props
Dale Kopff
props
Post by Dale Kopff » Sat Feb 18, 2012 12:00 am
Sent: Tuesday, November 11, 2003 8:52 PM
Subject: Re: props
Dale,
How interesting about your Prince prop out performing the Sensenich. The
22lb. not hanging way out front of the C&G is enough of a plus on its own!
Have
any more detail on the specs? I suppose the only real draw back would be
its use
on a float plane, being wood and composite. tell use more.
Bruce
Bruce, I have leading edge protection and with a cabon fiber finish, there
is no problems being on floats.
The Sensenich with spacer and hardware 38 lbs, Prince 13 lbs with the same
spacer and hardware. I used a spacer made by Saber which is compatable with
both ;props.
Static thrust, Sensnich 450 lbs @2400rpm, Prince 505lbs @2300rpm.
The Prince prop averaged 70 fpm rate of climb better than the Sensenich.
Full power both indicated 115 @ 2600 rpm.
Additional information can be had by e-mail, "propellers@aol.com.
Dale
Angus McKenzie
Props
Post by Angus McKenzie » Sun Feb 19, 2012 12:16 pm
Hi everybody, summer greetings!
I've been running a McCauley 74X56 (now re-pitched 54") that was on my 0-320-A2B on the Champion GCBC it came from.
Built the engine up to 160+hp; the prop worked great at 56" on wheels and then I went on MAM amphibs, after trying a friends' 74X52 I had the 56" re-pitched to 54". Works quite well.
Off the water in fairly quick times at gross+ and cruises at 80kts IAS at 2400rpm.
Max static rpm is 2400 and max level flight rpm is 2550.
Not getting to the 2700rpm where all the horsepower lives. Possibly a bit over-propped.
So, to complicate the equation I bought an 80X40 Borer (McCauley) off a 150hp Champion GCBC.
I intend to install this prop as-is and verify performance but I'm expecting to need to re-pitch to about 43". Oh', as well, there was a 2" McCauley spacer came with the prop if anybody needs one let me know.
Has anyone else tried a Borer? Results? Numbers? Advice? I know that "rule-of-thumb" is: 1" of pitch = 100rpm
As an aside to this I heard today from Carm Titus that his cousin Mike Titus (longtime Leavens employee who has helped many of us Rebel types with our engines) was working on a plane at Brampton in recent weeks and momentarily distracted by a bystander got hit in the head by a prop blade. Carm said Mike is going to lose one eye. You can't be too careful.
Thanks and best regards to everyone, Angus
Dennis Finley
props
Post by Dennis Finley » Sun Feb 19, 2012 5:37 pm
Hi All
Has anyone out their ever switch from a sensenich prop to a cato
prop,and if they have was it on floats,what did they think,I'm getting
close to buying my O-375 lycoming 215 HP
and i was thinking of going to the cato 3blade 78 inch that the
people at cato recommended it was 20 lbs lighter. with the hollow
crank,Eci cylinders and prop i can loose 30-35 lbs up front and gain
35 HP.
Dennis Finley
Elite amphib C-FDYF
mike jones
props
Post by mike jones » Sun Feb 19, 2012 5:58 pm
Hi all
I have a line on a prop for my 160 hp Lycoming, its a sensenich model
74dm6-0-60, may have come off a pa-140 owner says
Does anyone know if this would work on my setup, assume pitch is 60, way to
much but perhaps it can be repitched
I don't know much about props so any help would be nice
cheers
props
Post by Ralph Baker » Sun Feb 19, 2012 5:58 pm
Mike,
I believe Sensenich will repitch a metal prop a total of 4 inches over its life. You might want to confirm that with them and review the prop log to see if any of that 4' has been used up.
craig
Props
Post by craig » Sun Feb 19, 2012 8:50 pm
Yes, I got the HTML thing right after I sent the second email from work.
Here's the question: A friend asked me why no one puts a borer prop or a longer one on the rebel or elite. I didn't know why. I know the 180 hp cubs and such are using longer ones. CW
