Received: from ts72-12.tor.istar.ca [204.191.146.219]
by mail1.toronto.istar.net with smtp (Exim 1.80 #5)
id 0ychXd-0001re-00; Thu, 21 May 1998 22:26:41 -0400
Mime-Version: 1.0
Subject: Brushable Pro-Seal
Message-Id: <E0ychXd-0001re-00@mail1.toronto.istar.net>
Date: Thu, 21 May 1998 22:26:41 -0400
Hi, everybody !!
Several of you have asked about "Brushable Pro-Seal" - there even
seem to be a few people who don't believe it exists !!!
Here is where to get it:
Leavens Aviation Inc.
2555 Derry Road East,
Mississauga, Ontario L4T 1A1 Canada
Local tel: (905) 678-1234 Fax: (905) 678-7028
Parts Order Desk: 1-800-263-6142 (don't know if this works
outside Canada ... )
Ask for Stuart or Leanne, (tell them I sent you ... :-) )
The Part no. is: PR1005L Brushable Pro-Seal
The price is: $56.60 CDN for a one pint kit, incl. hardener.
(U.S. $ get about a 40% discount !! )
This stuff is great for stopping small leaks after the tanks are
closed, but even better to brush on BEFORE closing. Great to cover rivets
and seams. Avoid putting it on too thin, though - it might peel off
later !
Good luck !!! ....bobp
Brushable Pro-Seal
Brushable Pro-Seal
Received: from JimsRebel@aol.com
by imo30.mx.aol.com (IMOv14_b1.1) id ELLHa29472
for <murphy-rebel@dcsol.com>; Tue, 26 May 1998 22:01:23 +2000 (EDT)
Message-ID: <4731e0b7.356b73f4@aol.com>
Date: Tue, 26 May 1998 22:01:23 EDT
Mime-Version: 1.0
Subject: Re: Brushable Pro-Seal
X-Mailer: AOL 3.0 for Windows 95 sub 49
Hi all
Pro-Seal can also be thin out to be brushed on with MEK. After you mix the
two parts together add MEK then use a acid brush. After you have thin it
once
dont thin it again. If you only need a little , thinning out your left over
is
a lot cheaper. Pro seal 890A-2 is a brushable type , 890B-2 is the thick
kind. The -2 is two hour set up time , it also comes in -1 or -1/2 for
faster
set up times. Faster set up times can help seal up leaks when the aircraft
has
been flying already. I got my Pro-seal from Courtaulds Aerospace (206)
483-3999 near Seattle WA
Good luck
Jim LePard Rebel-254
JimsRebel@aol.com
Mime-Version: 1.0
Hi all
once
is
faster
has
Good luck
JimsRebel@aol.com
Brushable Pro-Seal
Received: from d.james (ba1p16.planeteer.com [204.50.144.49])
by toronto.planeteer.com (8.8.7/8.8.7) with ESMTP id VAA13075
for <murphy-rebel@dcsol.com>; Wed, 27 May 1998 21:35:00 -0400 (EDT)
Message-ID: <356CBFEB.D090DC17@planeteer.com>
Date: Wed, 27 May 1998 21:37:48 -0400
X-Mailer: Mozilla 4.01 [en] (Win95; I)
MIME-Version: 1.0
X-Priority: 3 (Normal)
References: <4731e0b7.356b73f4@aol.com>
X-Corel-MessageType: EMail
Just a few points regarding Pro-Seal:
- the 'thick' stuff is properly called 'extrudable'
- when I mixed up a batch of Pro-Seal I put 1/2 in a sealed container
and put in the freezer immediately and left it there for an hour or so
until needed, that way I didn't waste a drop! (if you exclude the 10% of
every batch that ended up on clecoes, pliers, clothes etc.)
David James
Rebel 228R
MIME-Version: 1.0
David James
Rebel 228R
Brushable Pro-Seal
Received: from tim-toshiba - 206.40.8.15 by email.msn.com with Microsoft
SMTPSVC;
Fri, 18 Dec 1998 10:54:11 -0800
Reply-To: <tlcarter@email.msn.com>
To: "'Murphy Rebel'" <murphy-rebel@dcsol.com>
Subject: RE: Brushable Pro-Seal
Date: Fri, 18 Dec 1998 10:29:32 -0800
Message-ID: <000001be2ab7$ce659c60$01650a80@tim-toshiba>
MIME-Version: 1.0
charset="iso-8859-1"
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook 8.5, Build 4.71.2173.0
Importance: Normal
X-MimeOLE: Produced By Microsoft MimeOLE V4.72.3155.0
In-Reply-To: <001301be2a18$bdf53ce0$319e13d1@drmooney>
Return-Path: tlcarter@email.msn.com
In a previous e-mail I gave another source for the Pro-Seal from Seal Pak in
Kansas. they have competitive prices, and this is the stuff that came
originally with my kit.
SealPak
2614 South Hoover
Wichita KS 67215
316-942-6211
They have both spatula and brush grade Proseal.
Tim
Sent: Thursday, December 17, 1998 3:56 PM
To: Murphy Rebel
That's great for you north of the border folks. Down here there is a better
way. I talked to the people in Ontario and it seems that the brushable
proseal is a hazardous material as far as shipping is concerned and is VERY
expensive to do to the states. For the US people there is a source in
Seattle. Atlas Supply, 206-623-4679. They can ship UPS with no problems.
Darrel Mooney
SMTPSVC;
MIME-Version: 1.0
Importance: Normal
SealPak
2614 South Hoover
Wichita KS 67215
316-942-6211
Tim
To: Murphy Rebel
Darrel Mooney
Sent: Thursday, May 21, 1998 8:27 PM
To: Murphy Rebel
Hi, everybody !!
later !
Brushable Pro-Seal
Received: from [137.186.224.236] (helo=ms01-236.tor.istar.ca)
for murphy-rebel@dcsol.com
id 0zrUZ2-0002pU-00; Sat, 19 Dec 1998 17:09:33 -0500
Mime-Version: 1.0
Message-Id: <E0zrUZ2-0002pU-00@mail2.toronto.istar.net>
Date: Sat, 19 Dec 1998 17:09:33 -0500
tell me the kit included a hardener ?? Was your 1005L info direct from
Courtaulds ?
--------------------------------orig.----------------------------
Mime-Version: 1.0
Just curious, Paul - if this is a one-part solution, why did LeavensThe PR-1005L mentioned in one e-mail is a one-part Buna-N slosh coating to
be used mainly for repair of leaks.
Courtaulds ?
callHi there!
Just a few more lines on PRO-SEAL. The stuff that MAM sent with my kit was
PRO-SEAL P/S 890 Class B1. This is beading, filetting (thick) stuff with
good strength, good fuel resistance and good adhesion to aluminum.
It comes as brushable if you spec the same number but Class A1.
All this stuff is made by Sealants and Coatings, Courtaulds Aerospace,
Glendale Calif., 818-240-2060. They make sealants and finishes for just
about anything that flies (incuding the Shuttle) worldwide.
They can supply data sheets and local distributors. (In Canada you can
VERY905-629-7999).
On the wet wing design in general: I just recently found out the new Cessna
Skyhawks now use wet wings. The photos of their opened tank show gooped up
seams very much like in my Rebel.
Oh yeah!....that's it .........they're trying to copy the Rebel!!......
Happy building! Paul Kucera, 453R , Ontario
To: 'Murphy Rebel' <murphy-rebel@dcsol.com>
Date: Friday, December 18, 1998 1:54 PM
inIn a previous e-mail I gave another source for the Pro-Seal from Seal PakbetterKansas. they have competitive prices, and this is the stuff that came
SealPak
2614 South Hoover
Wichita KS 67215
316-942-6211
Tim
To: Murphy Rebel
That's great for you north of the border folks. Down here there is away. I talked to the people in Ontario and it seems that the brushable
rivetsexpensive to do to the states. For the US people there is a source in
Darrel Mooney
To: Murphy Rebel
Hi, everybody !!
later !
Brushable Pro-Seal
Received: from [137.186.229.26] (helo=ms02-534.tor.istar.ca)
id 0zs94P-00073C-00; Mon, 21 Dec 1998 12:24:37 -0500
Mime-Version: 1.0
Message-Id: <E0zs94P-00073C-00@mail2.toronto.istar.net>
Date: Mon, 21 Dec 1998 12:24:37 -0500
Thanks for the clarification, Paul !!
This is VERY interesting - good stuff to bring along to the next
Builders Meeting (Jan.10), if you can ...
You might try AeroSpares, just around the corner from Leavens, on
Torbram. Several of the fellows have found they also have ProSeal, sometimes
at better prices !
....bobp
------------------------------orig.---------------------------------
Mime-Version: 1.0
at better prices !
....bobp
toHi Bob. I ordered the PR-1005L from Leavens going by their cat. description
but I did not like what I received (one part sealant and no data sheet).
Leavens buy PRO-SEAL from ASC, Courtaulds Aerospace branch in Mississauga
who will only sell min. $1000!!!! batches.
I went to ASC and picked up their catalogue.
PR-1005L is a one-part a/c fuel tank sloshing compound with good stiction
Leavensalum. and polysulfide (eg.PRO-SEAL) sealants. It dries clear.
The P/S 890 Class B1 that MAM supplied with my kit is good stuff but
todon't have it right now.
Leavens cat. descriptions are not very good. The PR-1422, PR-1826 and
PR-1440 are all fuel tank sealants with different properties (eg. stiction,
hardness, full cure time, temp. resistance). The PS-870 is a corrosion
inhibitor.
I found a better phone number for ASC, Coutrtaulds Aerospace:
1-800-237-6649
Paul
To: Murphy Rebel <murphy-rebel@dcsol.com>
Date: Saturday, December 19, 1998 5:10 PM
wasJust curious, Paul - if this is a one-part solution, why did Leavensbe used mainly for repair of leaks.
Courtaulds ?
At 11:16 PM 12/18/98 -0500, you wrote:Hi there!
tocallPRO-SEAL P/S 890 Class B1. This is beading, filetting (thick) stuff with
They can supply data sheets and local distributors. (In Canada you can905-629-7999).
upCessnabe used mainly for repair of leaks.
On the wet wing design in general: I just recently found out the newSkyhawks now use wet wings. The photos of their opened tank show gooped
Pakseams very much like in my Rebel.
VERYin betterproblems.rivets
