[rebel-builders] Holes for Float Pump-outs
Garry Wright
Post by Garry Wright » Mon Feb 20, 2012 2:36 am
I took it all apart and replaced some rather poor workmanship from a guy
who repaired it. Still working on it though leaks wise.
Garry
On Thu, Jan 5, 2012 at 1:10 PM, Walter Klatt <Walter.Klatt@shaw.ca> wrote:
Yeah, that's a lot, mine isn't that bad, yet. I also don't think you should
be adding extra pump-outs for that. Better to drain into the main
compartment through a drilled hole as designed. But with that amount of
leak, you need to fix it, for good.
Garry, weren't you having trouble with a similar leak? Can't remember how
you fixed yours.
I got talked into taking apart my rear main gear cylinders on the floats to
upgrade the O-rings and re-machine the grooves (plus adding a 2nd one) on
the front hydraulic fittings. I had a leak on one a couple years, and fixed
it with a new O-ring. Mine were not actually leaking right now. But Dennis
(the machinist) decided to do his, and so while he had his CNC programmed
and set up to do them, I decided to take advantage of the opportunity.
Luckily, the weather has been warm, as it is not fun working through those
access covers to take apart your cylinders. Anyway, got them back together
yesterday, so now just have to get the air worked out of the lines. Will do
that today. And I better not find any leaks now....
And just got my medical yesterday (yahoo, I passed) again, too, so am good
with that for another 2 years.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of John
R. Davidson
Sent: Thursday, January 05, 2012 11:43 AM
To: Rebel List
Subject: RE: [rebel-builders] Holes for Float Pump-outs
Hi Walter,
Sounds similar. Pilots side, outboard of wheelwell. Will take on ~2 gallons
overnight. Must be at the very bottom of the float because all the water
drains if left on land. There is evidence of several previous attempts at
fixing, but I think, as you suspect that the gear "works" it a bit when on
wheels,and re-opens whatever is leaking. Now that I know it has leaked, and
can leak, I'd like to be able to pump out all compartments.
As you recall, I'm quite heavy, and tend to fly "near gross" . I'd rather
have an extra 20 lbs of fuel, than water.
Hope you are well.
John
Date: Thu, 5 Jan 2012 10:57:46 -0800
John, which small compartment is leaking? I have one, too, on the
right float by the main gear. I think it is coming from the gear
attachment bolt.
I have been meaning to put a doubler in there, one of these years, to
strengthen it, as some others here have done. But for now I just let
it drain into my main compartment through the drilled hole. It is not
a big leak, maybe a couple cups in a day sitting on the water. All my
other compartments are still tight.
John R. Davidson
Sent: Thursday, January 05, 2012 8:36 AM
To: Rebel List
Wayne, you are 100% right...I should solve the leak problem. But
better men than I have tried, and failed, or at least it came back.
Eventually the compartment will be filled with pro-seal or whatever the
sealant-du-jour is.
Some future industrial archeologist will be able to document the
trends in sealant evolution on the basis of my one small compartment.
It is only the one that leaks.
In the meantime, I want to be able to pump them out and be sure.
As mentioned in the previous post, they can be set up to drain into
neighbouring compartments, but that allows a small leak in a small
compartment to flood a big compartment. Not ideal either.
Thanks for the input.
John
Subject: Re: [rebel-builders] Holes for Float Pump-outs
Date: Thu, 5 Jan 2012 11:07:50 -0500
As Drew points out.. gonna be a tight place to get a cup and hose up
high
password "builder"
"rebel" password "builder"
password "builder"
Bob Palmer
Post by Bob Palmer » Mon Feb 20, 2012 2:36 am
you fixed yours.
R. Davidson
To: Rebel List
Hi Walter,
Hope you are well.
John
attachment bolt.
John R. Davidson
To: Rebel List
sealant-du-jour is.
John
high
password "builder"
password "builder"
