tool kit from mam
tool kit from mam
Post by Walter Klatt » Fri Feb 17, 2012 11:51 pm
Well, if you want a real cheap, ie zero cost, tool to
knock out mandrels, here's what I do. I just take an
old mandrel stem from a pulled rivet, snip it to about
1/2 inch long, and hold it in a vise grip wrench with
about 1/8 inch sticking out one end. Then simply stick
that in your rivet mandrel hole and tap the other end
with a hammer, and it's done.
The one problem I haven't figured out, though, is how
do you prevent unwanted dimpling of skin on the head
side when the mandrel is in real tight with epoxy and
you can't get at the backside of the rivet to support
it.
[mailto:mike.davis@dcsol.com]
Sent: Thursday, September 25, 2003 3:56 PM
Subject: Re: tool kit from mam
Guess we didn't offer enough detail... I
just supposed that everyone knew we
only intended our list of tools to be used
to knock out the mandrel, then
drill the head of and remove the rest of the
rivet as you described below.
But you've certainly covered it beyond question now.
Sent: Thursday, September 25, 2003 2:46 PM
Subject: RE: tool kit from mam
Ok.....hate to say it but I haven't read
one good answer yet...but then
again I guess it all boils down to
whatever works for you.
First off...and words cannot impress upon
you, that whenever a rivet is to
be removed that the utmost diligence must
be taken so that the existing
hole
is not deteriorated or "oversized".
All of the above mentioned methods lead me
to believe that the hole will
be
deformed unless you get lucky. The
prescribed method ( and one that I
have
used for 25plus years) is to use the same
sized drill as was used to
originally install the rivet. In this case
...a #30.....and if you are
worried. then a spring drill stop set to
just below rivet head
depth.....will work. In the case of Avex
Rivets as well as Cherry- Max (
which are unbelievably hard on Cobalt
drills) it also help to use an
automatic centre punch on the stem just to
make sure it is "Knocked Out"
just below skin depth. the proceed to
drill in the centre until the
"Head"
of the rivet pops off. You should be left
with a rivet donut on your drill
bit.
As far as the remaining shank of the
rivet...it can be easily be removed
with either a pair of pliers or by using
the same automatic centre punch
as
you used to knock the stem down.
If the material ( I.e.: skin) is deformed
at all, ( as in sorta looks like
it has been dimpled) you can use a plastic
hammer on a good solid surface
hammer it flat and back into the round
hole shape....in the case of a
dimpled skin it is better to hammer the
round hole back first and then
re-dimple it...making sure that the hole
is not oversize first.
Paul
Terry Dazey
Sent: September 25, 2003 3:08 PM
Rebelers:
Wanna go one better? Take a concrete nail
(the shank is not quite 3/16
inch)
and grind 3/8 to 1/2 inch from the tip so
it looks like a small drift pin
punch (3/32?? constant diameter tip). Make
one for the 3/16 inch rivets
too.
Light, small and cheap. About .02 cents U.S.
Chuck Bailey gave me one FREE! Now, that's cheap.
Have fun building.
Terry Dazey
Rebel 662
Sumner, Washington U.S.A.
I followed Mike Kimball's example and
just got a small awl... put the
point
into the rivet and give it a tap with a
hammer, and out comes the
mandrel.
I think I paid about $3 for the one I got.
Archives located at
Incoming mail is certified Virus Free.
Checked by AVG anti-virus system
(http://www.grisoft.com).
Version: 6.0.521 / Virus Database: 319 - Release
Date: 23/09/2003
Outgoing mail is certified Virus Free.
Date: 23/09/2003
Archives located at
Archives located at
Paul Chamberlin
tool kit from mam
Post by Paul Chamberlin » Fri Feb 17, 2012 11:51 pm
Ok.....hate to say it but I haven't read one good answer yet...but then
again I guess it all boils down to whatever works for you.
First off...and words cannot impress upon you, that whenever a rivet is to
be removed that the utmost diligence must be taken so that the existing hole
All of the above mentioned methods lead me to believe that the hole will be
deformed unless you get lucky. The prescribed method ( and one that I have
used for 25plus years) is to use the same sized drill as was used to
originally install the rivet. In this case ...a #30.....and if you are
worried. then a spring drill stop set to just below rivet head
depth.....will work. In the case of Avex Rivets as well as Cherry- Max (
which are unbelievably hard on Cobalt drills) it also help to use an
automatic centre punch on the stem just to make sure it is "Knocked Out" to
just below skin depth. the proceed to drill in the centre until the "Head"
of the rivet pops off. You should be left with a rivet donut on your drill
bit.
As far as the remaining shank of the rivet...it can be easily be removed
with either a pair of pliers or by using the same automatic centre punch as
If the material ( I.e.: skin) is deformed at all, ( as in sorta looks like
it has been dimpled) you can use a plastic hammer on a good solid surface to
hammer it flat and back into the round hole shape....in the case of a
dimpled skin it is better to hammer the round hole back first and then
re-dimple it...making sure that the hole is not oversize first.
Paul
Terry Dazey
Rebelers:
Wanna go one better? Take a concrete nail (the shank is not quite 3/16 inch)
and grind 3/8 to 1/2 inch from the tip so it looks like a small drift pin
punch (3/32?? constant diameter tip). Make one for the 3/16 inch rivets too.
Have fun building.
Terry Dazey
Rebel 662
I followed Mike Kimball's example and just got a small awl... put the
point
into the rivet and give it a tap with a hammer, and out comes the mandrel.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.521 / Virus Database: 319 - Release Date: 23/09/2003
Paul Chamberlin
tool kit from mam
sorry to add this part but we always used to judge good "metal bashers" by
not so much how they could put something together but as to how they could
take something apart and then rework it back to origianl specs!
Paul
Terry Dazey
Rebelers:
Have fun building.
Terry Dazey
Rebel 662
point
tool kit from mam
Post by Drew Dalgleish » Fri Feb 17, 2012 11:51 pm
it.
Hi Walter
The way I get those rivets out is to drill the head til I hit the top of
the mandrel then I use a wood chisel to cut the top of whats left of the
head off. Then I can pound out the shank as described by Paul.
tool kit from mam
Yes, that's basically what I have been doing. If the
mandrel doesn't go easily, drill off the head. Usually,
it softens things up enough then, so that a little tap
after that causes the whole thing to go.
Certainly beats the old days before I learned to knock
out the mandrel first. There was many a hole I screwed
up, and had to go to the next rivet size up.
Thanks Drew. I'm always looking for a better way if
there is one.
Sent: Thursday, September 25, 2003 7:31 PM
though, is how
epoxy and
to support
it.
Hi Walter
described by Paul.
cribe.wcx
Archives located at
