm
You've REALLY hit a sore spot for me !! I <REALLY> don't
like the "speed cowl" (which does NOTHING for speed !) - it's a
REAL pig for maintenance, especially on floats !! Where do you
put this huge sail that will sink if you drop it ???!!!
I'm particularly burned, because the cowl wires (that were
even bent around the lip of the cowl !) came forward and chewed
great huge chunks (1/4" square !) out of my prop !!!!! The shape
of the speed cowl forces them forward if vibrated.... And that
was a brand-new $3,000 prop !!! Not to mention the mess I'd have
been in if it hadn't happened on short final !!
NEVER had a problem with the wires on any of our other 3
Rebels ! Or ANY Rebel I've ever flown with the 'standard' cowl.
Of course, this <could> be avoided <IF> I came up with a sure-fire
solid, guaranteed way to hold those wires in place that would
still let me get them out easily !
Also, you can't really do a proper preflight with the ^%$^%$%^
thing - just peer in through the oil filler flap !
In terms of cost - add about $2,000 for that sexy cowl !!
Add it up - cowl, special prop spacer, special spinner, special
exhaust .... $$$$ !!!!
If you do the 'standard' cowl, you can put the side braces
on horizontally, add piano hinges top & bottom, and .... just pull
2 pins and swing open the top & bottom of the cowling !!
If you're concerned about looks - a Rebel builder in Australia
used a Thorp T-18 nose bowl from Aircraft Spruce (about $85), and
it looked pretty sexy ....
I was SO mad at this cowling, I'd have traded ANYBODY for
2 cents !! I just wanted to put a little tape over the oil cooler
inlet to raise my temps a bit (it's getting cold here !) - Only
takes an HOUR !! Pull the pins (bending carefully), undo a bunch
of screws, lift and place SOMEWHERE .... GGGRRRRRRRRRR !!!
I'm still threatening to take a hacksaw to it, and carve
out some decent side panels, with piano hinges !! You can KEEP
'sexy' - give me MAINTAINABILITY !!!!!
Sorry for the tirade, but I'm still peeved with the thing !!
....bobp
-----------------------------orig.---------------------------------------
At 08:22 PM 11/2/00 EST, you wrote:
....bobp
---------*OK, old cowling verse new cowling for those of us who have still to decide
and order a cowling. Which cowling do you prefer, and why? I've heard ease of
maintenance, and know the prop spacer and C of G for the old cowling. The new
cowling gets marks for looks and better visibility (well, on second thought,
looks might be a personal preference). Lets not forget cost. Is it worth it?
Bruce G 357R
