[rebel-builders] 360 Prop
Post by Craig Walls » Sun Feb 19, 2012 4:00 pm
Pardon my ignorance, Drew, but why is running at full throttle straight and
level at low altitudes hard on an engine?
Dalgleish
Sent: Monday, October 08, 2007 9:50 AM
Subject: RE: [rebel-builders] 360 Prop
At 06:27 AM 10/8/2007 -0700, you wrote:
Just another question on the speed, Drew. Have you done a full power run at
low altitudes and what was the rpm and speed? At 8000, that would be your
max cruise speed, since your engine can't do more than 75% power at that
altitude.
Sorry Walter I haven't and I probably won't. To me running at full throttle
straight and level at low altitudes is too hard on the engine.
Bill Maxwell
Post by Bill Maxwell » Sun Feb 19, 2012 4:00 pm
I would be interested in learning more about this company and the
relationship to NSI in particular. Dont want the family name dragged into
disrepute unnecessarily but ...........
Bill
Sent: Monday, October 08, 2007 8:39 AM
Subject: Re: [rebel-builders] 360 Prop
G'day Everyone ! ...
I just took a look at the "Maxwell site" .... (engine / propulsion
systems) .....
I gotta say - it looks j....u....s.....t.... like the OLD N.S.I. setup
... that went belly up & took a lot of people's money with them
NSI still owes a good friend of mine a complete firewall fwd package ....
and he's STILL waiting for it ..... years later ... and he's out of
pocket $20,000 U.S. PLUS ... :o(
Biggus
541R
Sent: Monday, October 08, 2007 4:09 AM
Hi Walter !
My concern with RPM & harmonic problems was not with just
the prop - Sensenich may be very happy, but I've seen videos of
the crankshaft in a 360 at rpm between 1900 & 2450 .....
It can really flex !!! I'm also surprised that they say 2500 rpm
gives almost full power -- they are rated at 180 hp @ 2,700 rpm.
We've been towing gliders with 360's in Super Cubs for many
years - one of the challenges is proper cooling on descent -
you need to keep the power up so it cools slowly. The problem
is - you can't come back gradually on the power - only a few
seconds allowed between 2450 and 1900 .... run it there
continuously, and you'll break the crank !
Robin & I both found that the 360's ran noticeably rougher
at & below 2500 - I usually used 2550 as minimum cruise -
Robin preferred 2650+ !!
The previous owner of the Rebel Garry is talking about
wrote several observations - they should be in the archives.
I recall he said something to the effect that the Prince
gave him 2500 on takeoff, 2500 on climb, and 2550 wot,
straight & level ... The whole idea is that it twists with
load, giving "almost constant speed". The one I test flew
certainly did that, although it was too fine overall for
the 196 hp !! It would happily buzz through 3,000 rpm
if the speed went over about 85 in climb !!! Pierre then
went up 4" in pitch - a bit too much the other way, unfortunately ....
The Prince weighs only 9 lb..... !!!! :-)
There are over 30 Rebels flying with them - surely
somebody will jump in ...
http://www.prosumers.ca
On Sunday 07 October 2007 13:54, Walter Klatt wrote:
I expect a little more than 180 hp with my new XP360 as well. It is
using
mostly Superior components, but will have the ECI cylinders. Supposedly
these flow a little more as well, and with EI on one side.
As for the solid crank 360, Sensenich clearly specifies that there are
no
rpm restrictions, so that is what I was going by with my statement.
http://www2.sensenich.com/direct/murphy.htm
I agree that the Sensenich props are heavy, at 40 pounds, and if I can
find
a lighter one that will hold up to water operations, and perform as
well,
I'm definitely interested.
I have heard you guys talk about the Prince, but I need more numbers to
help with my assessment. Again, what I need to know first is take-off
or
static rpm, climb rpm, and then WOT straight and level rpm. And it has
be a Rebel or Elite floatplane.
Bob
Patterson
Sent: Saturday, October 06, 2007 9:25 PM
Gee Walter !!
If you're going for a 360, why not pop for a Prince prop ??
It'll save you over 20 lb. on the nose - a very good thing !!!
(It will be an odd number - like maybe 76 x 46 .... )
I'm not sure about the solid crank helping with the
harmonic ranges - those are strong power pulses ....
but the Prince should be a lot better at avoiding problems.
Pierre used an XP-360 that was polished, ported, and,
most importantly, balanced - it dyno'd at 196 hp !!
Showed over 2,200 fpm climb with the Prince ..... :-))
Tom Anderson
Post by Tom Anderson » Sun Feb 19, 2012 4:00 pm
NSI was run by Lance Wheeler. Creditor (Maxwell) took it over, dissolved
NSI and is running company under new name - Maxwell Propulsion Systems.
Nice looking firewall forward package - but I think I'd compare Eggenfellner
also - when considering a Subaru auto-conversion engine.
http://www.eggenfellneraircraft.com/
Ram Performance in Ohio is also another potential for Subaru engine. I
think he knows a little more about the EA-81 than Maxwell or Eggenfellner -
both of whom are only doing the larger 'legacy' engines.
http://www.ramengines.com/
Tom Anderson
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Bill
Maxwell
Sent: Monday, October 08, 2007 7:08 PM
Bill
systems) .....
Biggus
541R
Hi Walter !
using
no
find
well,
or
Bob
Patterson
Gee Walter !!
Jean Poirier
Post by Jean Poirier » Sun Feb 19, 2012 4:00 pm
There is also Stratus, a long time runner!
http://www.stratus2000.homestead.com/
Jean Poirier
Pr
Post by Drew Dalgleish » Sun Feb 19, 2012 4:00 pm
My prop is optimized for best climb and at full throttle the engine will
over rev.
Dalgleish
altitude.
Bill Maxwell
Thanks Tom. must have been one of the wealthier Maxwells, or maybe no
longer if he got caught up badly in NSI ....
Bill
Sent: Tuesday, October 09, 2007 6:43 PM
Eggenfellner
Eggenfellner -
Tom Anderson
Maxwell
Bill
systems) .....
Biggus
541R
Hi Walter !
using
Supposedly
no
find
well,
or
Bob
Patterson
Gee Walter !!
