[rebel-builders] vortex generators
Bob Palmer
[rebel-builders] Vortex Generators
Post by Bob Palmer » Sun Feb 19, 2012 8:58 pm
See Pacific Northwest Aero <cid:part1.08000301.00080409@shaw.ca>
pre-tested kits for Murphy products. They really do include everything
you need including an instructional CD. I noticed that they increased
the density of the VG's over the aileron area which seems like a good
idea. Haven't tried them yet though.
Bob
Darryl Conway wrote:
Another source would be Pacific Aero Northwest. Their VG's are aluminum and have the template for exact layout for full wing, stabilizer, and vertical fin. I installed them before first flight, so I have no comparison otherwise. The cost was about $250-275, included everything needed for prep and installation. My Moose can be flown really slow, it's just too bad I can't land the thing as slow as it will fly due to the high angle of attack.
Darryl
________________________________
Sent: Sun, January 17, 2010 9:25:53 AM
Subject: RE: [rebel-builders] Vortex Generators
I have the landshorter ones. When I did my testing back with the old 320 on
amphibs, my float take-offs were affected and my stall was lowered. I also
did full speed test runs before and after, and there was zero difference.
Later, I also noticed improved control on crosswind take-offs from my bay
during high wind conditions.
The only drawback is that I have broke a couple in front of my fuel fillers,
when filling from containers. I should never have put any there. The
aluminum ones probably would have just been flattened.
Mine are at the 10% position. Haven't tried them on the stabs, but based on
Eric's experience, might be very beneficial for the Rebel, too.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of craig
Sent: Saturday, January 16, 2010 8:11 PM
Subject: [rebel-builders] Vortex Generators
Someone please refresh my memory....which brand of VG's are we using on the
rebel? Source? Thanks, Craig
Checked by AVG - www.avg.com
Version: 9.0.725 / Virus Database: 270.14.146/2627 - Release Date: 01/16/10 11:35:00
Bob Palmer
I meant to provide a link but that didn't work.
Pacific Northwest Aero = http://www.pnwaero.com/murphy.htm
Bob
Darryl
Version: 9.0.725 / Virus Database: 270.14.147/2628 - Release Date: 01/16/10 23:35:00
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 8:58 pm
Bob, I gather you have a PNWA VG kit for the Rebel. Where are they
recommending placement along the MAC, i.e., how far behind the leading edge?
Ron
Bob Palmer wrote:
See Pacific Northwest Aero <cid:part1.08000301.00080409@shaw.ca<cid%3Apart1.08000301.00080409@shaw.ca>
Bob
Bob Palmer
Ron,
Mine are for an Elite. I am not sure if they are exactly the same but
they likely are. As I recall the leading edge of the VG is positioned
5-5/8" aft of the wing leading edge. My son put them on and he said that
he was glad we have flush riveting otherwise he would have had to shift
them slightly or rout out a few of the rivet heads into the VG.
Bob
Ron
Bob
Version: 9.0.725 / Virus Database: 270.14.148/2629 - Release Date: 01/17/10 11:35:00
Ron Shannon
Thanks, Bob. That would put them at essentially 10% MAC (6"). With
identical airfoils, the Rebel/Elite distinction shouldn't make a difference.
I am tempted to put the outboard 1/4 of the VG's further forward, as Micro
Aero suggests for all, with the rest of the inboard ones where yours are,
presumably achieving some of the desirable washout effect, while minimizing
cruise drag -- if Land Shorter, et al., are correct about placement further
aft. I've seen Super Cubs and Husky's with that kind of split / offset
layout.
Ron
254R
On Mon, Jan 18, 2010 at 8:17 AM, Bob Palmer <rtpalmer@shaw.ca> wrote:
Ron,
Bob
edge?
Ron
Bob Palmer
Ron,
As I mentioned in the first post, PNWA increases the number of VGs in
the aileron area which seems aimed at achieving the same thing.
Bob.
layout.
Ron
254R
Ron Shannon
Understood. Thanks.
Ron
254R
On Mon, Jan 18, 2010 at 10:15 AM, Bob Palmer <rtpalmer@shaw.ca> wrote:
Ron,
Bob.
Miller, Ross W
Post by Miller, Ross W » Sun Feb 19, 2012 9:24 pm
Has anyone put Vortex Generators on their Moose, and are there any documented performance data to support the results?
Ross 203SR
Ross.miller@gdit.com
Curtis Langholz
[rebel-builders] Vortex generators
Post by Curtis Langholz » Sun Feb 19, 2012 9:24 pm
My friend Chuck -176R (225PC) has VG's on his Rebel. He got them from Micro Aerodynamics in Aberdeen, Washington. With both of us in this Rebel it stalled at 36 mph with no power it was settling with a little nose high attitude. Solo he said with flapserons and no power it settles to the runway around 30 mph. I beleive they were about half the price of certified aircraft VG's. They also used my Cessna 120 for the STC on their VG's. It lowered my stall speed 6 mph with full aileron control in a stall. It gave it about 25 - 30% better aileron control. They will be going on my Rebel after I get her flying!
Curtis
175R
Subject: [rebel-builders] Vortex generators
Date: Wed, 9 Jun 2010 13:08:06 -0500
I think I posted this info some time ago - but maybe not. I put VG's on my SR-2500 (wings & horizontal stab) some months ago and found they made a remarkable difference. Prior to install, I found that I could run out of elevator during 3 point landings unless there was an aft cg. Power off stalls are practically a non-event. It simply will finally show a 500-700 fpm descent with no fall off on a wing. With power or flaps there is a break, but little fall off of a wing. Ailerons are actually somewhat effective even in a full stall. Seems to make ailerons more effective during normal flight, also.
I used the Hall Brothers VG's (double posted verticals) which are considerably less expensive than some others. They (on wings) are installed in the 10% - 12% of chord range (actually behind a stringer rivet line at about 11.2%). I experimented with several different placements and found that it is not as critical as some have stated. Very easy to install with the supplied epoxy or with the type used for granite counter tops. I believe it would take dynamite to get one off.
Only adverse effect (if you want to call it that) is that unless on speed for landings, it really tends to float - won't stall!
Charlie Starr - N96CS
Hotmail has tools for the New Busy. Search, chat and e-mail from your inbox.
http://www.windowslive.com/campaign/the ... P:042010_1
Miller, Ross W
Thanks Curtis. The responses I've received have all been positive and I am definitely going to put them on my Moose when I get to that stage.
To: REBEL BUILDERS <rebel-builders@dcsol.com>
Sent: Thu Jun 10 10:01:30 2010
Subject: RE: [rebel-builders] Vortex generators
Curtis
175R
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 9:24 pm
Curtis,
Thanks for this report. I also have the Micro Aero VG's, though not
installed yet. Can you tell us where Chuck's are installed, i.e., behind the
first rivet line (~2.5% MAC) or behind the second rivet line (~10% MAC)?
Micro Aero is rather firm about recommending the more forward location for
their VG's the Rebel. They wouldn't budge on that even after I quoted other
placement opinions and results posted on this list a few months back, and it
would be interesting to confirm whether Chuck followed their placement
instructions or not.
Thanks.
Ron
254R
On Thu, Jun 10, 2010 at 7:01 AM, Curtis Langholz <c120pilot@hotmail.com>wrote:
Curtis
175R
Jones, Michael
Post by Jones, Michael » Sun Feb 19, 2012 9:24 pm
What about vortex generators if you have the stol kit from angus, anyone
tried ??
Mike#007
Ron Shannon
Sent: June 10, 2010 11:57 AM
Subject: Re: [rebel-builders] Vortex generators
Curtis,
for
other
and it
Thanks.
Ron
254R
Rebel it
high
runway
It
gave
Rebel
Curtis
175R
Curtis Langholz
Ron,
I beleive he followed their pattern behind the first rivet line. I called him and he is going to send a picture to me.
What kind of results to others get with different placement of the VG's? On my Cessna 120 they were close to the leading edge also but were smaller in size then the ones for the Rebels. After having them on the 120 I plan on putting them on any other plane I own. They really made it a safer plane to land due to the full aileron control in a stall without getting into a spin, even trying to in cross control stall it would not drop a wing.
Curtis
175R
Date: Thu, 10 Jun 2010 08:56:53 -0700
Curtis,
Thanks.
Ron
254R
Curtis
175R
The New Busy is not the old busy. Search, chat and e-mail from your inbox.
http://www.windowslive.com/campaign/the ... P:042010_3
Curtis Langholz
Ross,
Your welcome! I'm new to this site and am very thankfull for the answers and pictures I have gotten from the other Rebel guys!! Thanks to everyone!
Curtis
175R
Date: Thu, 10 Jun 2010 10:11:53 -0400
Curtis
175R
The New Busy is not the too busy. Combine all your e-mail accounts with Hotmail.
http://www.windowslive.com/campaign/the ... P:042010_4
Ron Shannon
Thanks.
The performance changes with VG's have been discussed frequently here,
including a lengthy thread just a few months ago. If you search the message
archives for "VG" you'll get a bushel full of data and opinions, on all
brands and placements.
Ron
254R
On Thu, Jun 10, 2010 at 3:19 PM, Curtis Langholz <c120pilot@hotmail.com>wrote:
Ron,
Curtis
175R
