[rebel-builders] 1800 amphibs
Rebecca Brownell
Post by Rebecca Brownell » Sun Feb 19, 2012 4:51 pm
Thanks Craig ,they are sold
Jason
On 19-Aug-08, at 4:12 AM, Craig Walls wrote:
Jason,
There was a built set of MAM 1800 amphibs for sale 2 weeks ago in
Dowagiac
MI. (close to Kalamazoo) $23,000. I saw the add on Barnstormers
and can't
find it now but they may still be out there. It's a start.... Craig
Rebecca Brownell
Sent: Monday, August 18, 2008 3:54 PM
Subject: [rebel-builders] 1800 amphibs
Hi all
does anyone know of a set of 1800 amphibs out there that may be
available?New,used, built, not built,doesn't matter.
I'm on the "list" to get a set if there are 9 others who want them but
I hate the thought of going without floats for very long
after the plane is done.Will take them immediately if I can find
them.Or if anyone knows of a suitable alternative that
weighs about the same as the 1800 please let me know.
Thanks so much
Jason
817R
Randy McCallum
Post by Randy McCallum » Sun Feb 19, 2012 4:52 pm
Hi JasonI have a pair of 1800 Aerocomp super float amphibs for sale. They came off of a Taylorcraft and I was going to put them on my Rebel but I have both the plane and the floats for sale. The floats are in great shape but would have to be rigged for your Rebel. You can get more information on the floats from their website http://compairasia.com/floats/photo4.htm & http://mireley.net/glcompair/floats.htm I am asking $11,900 for them. They are in my hanger at Burlington Air Park, Ontario, Canada. If you want any more information let me know.Randy52R
From: brownell@candlelight.ca> To: rebel-builders@dcsol.com> Subject: [rebel-builders] 1800 amphibs> Date: Mon, 18 Aug 2008 19:53:35 -0400> > Hi all> does anyone know of a set of 1800 amphibs out there that may be > available?New,used, built, not built,doesn't matter.> I'm on the "list" to get a set if there are 9 others who want them but > I hate the thought of going without floats for very long> after the plane is done.Will take them immediately if I can find > them.Or if anyone knows of a suitable alternative that> weighs about the same as the 1800 please let me know.> > Thanks so much> Jason> 817R> > > > -----------------------------------------------------------------> List archives located at: https://mail.dcsol.com/login> username "rebel" password "builder"> Unsubscribe: rebel-builders-unsubscribe@dcsol.com> List administrator: mike.davis@dcsol.com> -----------------------------------------------------------------> > >
Post by Ken » Sun Feb 19, 2012 5:45 pm
Jason
I have an older 1995 manual.
If you mean bulkhead LB, I have a diagram (fig. 16f) that measures down
the middle 16 1/4 to the bend line. It also shows up the side edge 3 1/8
to the cut line with the bend line being 5/8 above that at the side edge
of the bulkhead.
I used those measurement without difficulty. The only important
measurement is the 16 1/4 down which is given in the text as well as
that diagram. All the bottom V angles are the same and you want a 5/8
flange on the bottom after you bend it.
The only problem I had with cut down bulkheads was bulkhead I as in
india which was about .1" too short top to bottom for some reason. I put
a .1" thick aluminum bar between the bottom skin and the bottom of the
bulkhead to fix that and keep the bottom skin flat.
Oh one more caution. Keep the flanges as tight to the bottom outboard
corner of the bulkheads as you can. I had a few places where I had to
put doublers in the corners as the rivet holes did not have adequate
edge distance. Trim the corners of the flanges after you bend the bottom
flanges and don't trim them at 90 degrees if an angle will let them
extend further into the corner. Especially important on the front
bulkheads from about A to C.
Rebecca Brownell wrote:
Hi all.In the manual for the floats,Fig.3.8.1 landing gear bulkhead.In
the written text it says measure down from the top 16 1/4 and measure
up 3 1/8.In the drawing for this step it shows 15 15/16 down and 3 3/8
up.This step is for cutting the bulkhead to size.Has anyone else
figured out which is the correct measurement.Ken?The manual has been
really good so far,must be a correction from a later date.Any help
would be appreciated.
Jason Brownell
817R
Rebecca Brownell
Post by Rebecca Brownell » Sun Feb 19, 2012 5:45 pm
Thanks Ken.16 1/4 it is.Did you have to trim the gap at the very
bottom of your bulkheads to 5/8 as described in the manual.Can't
figure out why this is done.?
Thanks again
Jason
On 8-Nov-09, at 8:03 PM, Ken wrote:
Jason
down
1/8
edge
of the bulkhead.
put
bottom
bulkhead.In
3/8
Jason Brownell
817R
When you get around to installing the forward keel you will notice that
it is flat about 5/8" wide across the bottom. A wear or rub strip bolts
onto the bottom of that flat section.
The rear keel is V shaped. There were a few things that I scratched my
head over while building the floats as well ;)
Thanks again
Jason
Rebecca Brownell
Rodger that,thanks
JB
that
bolts
Thanks again
Jason
Post by Ken » Sun Feb 19, 2012 5:46 pm
I believe there was a change as to how to mount the rear of the channel
against bulkhead C depending on your serial number. Originally you bent
flanges on the aft end of the channel. I used extruded aluminum angle
instead of bending flanges (which I think is the current method) and I
may well have trimmed the length.
Before you install the tracks that the front gear rides in make certain
the plastic rollers fit in the slot for the entire length without
binding because it was a pain to deal with that after assembly. Mine
needed some filing for the entire length. If the track is a tiny bit
wider at the aft end it will let you shim the gear against side movement
when it is down and it won't binding during retraction.
Could anyone who has built a set of floats tell me if they had to trim
the length on FL 209?It's the channel for the front gear.Looks like I
need to trim 1/2 inch off the front end but it doesn't mention having
to trim.Thought I'd check first.
Jason
817R
Rebecca Brownell
Post by Rebecca Brownell » Sun Feb 19, 2012 5:46 pm
Thanks Ken,the flanges were made from angle in my manual.I guess i'll
trim the length.Shim against side movement?Not sure what you mean there.
Thanks Jason
channel
bent
certain
movement
trim
Jason
817R
Jason
If the front gear tracks are vertically parallel on the front vertical
part then you can shim (with washers) the front gear leg to minimize
side to side play of the gear leg. But you won't be able to retract the
front gear if the tracks are narrower (closer to each other) at the rear
of the tracks. No problem at all if they are a tiny bit wider at the
rear though. If there is too much side to side play of the gear leg it
is going to be very difficult to control wheel shimmy.
Make sense now?
Thanks Jason
channel
bent
certain
movement
trim
Jason
817R
Rebecca Brownell
Yes Ken I think so,I'll let you know how it goes.Thanks for your time.
Jason
On 13-Nov-09, at 9:41 PM, Ken wrote:
Jason
rear
Make sense now?
there.
Thanks Jason
channel
bent
angle
and I
certain
movement
No doubler that I'm aware of Jason
(Ignore the doubler on Waynes's pic on his CD if that is what you are
looking at as that was a one off thing)
THe two aluminum cover plates for the front two large holes are
described in about the last chapter of the manual for some reason. Think
the chapter is "finishing the top deck" or similar.
I believe you will only use 7 of the plastic covers per float.
Hello all,I wonder if someone could help me understand something?There
is photo's in the manual for the floats that show the top deck with a
doubler that goes from the front back to at least past the first
inspection hole.It shows a cover plate made from aluminum for the
first two inspection holes.The manual mentions that these holes get
covered with tops made from FL211's wich I have.However there is no
mention of a doubler on the deck and no section on making covers from
the FL211's.I have 19 plastic covers for the floats which is enough to
cover the first two holes as well but I can't see how that would
work.Completely baffled on this point.If anyone could offer some
clarity as to what the finished float looks like up front in that deck
area it would be greatly appreciated.
Thanks so much
Jason
817R
Rebecca Brownell
Thanks Ken.I get thinking I'm missing something .I hate moving ahead
when I don"t have the big picture.There must have been many changes in
the float manual,was there?It's not too bad but not quite as thorough
as the plane manual.Thanks again for your time.
Jason
817R
Think
There
deck
Thanks so much
Jason
817R
Post by Wayne G. O'Shea » Sun Feb 19, 2012 5:46 pm
There have been NO changes in the float manual that I know of since the
first kit I aquired in the early 90's.. As you know Jason and as Ken
mentioned... I do have a complete build CD with over 1200 pictures that come
up like a slide show. Step by step in the order they are built, not in the
order the manual spells out.
From: "Rebecca Brownell" <brownell@cottagecountry.net>
Sent: Tuesday, November 17, 2009 11:28 PM
Subject: Re: [rebel-builders] 1800 amphibs
Jason
817R
Think
There
deck
Thanks so much
Jason
817R
MAM sent you T rails for 1500 floats... they are about 21 inches shorter
than the 1800's !
Funny you have 6 though... you should only have 4 x 16' pieces of T rail.
Sent: Thursday, November 19, 2009 5:28 PM
Here we go again.Are the top rails not supposed to be the full length
of the float?One piece aprox 15'9".I have 5 pieces 14'2" long.The way
I read the manual It's supposed to be one piece and trim off the
extra.What the.........?
Jason
817R
Rebecca Brownell
Hi Wayne I have 5 14'pieces.What the he.. do I do now?
shorter
than the 1800's !
rail.
Jason
817R
