[rebel-builders] Jabiru engines
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 4:31 pm
I hadn't thought much about the paint shaker aspect -- why six are
smoother than four. Thanks for explaining, and for encouragement.
If you had told me three years ago that I'd soon be building a real
airplane at all, much less with an engine that apparently hadn't been
used on the chosen airframe in the northern hemisphere before, I would
have laughed at the absurd lunacy of both points -- yet here I am doing
it. Funny how that happens. I have to thank the great folks on this list
for encouragement -- to do something this nuts! :-)
Ron
Ken wrote:
Nothing intended but encouragement Ron.
Experimental aviation would be pretty boring if we all did the same
thing. In theory you have more power than a rotax so the challenge is
whether you can make it available on a Rebel. The Kitchener crew was
comparing a 4 cylinder Jab to the rotax rather than your 6 cylinder engine.
I actually prefer the 6 cylinder 0-300 to the more popular 4 cylinder
0-320. Smoother and cheaper to operate IMO.
As previously mentioned, a 4 cycle, 4 cylinder engine does not have
overlapping power pulses like a 6 cylinder engine. Between every power
stroke, the 4 cylinder engine slows down a bit which decelerates the
prop and flexes the engine mount rubbers in the opposite direction etc.
Much like a paint shaker... ;)
rshannon
Post by rshannon » Sun Feb 19, 2012 4:31 pm
BTW, those who believe the faster revving, shorter prop'ed Jabiru 3300 will
not perform as well as the slower revving, longer prop engines on slower,
draggy airframes should look at the performance comparisons published by
Legend Cub. (See http://www.legend.aero/content.asp) Even on their
relatively draggy Cub knockoff, the Jabiru outperforms their standard O-200
in every category, including take off AND top speed.
Granted, the Rotax 912S is probably some 50+ lbs. lighter than the O-200 so
it may well perform better than the O-200. Maybe even enough to catch up to
the Jabiru. :-)
Ron
Keith Leitch
Post by Keith Leitch » Sun Feb 19, 2012 4:31 pm
Ron,
I for one agree with you. I had talked to Legend while at Oshkosh and they were very happy with the Jabiru. The only problem they relayed to me was in cooling it. They recommended putting CHT on all cylinders and keeping an eye on them. I think they may have gotten the problem worked out since they do sell them with the Jabiru. I guess the performance of the Jabiru vs the O-200 is quite a bit better.
Keith
the Jabiru. :-)
Ron
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
C&P Kucera
Post by C&P Kucera » Sun Feb 19, 2012 4:31 pm
Thanks for the info Ron, the Cub has two things going for it, the huge 35 ft
wing and 26" narrow fuse.
I think the Rebel on sraight floats will not do that great with the Jabiru
because of the short prop and wide fuse and shorter wingspan.
paul
reb453R
Sent: Monday, March 24, 2008 12:02 PM
Subject: Re: [rebel-builders] Jabiru engines
will
O-200
so
the Jabiru. :-)
Ron
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 4:56 pm
Alright thrill seekers... although the hubbub has settled down of late
[Yea!] I can't resist passing on this contribution to The Great Jabiru
Debate [Ed.: See message archives, this subject line. Thou shalt not repeat.
<g>]
Some months ago I made my first contact with a real Jabiru 3300-powered
Rebel in the wild. Dan Dyet has one of the earlier mechanical valve lifter
models on 730R. He reported at first he had problems with cooling, which he
acknowledged have been addressed in newer models. (He apparently did not use
a Jabiru nose bowl.) However, he included the following performance data:
I am using the std Bing carb without the economy tuning kit. Haven't had any
issues with it at all, good carb.
Engine runs great and starts like a charm (with preheat during winter).
I have one of the original models,mechanical lifters.
I started out with the GT wood prop then switched over to a Sensenich ground
adjustable carbon fiber.
GT prop at 64" dia and 51" pitch is too coarse for the Rebel airframe.
GT prop on climb out at 70 mph gave me 2700 rpm 700 fpm solo, cruise 2750
rpm at 120 mph, WOT 2900 rpm 130 mph.
Sensenich prop 64" at a pitch setting of 2.5 gave me 2900 rpm at 70mph 1000
fpm solo climb out, cruise 2750 rpm at 110 mph, WOT 3200 rpm 125 mph. With
this prop I use up less than 200 ft of runway before I'm in the air and
flying.
---[end quote]---
He didn't mention the takeoff gross he was carrying for these results, but
IMHO, with either of those props, the numbers are not too shabby for 120 HP.
The newer hydraulic lifter models have redesigned cylinder cooling fins,
redesigned baffle ducts, better oil pump, better carb tuning, they specify a
more efficient Positech cooler and reportedly have a bit more demonstrated
HP than the early models. The total width of the 3300 is barely 24" which,
with a properly fitted nose bowl/cowl, makes for a pretty small drag profile
up front.
Ron
254R
http://n254mr.com
Joe Ronco
Post by Joe Ronco » Sun Feb 19, 2012 4:56 pm
Good info Ron. If you can get it, I would be interested in the 730R empty
weight, max gross weight it is registered at and the weight when he took
these readings. Also the fuel burn at the various speeds.
J Joe
Shannon
Sent: Tuesday, October 21, 2008 8:19 PM
<g>]
flying.
---[end quote]---
up front.
Ron
254R
http://n254mr.com
Post by Walter Klatt » Sun Feb 19, 2012 4:56 pm
Ron, why would the coarser prop at 2900 rpm do 130 mph while the finer one
do only 125 mph at 3200 rpm? That engine should be producing more hp at the
higher rpm, which should translate into more speed, not less. With my Rebel,
I have always got more speed out of it if I could pitch my prop for maximum
rpm at WOT.
Shannon
Sent: October 21, 2008 7:19 PM
<g>]
flying.
---[end quote]---
up front.
Ron
254R
http://n254mr.com
Ron Shannon
I'll probably put my foot in something here but (here goes) this doesn't
surprise me.
With the std. Bing carb, other things being equal the Jabiru 3300 develops
max HP at around 2800 RPM +/-. As all props "unload" with increased airspeed
and, if the props being compared are more or less appropriate for the
engine, the more finely pitched prop will be more unloaded ( at a higher
cruise speed than will a coarse prop. To put it another way, the more coarse
cruise prop will still be pulling (with its max thrust) at higher airspeed
AND slower RPM, because the latter (2800 RPM) also yields greater HP.
(Notice the difference in WOT: the cruise prop WOT was 300 RPM less than the
climb prop means it was more fully loaded, developing more thrust, even at
slower RPM, when at cruise+ airspeed.) Another way to say it is at cruise+
airspeeds, a finer pitched prop's thrust-per-RPM will max out at a lower
speed.
Of course, the airspeed vs. RPM vs. prop pitch is not a linear set of
tradeoffs, with each one pivoting around the others in perfect correlation,
in large part because drag increases with the square of airspeed, but also
because of the sweet spot where max HP occurs.
In short, the cruise prop developed more thrust at 2800 RPM (max 120 HP)
than the climb prop developed at 3300 RPM (l~100 HP). Of course, as we all
know, different results occur in the lower speed ranges and different loads,
i.e., climb.
That makes sense to me... I think.
Rebel,
rpm at WOT.
Shannon
repeat.
<g>]
use
any
ground
flying.
---[end quote]---
HP.
profile
up front.
Ron
254R
http://n254mr.com
Ron Shannon
Oops! That got sent in the middle of editing, before it was fully baked.
I've tweaked the version below a little more, though I'm not sure it really
adds much to my 1st edition gibberish.
surprise me.
engine, the more finely pitched prop will be more unloaded at a high cruise
speed than will a coarse prop. To put it another way, the more coarse cruise
prop will still be pulling at higher airspeed AND slower RPM, because it's
more loaded AND the latter (2800 RPM) also yields greater HP to cope with
that load. (Notice the difference in WOT: the cruise prop WOT was 300 RPM
less than the climb prop means it was more fully loaded even at slower RPM,
when at cruise+ airspeed.) Another way to say it is at cruise+ airspeeds, a
finer pitched prop's thrust-per-RPM will max out at a lower speed.
i.e., climb.
Rebel,
maximum
rpm at WOT.
Shannon
repeat.
<g>]
he
use
any
ground
1000
flying.
---[end quote]---
HP.
profile
up front.
Ron
254R
http://n254mr.com
Yeah, it definitely looks like the finer pitch prop runs out of steam at
higher rpms. And if that Bing carbed engine peaks its hp at 2800, that also
would help explain it.
Shannon
Sent: October 21, 2008 9:41 PM
surprise me.
airspeed
cruise
cruise
RPM,
correlation,
loads,
i.e., climb.
one
Rebel,
maximum
rpm at WOT.
Shannon
repeat.
<g>]
lifter
he
use
any
ground
1000
With
flying.
---[end quote]---
but
HP.
specify
demonstrated
which,
profile
up front.
Ron
254R
http://n254mr.com
Post by Ken » Sun Feb 19, 2012 4:56 pm
200 foot takeoff without a headwind would be VERY impressive indeed with
a 64" prop. I figure I'm making perhaps a tad over 120 hp but I'd
estimate at least twice that distance with 20 gal. fuel, a 72" prop, and
mid 70's OAT. My engine is likely 200+ lb heavier.
Our speeds are in the same ballpark but I normally cruise slower for
fuel savings. My climb seems better at easily a 1000 fpm. despite the
weight, which makes me wonder how accurate our respective takeoff
distance numbers are. Doesn't matter though as we both get off the
ground pretty darn quick. It takes a slow speed over the fence, serious
braking, and bravery to stop in that distance ;) ...
any
ground
flying.
---[end quote]---
