[rebel-builders] Fuel Leak
Alan Hepburn
Post by Alan Hepburn » Sun Feb 19, 2012 9:23 pm
Thanks, Walter. The leak is internal - none of the visible rivets or seams
is leaking. As I said, I think I'll get this summer out of it, then decide
whether to take the wing off and get serious about fixing it.
Al
Klatt
Sent: Thursday, May 27, 2010 7:03 PM
Subject: RE: [rebel-builders] Fuel Leak
The other place it might leak out of, if you used the standard 1410 rivets,
is through the rivet mandrels. I had a couple weeping on me shortly after it
was new, and it was on the top of the tank near the rear, and only when
filled right to the top with fuel, sitting in my hangar for a few days. I
used a small dab of Seal-all on the outside each rivet head that had weeping
(about 3 or 4) and has been good for the last 10 years.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Alan
Hepburn
Sent: Thursday, May 27, 2010 2:50 PM
At 66, I didn't have the nerve to ask the girl in the store where they keep
these!
G. O'Shea
Sent: Thursday, May 27, 2010 5:43 PM
Subject: Re: [rebel-builders] Fuel Leak
Yes it does Al. I 've seen many tanks that are great until totally full.
That is usually the upper forward stringer leaking. With you on amphibs you
sit pretty level.. so you get almost 1/2 tank or so before the fuel is up to
the top of the rear tank bulkhead. If it leaches when you start leaving it
at about 3/4 tank, I would suspect a leak thru one of the rib flange to rear
bulkhead areas (at the top of course). Always find it seems to be an easy
spot to miss getting enough gooo into when building and have fixed a fair
number of those. That one is easily fixed by what I described yesterday by
pulling he lower skin out of the way to work. Scuff 'till the cows come home
around ALL the ribs/skins/bulkhead out at least an inch onto every surface
and then spread PRC/Proseal/Sealpack onto the COMPLETE perimeter to build a
dam. Saves tearing into the inside of the tank for weepers.
Remember when you are blowing up tanks to check for leaks.... You put enough
PSI in there to blow up the balloon and it stays there for a few hours. Next
time grab a condom.. less prone to any air escaping thru the pores and the
lubricant helps with the seal on the filler neck (you need to retain with an
elastic before inflating). Blow it up to look like a water tower and leave
it for a couple DAYS. Temperature and barometric changes should make it
disappear into the tank on a cool morning and then blow back up through the
day. You know you have a perfect tank when it actually creates enough vacuum
to inflate that condom inside the tank! I use a well pressure tank snifter
valve (ie like a valve stem) threaded into one port with the others plugged
or the outlet valve shut off. Then I just fill it with the air compressor
until that condom looks like a fancy water tower!
Sent: Thursday, May 27, 2010 5:15 PM
Wayne/Gary:
Before I got into major surgery, I decided to get an idea of the size of
this leak, so I'd know how long to test it before I decided it was fixed.
put a balloon on the inlet, blew it up as hard as I could with lung power,
and let it sit. It's been there for four hours with no visible change in
the balloon, so we're not talking about a big leak - certainly nothing
light
would shine through.
Now, thinking about it, the only time I noted the leak was when the
airplane
was in the hangar over the winter. The tank was full. So perhaps (a) the
leak is at the top of the tank, and (b) it's so small that in warm weather
the gas evaporates before it becomes visible. It's even possible that the
leak has always been there, but is small enough that the balloon test does
not detect it over 24 hours.
So I'm starting to re-think this thing. My idea is to operate the
airplane
over the summer as is. The season is short enough, for sure. I'll use
time to try to characterise the leak. I'll start by filling the tank half
way, and see if there's any sign of a leak. I'll then add gas in 5 gallon
steps, and see if and when the leak shows up. If it is near the top of
tank, I may even live with it, by only filling the tank immediately before
flight, and running off the leaky side for the first hour.
At the end of the season, I can take the wing off and work on it over the
winter in a heated area, if I decide that it's troublesome enough to be
worth the bother.
Does this make sense?
Al
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Gary
Gustafson
Sent: Thursday, May 27, 2010 4:26 PM
I did use a 50/50 mixture of toluene and MEK. I did slosh MEK inside
first and let it dry for several days. The Proseal/MEK/toluene mixture
was a bit thicker than engine oil but not by much. It flowed slowly. I
used a small cup on a rod to transport a bit of the mixture to each
section and had the wing tilted so that when I poured the mixture would
land just above the rear J panel. Once I sealed the opening in the rib
next to the fuselage, I applied 4 PSI to the inside of the tank (measured
with a water menometer for about 5 hours. I do not know how long it
will last as I did not scuff up the areas where the leak(s) were
occurring.
However, I would listen to Wayne as he has had much more experience than
my one patch. Mine did not leak much and I could see no light from the
outside when a small LED flashlight was inserted on a rod. My wing tanks
passed the pressure test (glove inflated for 24 hours) but have now
developed weeping leaks that take a day to notice. I have noticed that
the doors initially opened and closed easily and now stick or are hard
to close. Which leads me to wondering if the plane 'settles' or moves
slightly as it is broken in. The other thing is that I wonder if the
leaks in the tanks could have developed via thermal expansion and
contraction here in the hot Florida sun.
Hepburn
Sent: Wednesday, May 26, 2010 8:58 PM
Thanks for this. I have no visible leaks, so I figure it must be
somewhere
on the rear bulkheads. I had thought about putting an access plate in the
root rib as you describe, but I'm wondering why you wouldn't just stand
wing trailing edge down and pour about a pint of diluted Proseal through a
tube towards the rear bulkheads, then move the tip up and down and the
leading edge backwards and forwards. Then pump off the excess Proseal and
ventilate it to evapourate the excess solvent. I'd also planned to use
some
gentle pressure to try to force the stuff into the leak. How long did it
take the Proseal to cure? Did you use the same 50:50 toluene:MEK mix, and
how thin did you make the sealant? I'm thinking about like engine oil.
I'm
told you should rinse the tank thoroughly with MEK first.
This leak appeared after about 4 years in service. I've tried looking for
it
with a flexible inspection camera through one of the flap hinge access
covers, but can't be sure of having seen the source.
Al Hepburn
Gustafson
Sent: Wednesday, May 26, 2010 7:31 PM
I would go with Proseal diluted with 50/50 solution. It is a heck of a
job to de-rivet. What I did was cut a hole into the rib next to the
wing, made a cover along with two doublers to cover the hole, then
poured the diluted Proseal mixture near the rear spar in each section
and tilted the upside down wing at an angle so that te Proseal would
run down to the trailing edge where the spar and skin come to gather
while alternating lifting the wing tip and the fuselage end of the wing
to ensure an even flow. I then Prosealed both doublers and riveted
them in place, then Prosealed around the cover plate and riveted it
in place. No leaks from the top trailing edge or the access plate
that I riveted in. However, after about 2 weeks of flying the top
outside edge near the filler cap started to weep (gradually seep out
over a 24/48 hour period). I mention this as one might put the diluted
Proseal all around the top edge of the tank.
Good luck
Hepburn
Sent: Wednesday, May 26, 2010 7:03 PM
Subject: [rebel-builders] Fuel Leak
Well, I just got back from playing ring around the volcano on a
Transatlantic trip. Delivered four airplanes (not Murphies) safely to
Paris
on schedule. So no I'm trying to figure whether to slosh my leaky tank
with
Proseal diluted with 50:50 toluene/MEK, or de-rivet the rear lower skin at
the TE and try to localize the leak. What would you do?
Al
G. O'Shea
Sent: Wednesday, May 26, 2010 5:27 PM
Subject: Re: [rebel-builders] Rebel / Elite - Dipstick clearance on
Dynafocal mounts
Hey Al !!! Where the hell ya been??? ;O)
Sent: Wednesday, May 26, 2010 4:46 PM
Subject: RE: [rebel-builders] Rebel / Elite - Dipstick clearance on
Dynafocal mounts
My mount was wrong and Murphy replaced it - but that's about 5 years ago.
Al Hepburn
G. O'Shea
Sent: Tuesday, March 23, 2010 11:45 PM
Subject: [rebel-builders] Rebel / Elite - Dipstick clearance on Dynafocal
mounts
Someone asked if it was a common issue that his dipstick tube was hitting
the mount a while back....
.. .. so while bolting up the latest (O-320-E2D) engine installation
today,
I took a picture after everything was tightened up.
This has been the typical clearance on every Dynafocal engine I've
mounted
to a Murphy made mount. About 3/16 to 1/4"....so not sure why the fella
had/has issues.
http://www.irishfield.on.ca/gallery/dip ... omount.jpg
N.Smith
Post by N.Smith » Sun Feb 19, 2012 9:23 pm
Hi All
With the Murphy 1800 amphib's and the supplied hydraulic reservoir for the
gear system, would anyone know how much the level changes in the reservoir
as the gear is pumped up and down ?
Just trying to avoid overfilling and it leaking all over the floor while I'm
merrily pumping away :-)
Nig
745E
jbcressman
Post by jbcressman » Sun Feb 19, 2012 9:23 pm
Nig...I have mine filled to within 1 inch from completely full and never have had a problem. Bob 331R
Sent: Mon, Jun 7, 2010 1:41 pm
Hi All
Nig
745E
wright.garry30
Post by wright.garry30 » Sun Feb 19, 2012 9:23 pm
Should stay level as return same. As outflow.
------Original Message------
Sender: mike.davis@dcsol.com
ReplyTo: rebel-builders@dcsol.com
Sent: Jun 7, 2010 11:41
Hi All
Nig
745E
Post by Wayne G. O'Shea » Sun Feb 19, 2012 9:23 pm
It varies about 3/4" Nigel (of course depending on which container you
have).. because the rod side of the cylinders (gear up) has less internal
volume than the gear down side.
Sent: Monday, June 07, 2010 3:35 PM
Hi All
I'm
Nig
745E
