Couple questions.
Couple questions.
Post by Bob Patterson » Fri Feb 17, 2012 9:21 pm
Hi Keith !
Welllll - you almost get that effect with the standard window
setup ! It's a large window, and swings down out of the way, leaving
an opening that's plenty large enough to jump out of if you've just
flipped on your back in the water ! and, of course, you can fly
with it open, for that beezy feeling !
....bobp
------------------------------------orig.-------------------------------
At 09:21 AM 10/29/01 -0500, you wrote:
I have been thinking about a set of doors much like a J-3 Cub
Ideas----Comments ???
Keith Oliver
Elite #654 TD
N654ME (reserved)
Farmingdale, Maine
Sent: Monday, October 29, 2001 9:12 AM
Subject: Re: Couple questions.
Hi Joel !
The gull-wing doors are supposed to be better for seaplane
operations - although some experienced float pilots say not, because
they'd be harder to open if inverted in the water.....
manual,
Keith Oliver
Couple questions.
Post by Keith Oliver » Fri Feb 17, 2012 9:21 pm
I was thinking it would be somewhat like the clamshell for float ops
Also would get rid of door sag
Keith Oliver
Elite #654 TD
N654ME (reserved)
Farmingdale, Maine
Sent: Monday, October 29, 2001 10:29 AM
Subject: RE: Couple questions.
Hi Keith !
....bobp
Keith Oliver
Elite #654 TD
N654ME (reserved)
Farmingdale, Maine
Hi Joel !
overlap
beautifully
manual,
Couple questions.
Never had a problem with door sag ! The thing I didn't like
about the clamshell - and the swing-up doors - is that the top piece
always ends up hitting my head, or just being in the way when you
don't want it. The latches never seem to hold them, or you have to
fiddle too much to keep them up. ...... but - it's YOUR Rebel and
YOUR choice !! That's what makes homebuilding so popular - you can
have it YOUR WAY !!! :-)
Keith Oliver
Elite #654 TD
N654ME (reserved)
Farmingdale, Maine
Hi Keith !
....bobp
Keith Oliver
Elite #654 TD
N654ME (reserved)
Farmingdale, Maine
Hi Joel !
overlap
beautifully
Legeorgen
Couple questions.
Post by Legeorgen » Fri Feb 17, 2012 9:21 pm
Hi Bob,
Thanks for the comments on the prop spacer. I had to chuckle when I read your
comments on the "narrowing seat phenomenon" with lexan doors. I can attest,
It's true!!! I often end up stuffing my jacked between the sear and lexan on
long trips with my Kitfox.
I left the aluminum on the Rebel doors.
Bruce G
Couple questions.
Post by Walter Klatt » Fri Feb 17, 2012 9:21 pm
Bob, I assume you are talking about the regular Rebel windows here. I did
not think that you could fly with them open. When I run mine up on the
ground past about 1200 or so, they come out of the latch and flop up. Based
on that, I didn't think that they would stay down in flight?
Also, is it OK to fly the Rebel with the doors completely off?
....bobp
Couple questions.
Post by Mike Davis » Fri Feb 17, 2012 9:21 pm
The original factory video showed Robin open the window in flight, seemed to
stay down just fine.
Sent: Tuesday, October 30, 2001 6:01 AM
Based
....bobp
Drew and Jan
Couple questions.
Post by Drew and Jan » Fri Feb 17, 2012 9:21 pm
I've flown lots of times with my windows open. The plane cruises just fine
but when I slow for landing the window shakes like crazy. I just make sure
I close the window while on downwind
....bobp
Couple questions.
Hi Walter !
It certainly IS OK to fly with the doors off - but VERY breezy !
The windows WILL stay open in flight, but are sensitive to angle of
attack. The latches will NOT hold them open in the fully down position -
but they WILL float at about a 45 degree angle down, and this is a
perfectly safe way to keep cool when you're flying low on those
really hot days. Surprisingly, you'll be able to unfold and read a
map inside, even with the windows open ! We usually just open one
at a time ... Excellent for photography - that's why the Rebels
are in high demand at airshows !!
I always close the windows for takeoff and landing, because,
if the angle of attack changes, or there's a gust, they will SLAM
closed, and can pinch your elbow if it's hanging over the hinge !! :-)
---------------------------------orig.---------------------------------
....bobp
Rebflyer
Couple questions.
Post by Rebflyer » Fri Feb 17, 2012 9:21 pm
Hi Keith,
My only comment to that is you will be amazed at the time it will take to "invent" your doors. Fly or Build. But isn't that what building your own is all about? Keep at it, it's worth it. Curt N97MR
Keith Oliver
Couple questions.
I hear ya
Keith Oliver
Elite #654 TD
N654ME (reserved)
Farmingdale, Maine
Rebflyer@aol.com
Sent: Tuesday, October 30, 2001 5:43 PM
Hi Keith,
Couple questions.
So, what you guys are telling me is that I've been sweating my @#%$s off for
two summers now for nothing?!! OK, I will have to try opening a window in
flight, although this time of year I am more likely to get frost bite in
these parts.
Sounds like maybe this open window might also serve as a backup to the
airspeed indicator if it varies its position based on speed and angle of
attack. One of my hangar neighbours this summer had a wasp invade his pitot
tube, and he didn't notice it until after he took off. Needless to say, he
had some anxious moments until he got back on the ground.
Sent: October 30, 2001 10:50 AM
Hi Walter !
flop up. Based
....bobp
with **
itself **
with **
itself **
Charles Dixon
Couple questions.
Post by Charles Dixon » Fri Feb 17, 2012 9:21 pm
Please help me get of the Murphy list
Sent: Tuesday, October 30, 2001 9:10 AM
did
Based
....bobp
LisaFly99
Couple questions.
Post by LisaFly99 » Fri Feb 17, 2012 9:21 pm
In a message dated 11/2/01 2:17:31 PM Central Standard Time, charlesd@crookedhole.com writes:
Couple questions.
Post by Wayne G. O'Shea » Fri Feb 17, 2012 9:21 pm
Charles, before you do drop me a line at oifa@irishfield.on.ca and let me
know where/what you have been up to since your flight to Alaska!!
Sent: Friday, November 02, 2001 3:11 PM
seemed
did
Based
and, of course, you can fly ** To unsubscribe, send e-mail to list-server@dcsol.com with
