Didn't you know... we changed over way back in 1977! I remember because I was in junior high at the time and everybody was required to learn metrics because of the change.
Sent: Friday, October 04, 2002 3:59 AM
Subject: Re: Rotax 912 oil cooler
G'day Chuck
Now that's a really nice program.
I have found that 240F = 115C!
Just when are the Americas going to change to metrics?
Regards
Ian----- Original Message -----
Sent: Friday, October 04, 2002 1:30 AM
Lan,
I use a program called Convert that will convert almost everthing I need. Freeware from:
http://www.joshmadison.com/software/convert/
Chuck Bailey
Rebel 176
N225PC
Send and receive Hotmail on your mobile device: Click HereFrom: "Ian Donaldson"
Reply-To:
Date: Thu, 3 Oct 2002 21:56:39 +1000
G'day again Bruce
I have learned that there is a larger size cooler available and I will investigate that.
Unfortunately here in Australia we are thoroughly metricated and I have forgotten how to convert Fahrenheit to Celsius and I don't know just how hot 220F is !
Ian,
My 912S on a 100F summer day in climb out may hit oil temps 220F. Normally I can't get it hot enough to burn off the condensation. I left it 1/3 taped off all summer. The cooler came stock with Skystar fire wall forward package. It's an Earl cooler with dimensions about 3" high and 9" long. It sets right up front in the inlet so it gets lots of cooling air. I would examine the amount of air getting to your cooler. Good luck.
*-------------------------------------------------------------------------* To unsubscribe go to http://www.dcsol.com:81/public/listserv.htm Archives located at http://rebel:builder@www.dcsol.com:81/default.htm To contact the list admin, e-mail mike.davis@dcsol.com *-------------------------------------------------------------------------*
