Rebel Bungee Gear
Rebel bungee gear
Post by Mike Kimball » Fri Feb 17, 2012 10:42 pm
Tire pressure sure made a huge difference with my Renegade Spirit! The
tires were designed for 15 psi, but if I put 15 psi in them I would always
bounce my landings. I let them down to 5 psi and my landings were smooth as
glass from then on. Never had any problems with tires rotating on the rims.
Of course, a Renegade takes off and lands very slow. Probably more of a
problem the faster the airplane is.
SR #044
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com]On Behalf Of Bob
Patterson
Sent: Wednesday, January 15, 2003 8:09 AM
Subject: Re: Rebel bungee gear
Hi Ian !
The piece of string sounds like a good solution ! Rebel
builders are inventive !! ;-)
The only caution with low 'tyre' pressure is - if it's too
low, the tires can rotate, pulling the tube, and possibly yank the
filler stem off !! (voice of sad experience ...) :-(
It could just be that your landings are sooooo smoooooth that
the bungies don't have to move ! ;-^) :-)
You're right about the bungies being simple, light, and
strong - just like the Rebel. Guess that's why they were chosen ! :-)
Glad you're enjoying the Rebel - one of these years I'll
have one set up like yours, with the 912-S. My 'hot rod' O-320 is fun,
but, as I age, I'll want something a lot less 'thirsty'.... ;-)
-----------------------------orig.---------------------------------
At 12:10 AM 1/16/03 +1100, you wrote:
G'day Bob
Thanks for the reply.
The tyres (tires) that I have are something like 15x6. They are the
standard
MAM issue ,and I do run low pressure in them, but I will let them down to
12/14 as you suggest.
I never considered that it would wear the gear out if the bungies are
loose. But it seems to me that there is no give in them at all.
I have been trying to think of a way to see if the bungies do move, and it
suddenly occurred to me that all I need to do is tie a string with some
slack in it between the bungie bolts. Then when I do a few landings I could
check if the string has broken. Hows that for an idea.?
The die spring suspension seems a good thing, but the bungies are cheap,
light and simple.
Thanks again and regards
Ian Donaldson
Rick Harper
Rebel bungee gear
Post by Rick Harper » Fri Feb 17, 2012 10:43 pm
G'day Bob ....
Glad to have you "down here" ... when & if " you can come ...
I've been doing some Luthier work for a company that imports a lot of
Canadian built guitars .. and last week the manager of the firm said
that he might send me to Canada to talk with the manufacturing people
direct .... so I said ... BY THE WEST COAST THANKS !!! :-)
So you never know, I might just beat you to the punch ! :-)
Rick & Wendy
541R
Sent: Thursday, January 16, 2003 4:18 AM
Hi Rick !
Thanks to Roger, you've got the contact details....
I have a set of Gord's bushings on my Rebel, to compliment
Wayne's die spring gear legs, and they are very nicely done. The cost
shouldn't be toooo painful, given that our Canuck Buck is close to
par with yours !
Sounds like you're really enjoying your Rebel !! I sure
would like to come down there & fly along on one of your trips -
they sound a lot more 'exciting' than the Rambles !! ;-)
You sure fly over some rough country ! Maybe one of these years
Anna & I will come for one of those 'spam can' fly-yourself tours
of OZ - sure sounds like a GREAT vacation !!
-------------------------------orig.--------------------------------
At 04:11 PM 1/15/03 +1100, you wrote:
G'day Bob !
Can you give me contact details for Gordon Mohr ?!? ... I have die
springs on Rebel 541R .... and the ride / landings are GREAT - Soft &
Smooth ...But, obviously the gear "works" up & down a fair bit ....
I've
toyed with the idea of making my own bushes ,... but if Gordon's are
tried & proven, I'll drop him a line.
PS Done nearly 200 hrs (and about 500 landings) in 18 months so far
and the next 4 months will see another 50 to 70 hours on the VDO !
all looks good so far :-)
Flying from Sydney to Perth & back in late April (same distance as
coast
to coast in Canada or the US )
Rick & Wendy Harper
541R
Sent: Wednesday, January 15, 2003 6:50 AM
Hi Ian !
I recall Darryl Murphy saying that the bungee gear is only
supposed to move to prevent structural damage to the fuselage. The
tires are the main shock absorbers - that's why I like the fat DICO
or CARLYLE tires so much !! :-) These are available from
Murphy,
at about half the cost of the skinnier 'aircraft' tires, and are
well suited to a 912 Rebel !
Do not slacken them up so the gear moves when taxying - if
the gear moves a lot, you will wear through the tops of the gear
legs very quickly. Gord Mohr makes a beautiful set of fitting to
go into the tops of the gear legs, with brass bushings inserted,
to prevent this wear - and they are essential if you go to a
die-spring setup to replace the bungees. The die-spring gear (IF
springs are carefully selected for rate & load) will give you
THE best ride in a Rebel. The Cessna-style spring gear tends to
"waddle", but the die spring gear just gives a great, smooth ride -
but everything is moving all the time, so lubrication & bushings
are essential.
Best suggestion for now - use the fat tires, and lower the
air pressure a bit (they work great at 12-14 lb.)......
....bobp
---------------------------------orig.----------------------------------
At 11:38 PM 1/14/03 +1100, you wrote:
G'day
I have a Rebel with a 100hp Rotax, and it is fitted with the
standard
bungee gear.
Well not really standard as I have fitted 8 of the 9044 factory
made
bungee
rings.
Now my problem is that it appears that the legs do not move at
all.
No
matter how I load the plane, or in fact jump around inside, the
legs
just
don't move.
What experience do others have? How many rings is enough? Should
legs
move while taxying?
I look forward to hearing your responses.
Regards
Ian Donaldson
PS the temperature here where I live in Australia is currently
37o.
That's
centigrade!
Archives located at
Archives located at
Archives located at
Ian Donaldson
Rebel bungee gear
Post by Ian Donaldson » Fri Feb 17, 2012 10:43 pm
G'day Bob
Hi Ian !
That's all that I ccould think of to see if the bungees had any movement at
all.
I will give it a try next weekend and I will let you know what occurs.
Been there done that!
Not really.! I have had every style possible. Greasers to the ten foot drop!
I have been surprised that IU have never broken anything. A real tough set
up.
I'm happy enough. With no spats and no strut fairings it goes at 80 knots at
18.5 liters an hour.
regards
Ian Donaldson
G'day Bob
standard
it
could
light and simple.
Ian Donaldson
Ian Donaldson
Rebel bungee gear
G'day Mike
I will try lower pressures and see what happens.
Regards
Ian
as
rims.
Gordon Mohr
Rebel bungee gear
Post by Gordon Mohr » Fri Feb 17, 2012 10:43 pm
What are the odds of someone named HARPER ending up being a luthier? :-)
At 04:07 PM 16/01/03 +1100, you wrote:
G'day Bob ....
Rebel bungee gear
Post by Bob Patterson » Fri Feb 17, 2012 10:43 pm
Hey - that would be GREAT !!! Hope we can meet up at Arlington !!
----------------------------------orig.-----------------------------------
At 04:07 PM 1/16/03 +1100, you wrote:
G'day Bob ....
Rick & Wendy
541R
Hi Rick !
par with yours !
G'day Bob !
I've
coast
Rick & Wendy Harper
541R
Hi Ian !
Murphy,
are essential.
....bobp
G'day
standard
bungee gear.
made
bungee
rings.
all.
No
legs
just
don't move.
legs
move while taxying?
Regards
Ian Donaldson
37o.
That's
centigrade!
Archives located at
Archives located at
Archives located at
