Scott 3200 Tailwheel
Scott 3200 tailwheel
Post by Bob Patterson » Sat Feb 18, 2012 2:01 pm
Thanks Ian !!
Didn't know there were cars with composite springs -
another possible source !! :-)
Small world !! That Stits Flutter-Bug flew in to Brampton for
one of our last BBQ's of the season ! We were wondering why he
chose such short gear legs - now we know.... They appeared to be
a bit tooooo flexible, as there were extra braces added to stop
movement, and the legs were tied across under the fuse, as well.
Thanks for the link - an interesting site !
On Tuesday 11 October 2005 06:05 am, IAN DONALDSON wrote:
G'day Bob
I asked a question re the fibreglass springs on the rec.ultralight group
got the following answers.
My 1993 Buick Regal has a rear spring made of composite. Might get one
these and cut it down. Buick has over 130,000 miles without the rear
spring
giving problems.
Chevy Astro van has composite real leaf springs. Probably get 'em nearly
free at a junk yard.
There's a Stits SA6b that has composite leaf springs off an Astro van as
gear legs. Pictures are here:
http://1000aircraftphotos.com/Contributions/1050A.htm
Unfortunately there are none of these vehicles here in Australia.
I also did a Google search and there is a manufacturer in Canada!
regards
Ian Donaldson
Dave Ricker
Post by Dave Ricker » Sat Feb 18, 2012 2:01 pm
The Corvette also has (had?) a transverse composite leaf in the rear
.......although I doubt you'd find one for free in the junkyard ;o)
Bob Patterson wrote:
Thanks Ian !!
G'day Bob
spring
giving problems.
regards
Ian Donaldson
David A. Ricker
Fall River, Nova Scotia
Canada
rickhm
Post by rickhm » Sat Feb 18, 2012 2:01 pm
I was told by a mechanic that my 1995 Chevy S10 pickup has carbon composite springs. If this is true I am sure there are plenty of these in the junk yard.
Rick Muller
SR70
Thanks Ian !!
G'day Bob
regards
Ian Donaldson
David A. Ricker
Canada
IAN DONALDSON
Post by IAN DONALDSON » Sat Feb 18, 2012 2:01 pm
G'day Bob
I had to go and get the manual to refresh my memory and there certainly is a
"bathtub" fitting on the Fus-49.
However the tail spring is held in place between the TS-1 bolts with
multiple pieces of aluminum. Is this still satisfactory or has someone made
a tidier way of fitting this all together.
regards
Ian Donaldson
Ian..would suspect U already have the 2 piece motor mount style fitting in
the tail. The early Rebels had a multi layer of alum strap that held the
bolt and no bath tub fitting attached to the Fus-49.
IAN DONALDSON
G'day Ken
It bothers me that the horizontal stabiliser braces and the tail spring
attachment is just all cobbled together and held in place with 1/4" bolts.
If one of those let go it would cause an interesting moment or two.
I do regularly check the alum angle to make sure that it is not cracking,
but I would be happier with a beefier setup.
But having said that I have not heard of one going wrong!
I have managed to shim it so that there is no side play at all so I guess
that it will be OK.
regards
Ian Donaldson
FWIW the Rebels that I've seen still all have those multiple pieces back
at the TS-1 location. Occasionally I see one that has replaced the
aluminum angle (the TS-3 bottom piece) with a steel angle. (I think
Angus had a crack appear in his alumium piece??) As long as there is no
up down or sideways free play, I think you are fine.
Rick Harper
Post by Rick Harper » Sat Feb 18, 2012 2:01 pm
G'day Ian ...
The 1/4" bolt would still be there AFTER the tail / stabiliser was ripped off !
(Although I did replace the angle aluminium bracket with stainless steel)
Rick
541R
Sent: Monday, October 17, 2005 4:48 PM
Subject: Scott 3200 tailwheel
G'day Ken
that it will be OK.
regards
Ian Donaldson
Post by Ken » Sat Feb 18, 2012 2:01 pm
Hi Ian
IIRC (If I Remember Correctly)
I believe that mine were originally 3/16" bolts but I upgraded to the
current 1/4" bolts.
Thought that might make you feel better ;)
G'day Ken
that it will be OK.
regards
Ian Donaldson
IAN DONALDSON
G'day Ken
Just a little better!
regards
Ian
Hi Ian
current 1/4" bolts.
IAN DONALDSON
G'day Rick
I'm glad that we can now both receive emails again!
I guess that the bolts are strong enough, but it just concerns me a little.
I like your idea of stainless steel, but that is not without it's own
problems.
How is the repair going on your Rebel? Making any progress?
Regards
Ian
ripped off !
Rick
541R
Rick Harper
G'day Ian ....
Repairs are going very slowly :o(
I can only get out to the plane on my days off (it's an hours drive to get there)
I reckon 6 to 12 months :o(
I just got my parts I needed from Julius in Canada ( THANKS !!! )
Onward & upward !
Rick
541R
Sent: Monday, October 17, 2005 10:12 PM
Subject: Re: Scott 3200 tailwheel
G'day Rick
problems.
Regards
Ian
ripped off !
Rick
541R
british thunder
Post by british thunder » Sat Feb 18, 2012 2:01 pm
has any one had any experience with the matco 8" pneumatic tail wheel?
thinking of changing the original.
This will be my first tine in a tail dragger.
I know most people recommend the Scott 3200. Just looking for input on the
Matco, seems more reasonably priced.
thanks
Cec
014R
Sent: Friday, October 07, 2005 10:46 PM
Subject: Scott 3200 Tailwheel
Some of you may already have this info, but it was news to me so I thought
I'd pass it along just in case anyone else is interested...
I've been contemplating the purchase of a new or used Scott 3200 tailwheel
after reading the discussions in this forum. I contacted WagAero this
morning
and was told the Scott 3200 was no longer available. Not just out of
stock,
but no longer available.
I contacted Chief Aircraft and was told that the manufacturer of the Scott
tailwheels had sold the company (overseas I think), and that Alaska
Bushwheel, Inc. ( http://www.akbushwheel.com ) was now producing a look
alike
Scott 3200. According to Chief Aircraft, Alaska Bushwheel has been
producing
most of the parts for the original Scott 3200 tailwheel anyway, so when
original company was sold, Alaska Bushwheel began manufacture. They are
also
making a 'Tundra' conversion kit which includes a larger, wider fork with
larger, wider tire for the Scott 3200. They have pictures at
http://www.akbushwheel.com/3200TundraTailwheel.html
Chief Aircraft ( http://www.chiefaircraft.com ) is selling the Alaska
Bushwheel Scott 3200 look alike for $938.50. They call it the model ABI
3224A
and it comes with the heavy duty steering arm. Parts are supposed to be
interchangeable between the original Scott 3200's and the Alaska Bushwheel
version.
Aircraft Spruce is advertising the Scott 3200 for $1281.00 USD. A used
Scott
3200 just sold on Ebay for $676.66 USD.
Anyone have any positive/negative experience with Alaska Bushwheel
products
or the company?
Just FYI
Roger Hoffman #687R
Eugene, OR USA!
steve whitenect
Post by steve whitenect » Sat Feb 18, 2012 2:01 pm
Broke the steering pin on mine and returned it. Ken B got rid of his also.
Both installed on tandum aircraft which are a bit harder on the tail.
Steve W.
From: "british thunder" <britishthunder@sympatico.ca>
Subject: Re: Scott 3200 Tailwheel
Date: Tue, 18 Oct 2005 09:01:18 -0500
thanks
Cec
014R
thought
tailwheel
morning
stock,
Scott
alike
producing
also
with
3224A
Bushwheel
version.
Scott
products
or the company?
Just FYI
Roger Hoffman #687R
Eugene, OR USA!
Ian Donaldson
Post by Ian Donaldson » Sun Feb 19, 2012 10:47 am
G'day
I have just fitted a Scott 3200 tailwheel to my 912 Rebel and I am pleased
to say that the difference is amazing.
The ride and the general handling is greatly improved and even the oil
canning noises that she made is reduced.
I have noticed that I need a little more nose down trim so I guess the extra
3 pounds at the back have made a difference, but things work out OK with the
weight and balance.
Anyone want to buy a used rebel tailwheel? Cheap!
regards
Ian
