[rebel-builders] Fuel lines
Dale Fultz
Post by Dale Fultz » Sun Feb 19, 2012 2:04 pm
On all factory planes the gascolator is the lowest point for dirt and water
to be trapped and extracted. Dale SR-033
[rebel-builders] Fuel Lines
Post by Ken » Sun Feb 19, 2012 8:29 pm
I believe you are referring to soft coiled aluminum tubing which should
be just fine AFAIK. The straight lengths sometimes look a little better
in places that are visible. I believe 6061 straight lengths were the
cheapest local stuff around my part of the world last time I looked.
David L. Tuck wrote:
Does it matter if I use what is called versatube? for fuel line in the rebel? or do I use the 5052 3/8's ridged?
Dave T
mike jones
Post by mike jones » Sun Feb 19, 2012 8:29 pm
Where did you fint this fuel line ken, I need little bit and cant find any
cheers
Sent: Monday, August 24, 2009 9:51 PM
Subject: Re: [rebel-builders] Fuel Lines
Dave T
It was one of the Metal Supermarket stores. Aircraft Spruce probably has
the 5052 and versatube in stock as well. I think they have dramatically
increased their stock in Brantford now.
cheers
Dave T
