mike#007
Brian Breathnach
Sent: Tuesday, October 25, 2005 1:05 PM
Subject: Re: Everbrite
Good Morning Bob
OK, got it--thanx
Brian
Sent: Wednesday, October 26, 2005 9:50 AM
shearHi Brian !
I think this product is meant as a paint primer, for large
surfaces. The beauty of Everbrite is that it's CLEAR - perfect
if you want a shiny aluminum float, or airplane.
Nothing beats the Polyfiber Epoxy Primer for bonding
pieces together !
.......bobp
On Tuesday 25 October 2005 12:14 pm, Brian Breathnach wrote:Hi Al,
Interesting product.
Would you know if the product has the same (or better) adhesive and
thansheets?performance as the chrommate based primers when applied between alummakeAnyone out there use it yet?
Thanx
Brian
779R
Sent: Sunday, October 23, 2005 8:08 PM
Al
You might want to check this stuff out:
http://www.pantheonchemical.com/PreKote.htm
I probably heard of it here but the test reports by the military/labspreventingit sound like a no-brainer for an adhesion promoting & corrosiontreatment. The military test report they quote make it sound better
badlengthalodine not to mention it has no hazmat issues.called Everbrite as a possibility for use on floats. It sounds reallyDave
Alan Hepburn wrote:
interesting. Who was the person who had tried it, and what size of a
project has he used it on? It seems that eurethane may not be the best
choice for floats if the airplane is going to be in the water for anyof time, as it tends to form bubbles. Even if this Everbrite proves a
doesn'tchoice, there doesn't seem to be too much to loose, as long as it
actually cause corrosion, as it can be removed with acetone.
