you haven't built it yet, then do the cutting before you put it together.
The one thing is, the spades are rather long and narrow when you're done,
and while they still have good strength for vertical loads, they're not not
so strong when subjected to lateral loads. By now, you're probably
thinking "He found that out the hard way", and you're right. I caught the
tip of the spade on the basement door when I was taking it to the hangar -
and instant crimped spade. And it didn't take much of a bump. It bent just
in front of the outboard end of the spar. The problem was solved by
re-skinning the spade, but the the doublers I suggested will hopefully
prevent a recurrence if somebody walks into the stab when it's on the ramp.
'Cause of the spade is bent, it will foul the horizontal stab, and that
could be unpleasant.
BTW, you can guarantee correct alignment of the spade when you're building
it by clecoing the ribs through the 3/16" tooling holes to a nice straight,
stiff piece of aluminum angle.
Al
Sent: Thursday, February 03, 2005 5:39 PM
Subject: Re: Shortening Elite elevator
andI'm planning on doing this mod this weekend. Robin says it's a good idea
thehe is hoping some info will be available in a couple weeks, sounds like
Anyway,info is coming from Sean?? was getting it to Robin on what he done?
theAl seems to have the direction, just set your table saw fence to 3-11/16"
and run each side through, and your done..........
What is the best way to cut the skin off with out making a mess? Snips?
Cutoff wheel? I'm pretty early in this project and don't have all the
sheetmetal skills down yet. Does the doubler you added seem necessary?
Mike Betti
771E
Sent: Tuesday, February 01, 2005 6:38 AM
theNo, you chop the span off the outboard edge of the spade, then re-locateoriginal tip ribs. Be sure to take care to maintain the alignment of
havespade or it can wind up twisted. Come to think of it, if you already
you,alignmentthe spade built, it would be a good idea to cleco the suggested 6" patch
that spans the roots of the ribs so you don't have to worry aboutniceso much. I'm going over to the shop tonight to work on the retracts, so
will try to get a couple of pix.
I don't recommend you do it this way, but it's just as if you put the
elevator in a table saw and lopped about 3 11/16" off each end!
Al Hepburn
Sent: Sunday, January 30, 2005 7:34 PM
I'm in the middle of building my elevator right now. It sure would beto hear how this thread comes out before I finish. If I understand
elevatorwon't this create a 3" space between the stab main spar and the
threeandwhetherbalance? Is the space filled in?
Mike Betti
E771
Sent: Sunday, January 30, 2005 5:29 PM
Subject: Shortening Elite elevator
Robintoit
in
thoughtorderI
