[rebel-builders] Moose: Elevator trim (crush tube)...was: Ray Allen Servo
I have checked my manual chapter 3 and there is no reference to a crush
tube for the servo and there isn't any reference to it in the parts
list. We got our Elite kit in 2005. On looking at it again I can't
imagine that there would be a problem of it bending with just air loads.
Maybe with such a large trim tab it is easy to damage?
Bob
773E
Ted Waltman wrote:
Bob
773E
Ted Waltman wrote:
Part # is "Crush Tube" listed as EL--0032 in the manual. I thought it was
per a service bulletin, but none is shown on the website. The issue is that
the trim tab actuator arm is simply a 1/4-28 threaded rod. That rod will
bend under moderate force. Hence, once one has the rod cut to proper length
and tested for successful full up/down trim travel, one is to spread proseal
on the threaded rod then slide the crush tube over it. The crush tube,
therefore, is simply an aluminum sleeve (pipe, per se).
Hope this helps and makes sense,
Ted
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Hans
Kuck
Sent: Saturday, August 22, 2009 10:58 AM
Subject: Re: [rebel-builders] Moose: Ray Allen Servo
TED, could you please mail me a copy of the service bulletin regarding the
Ray Allen Servo. I was not aware that there was such a S.B. to
hansk3d@gmail.com
cheers
Hans
On Fri, Aug 21, 2009 at 7:58 PM, Ted Waltman <tedwaltman@gmail.com> wrote:
theFred,
AFAIK, every Moose owner uses this combination servo/actuator arm. Put
aresleeve on as per the service bulletin (get a sleeve at your local hardware
store if you don't have one already).
Ted
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Fred
Messinger (fredm)
Sent: Friday, August 21, 2009 3:45 PM
Subject: Re: [rebel-builders] Firewell caulk
Hi Guys,
I'm currently installing the elevator trim tab servo motor on my moose
quick
build.. The one MAM shipped is manufactured by The Ray Allen Company.
Everything (motor casing, clevis forks) is made out of a hard plastic
material. The push rod itself is a threaded metal rod, though.
My questions: Is anyone else using this set up? If not, which system
you using?
I confess, I'm a little concerned about those flimsy little clevis forks
the plastic drive pin....especially in cold weather.
Fred
Checked by AVG - www.avg.com
Version: 8.5.409 / Virus Database: 270.13.64/2321 - Release Date: 08/23/09 06:18:00
