[rebel-builders] Dynalfocal mount installation
steve whitenect
Post by steve whitenect » Sun Feb 19, 2012 4:10 pm
I have no idea Walter. I think they have different angles but what they are, you'll have to research a bit further. I thought u purchased a new engine? They shud be able to tell u what to look for if it's a reman.
Steve W
Discover new ways to stay in touch with Windows Live! Visit the City @ Live today!
http://getyourliveid.ca/?icid=LIVEIDENCA006
Post by Bob Patterson » Sun Feb 19, 2012 4:10 pm
The angles on the engine tabs are different - they supposedly
focus on the center of the engine, reducing vibration more.
I was thinking of asking the same question, as our gliding
club got one of those. It was a real pain, meant re-welding the
engine mount and adding adapters, which pushed the engine
forward another couple of inches !! I definitely wouldn't
want one of those, given the hassle involved !
http://www.prosumers.ca
On Tuesday 04 December 2007 00:35, Walter Klatt wrote:
How can I tell what is a type #2?
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of steve
whitenect
Sent: December 3, 2007 4:30 PM
Subject: RE: [rebel-builders] Dynalfocal mount installation
Hi Walter
You didn't by chance get one of the rare #2 type dynafocal engines trying
ot fit it to a type 1 mount? Just a thought!......
Steve W> Date: Mon, 3 Dec 2007 12:15:27 -0800> From: Walter.Klatt@shaw.ca>
Subject: Re: RE: [rebel-builders] Dynalfocal mount installation> To:
rebel-builders@dcsol.com> > Thanks, any and all tips welcome, the more the
merrier. With all the tough things I have done with building and servicing
my Rebel, I can't believe the challenge with this one, especially when
others say it was a piece of cake for them.> > Speaking of tough jobs, I
still remember a year ago, when I changed my O-rings in my amphib main gear
cylinder without removing it, and just working through the cap hole at the
top. Other than a few skinned knuckles, that was easy compared to getting
this dynafocal mount installed to the engine.> > Walter> > ----- Original
steve whitenect
The type 1 intercepts the crankshaft at 30* and the type 2 at 18*. Ran a search and it seems that the type two is more common with the 0-320's. U shud be able to see if the angle is different by 12*.
Steve W
Use fowl language with Chicktionary. Click here to start playing!
http://puzzles.sympatico.msn.ca/chickti ... id=htmlsig
Dale Fultz
Post by Dale Fultz » Sun Feb 19, 2012 4:11 pm
Walter what is the number on the mounts I can tell you which is which then I
have both types of mounts .. The wrong ones will have a larger hole in the
middle also.. that is the easiest way to tell them apart.. Dale
Dale Fultz
The mounts are interchangeable if you have the wrong ones they can be
unbolted and acquire the right ones.. Dale
Post by Walter Klatt » Sun Feb 19, 2012 4:11 pm
I am quite sure I have the type 1 as that is what was ordered on the engine,
and I didn't notice the angle to be different when I was trying to fit them.
My problem was that after getting two holes to fit, I couldn't get the
others to go.
I think I may make myself a tapered pin that was mentioned and use it to
find the hole and tap the bolt in behind it.
Fultz
Sent: December 3, 2007 6:34 PM
Subject: Re: [rebel-builders] Dynalfocal mount installation
Richard Wampach
Post by Richard Wampach » Sun Feb 19, 2012 4:11 pm
I ran into that problem on My SR-3500, the O-540- engine has the
removable lugs bolted to the engine case. Murphy steel mounts for that
series of engine uses the 30* angle. The rubbers fit onto the engine
lugs, and the whole assembly (eng & Lord rubber mounts) slides back to
the steel Murphy mount, and the bolts slip in easily. The 30* aims all
4 lugs to about the center of a 6 cylinder engine, between # 3, & # 4
cyls. The 18* mount aims at the crankshaft flange on a 6 cylinder
engine.
As I remember. On the O-320, O-360 the rubbers straddle the ears on the
steel mount, and bolts up to the fixed lugs on the engine--- is any of
that clear?? I'm not sure what I just said is what I thought I was
saying. Perhaps a picture would help us know what is causing your
hardship. Can you send us one of your mount and eng lugs?
Dick W.
Dale Fultz
Sent: Monday, December 03, 2007 6:34 PM
I have the 94150-40 barry mounts and they seem to fit the MAM engine mount
just fine.
Fultz
Sent: December 3, 2007 6:19 PM
Ronald Shannon
Post by Ronald Shannon » Sun Feb 19, 2012 4:11 pm
FWIW, with my Jabiru, I put the mount on the engine first. To get the mount
on the engine, I first had to make one end of a large "G" clamp "skinny" by
knocking the head off the screw end. That headless end was then used to hold
a socket inside the mount, which in turn held the bolt tight inside the
mount, i.e., forward. The other end of the clamp goes on the front side
mount washer, pulling the rubbers together enough to get a nut on the
forward end of the bolt. I may have some pictures. Let me know if you'd like
them.
Don't know whether this technique might apply to your situation, but it
might give you an idea.
engine,
them.
others to go.
Yeah, send me a pic offline, and all ideas are welcome. Thanks.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Ronald
Shannon
Sent: December 3, 2007 7:53 PM
them.
engine,
them.
others to go.
kpierson
Post by kpierson » Sun Feb 19, 2012 4:11 pm
Walter: I have an IO-320 with a type #2 mount, most,
but not all, were IO series engines. the best way to tell
the difference is if the ears on your engine are machined
out flat then it is a type #1 mount. The ears on a type
#2 engine are bored out on an 18 degree angle,the depth
of the hole is aproximetly 1/4 inch.
All dynalfocal engine mount holes are pointed at an imaginary
focal point inside the engine, weather it be 18 , or 30 degrees.
On 12/3/2007 7:04 PM, walter.klatt@shaw.ca wrote to rebel-builders:
-> Yeah, send me a pic offline, and all ideas are welcome. Thanks.
-> Walter
-> -----Original Message-----
Ronald
-> Shannon
-> Sent: December 3, 2007 7:53 PM
-> Subject: Re: [rebel-builders] Dynalfocal mount installation
-> FWIW, with my Jabiru, I put the mount on the engine first. To get the
mount
-> on the engine, I first had to make one end of a large "G" clamp "skinny" by
-> knocking the head off the screw end. That headless end was then used to
hold
-> a socket inside the mount, which in turn held the bolt tight inside the
-> mount, i.e., forward. The other end of the clamp goes on the front side
-> mount washer, pulling the rubbers together enough to get a nut on the
-> forward end of the bolt. I may have some pictures. Let me know if you'd
like
-> them.
-> Don't know whether this technique might apply to your situation, but it
-> might give you an idea.
-> On 12/3/07, Walter Klatt <Walter.Klatt@shaw.ca> wrote:
-> > I am quite sure I have the type 1 as that is what was ordered on the
-> > engine,
-> > and I didn't notice the angle to be different when I was trying to fit
-> > them.
-> > My problem was that after getting two holes to fit, I couldn't get the
-> > others to go.
-> > I think I may make myself a tapered pin that was mentioned and use it to
-> > find the hole and tap the bolt in behind it.
-> > Walter
-> List archives located at: https://mail.dcsol.com/login
kpierson
Weather, whether. I must have been thinking of the outside
tempture, it's about 18 degrees hear.
On 12/3/2007 9:27 PM, kpierson wrote to walter.klatt@shaw.ca:
-> Walter: I have an IO-320 with a type #2 mount, most,
-> but not all, were IO series engines. the best way to tell
-> the difference is if the ears on your engine are machined
-> out flat then it is a type #1 mount. The ears on a type
-> #2 engine are bored out on an 18 degree angle,the depth
-> of the hole is aproximetly 1/4 inch.
-> All dynalfocal engine mount holes are pointed at an imaginary
-> focal point inside the engine, weather it be 18 , or 30 degrees.
-> On 12/3/2007 7:04 PM, walter.klatt@shaw.ca wrote to rebel-builders:
-> -> Yeah, send me a pic offline, and all ideas are welcome. Thanks.
-> -> Walter
-> -> -----Original Message-----
-> -> From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf
Of
-> Ronald
-> -> Shannon
-> -> Sent: December 3, 2007 7:53 PM
-> -> To: rebel-builders@dcsol.com
-> -> Subject: Re: [rebel-builders] Dynalfocal mount installation
-> -> FWIW, with my Jabiru, I put the mount on the engine first. To get the
-> mount
-> -> on the engine, I first had to make one end of a large "G" clamp "skinny"
by
-> -> knocking the head off the screw end. That headless end was then used
-> hold
-> -> a socket inside the mount, which in turn held the bolt tight inside the
-> -> mount, i.e., forward. The other end of the clamp goes on the front side
-> -> mount washer, pulling the rubbers together enough to get a nut on the
-> -> forward end of the bolt. I may have some pictures. Let me know if
you'd
-> like
-> -> them.
-> -> Don't know whether this technique might apply to your situation, but it
-> -> might give you an idea.
-> -> On 12/3/07, Walter Klatt <Walter.Klatt@shaw.ca> wrote:
-> -> > I am quite sure I have the type 1 as that is what was ordered on the
-> -> > engine,
-> -> > and I didn't notice the angle to be different when I was trying to fit
-> -> > them.
-> -> > My problem was that after getting two holes to fit, I couldn't get the
-> -> > others to go.
-> -> > I think I may make myself a tapered pin that was mentioned and use
it to
-> -> > find the hole and tap the bolt in behind it.
-> -> > Walter
-> -> List archives located at: https://mail.dcsol.com/login
-> -> username "rebel" password "builder"
-> -> Unsubscribe: rebel-builders-unsubscribe@dcsol.com
-> -> List administrator: mike.davis@dcsol.com
bransom
Post by bransom » Sun Feb 19, 2012 4:11 pm
Walter,
I helped my brother change the rubber bushings on his Grumman a couple
years ago. He had the tapered pins. We got good at it by the 4th hole and
just a modest amount of cussin. I recall getting some of the pins or bolts
in, bottom ones first I think, then lifting the engine so that it tilted
back from the bottom mounts and pressed into the top bushings. I winced a
bit when lifting brought the front wheel off the ground, but of course that
was really not too big a deal. Just need to move things around with a bit
of fine tuning on the amount of lift till the next hole lines up. Probably
way easier with an assistant.
-Ben
Shannon
them.
engine,
them.
others to go.
WALTER KLATT
Post by WALTER KLATT » Sun Feb 19, 2012 4:11 pm
Well, I'm glad to hear that I am not the only one that had to resort to extra means (like the tapered pins) to install these dynafocal mounts. Now I have to figure out how to evenly grind a bolt down to a tapered tip. I don't want uneven edges to gouge the hole on the engine. Or is it possible to buy a tapered 7/16 pin, and just cut it down to the right length?
Date: Tuesday, December 4, 2007 3:07 pm
Walter,
the pins or bolts
it tilted
course that
up. Probably
-Ben
Behalf Of Ronald
Shannon
get the mount
clamp "skinny" by
then used to hold
inside the
front side
on the
if you'd like
them.
situation, but it
ordered on the
engine,
trying to fit
them.
couldn't get the
others to go.
and use it to
Post by Wayne G. O'Shea » Sun Feb 19, 2012 4:11 pm
Walter... I'll go see what I have in the hangar. Have a few trays of taper
pins.
Sent: Tuesday, December 04, 2007 6:36 PM
Walter,
the pins or bolts
it tilted
course that
up. Probably
-Ben
Behalf Of Ronald
Shannon
get the mount
clamp "skinny" by
then used to hold
inside the
front side
on the
if you'd like
them.
situation, but it
ordered on the
trying to fit
couldn't get the
and use it to
