Rotax 912 oil cooler exit air
LisaFly99
Post by LisaFly99 » Fri Feb 17, 2012 10:28 pm
In a message dated 10/6/02 10:15:24 PM Central Daylight Time, allsure@iprimus.com.au writes:
Is there any general rule of thumb that I could use to work out the ratio of inlet vs outlet dimensions. I have not seen a cowl for a Locoing but the inlets appear similar sizes.
Could the inlets be too big?
IAN
In general I've heard 1.7 exit minimum larger than inlet.
Phil&Lisa Smith
N414D
#460R
Ian Donaldson
Post by Ian Donaldson » Fri Feb 17, 2012 10:28 pm
G'day Phil
That's interesting.
Even after cutting out the bottom of the cowl I don't think that I have approached 1:1
Something more to think about!
Regards
Ian Donaldson
IAN
Phil&Lisa Smith
N414D
#460R
Rick Harper
Post by Rick Harper » Fri Feb 17, 2012 10:28 pm
G'day Ian ...
Tony Bingelis said a ratio of 2:3 ie 100 square inches of inlet & 150 square inches of outlet was a safe rule
Rick & Wendy
Sent: Tuesday, October 08, 2002 12:28 AM
Subject: Re: Rotax 912 oil cooler exit air
In a message dated 10/6/02 10:15:24 PM Central Daylight Time, allsure@iprimus.com.au (allsure@iprimus.com.au) writes:
IAN
Phil&Lisa Smith
N414D
#460R
Ian Donaldson
G'day Rick,Curt & Drew.
Thanks for the information. Armed with those facts I should be able to sort the thing out.
I just wonder whether the formulae apply only to air cooled engines. The Rotax that I am using has water cooled heads and air cooled barrels, and just maybe it does not need as much air flow.
I will try Curt's suggestion and try to tidy up the firewall area to get a smooth exit for the air.
And Curt the Rebel sure is nice to fly!
Regards
Ian Donaldson
G'day Ian ...
Rick & Wendy
N414D
#460R
Post by Drew Dalgleish » Fri Feb 17, 2012 10:28 pm
Hi Ian
Tony was just writing about air cooled engines but I think the formula
should still apply because the total amount of heat to be removed is the same.
At 10:08 PM 10/9/2002 +1000, you wrote:
& Drew. Armed with those facts I should be able to sort the thing
out. has water cooled heads and air cooled barrels, and just maybe it
does not need as much air flow. I will try Curt's suggestion and try to
tidy up the firewall area to get a smooth exit for the air. And Curt the
Rebel sure is nice to fly! Regards Ian Donaldson G'day Ian ...
& 150 square inches of outlet was a safe rule & Wendy
N414D
#460R
Ian Donaldson
G'day Drew
You can see that I never thought things through!
In your last email you suggested that the inlets should be 3" x 6" times
two. Do you think that
that area would include the openings for the oil cooler and water radiator?
What I am trying to establish is to whether I have more entry air than I
need. If the entry area was
reduced there would not be such a problem getting the hot air out.
Regards
Ian Donaldson
Hi Ian
same.
Hi Ian
I'm just passing on what I read in Tony Bingeliss' book. I belive he was
talking about the total area. When I was trying to get more air out of my
cowling I made a lip for the bottom of the cowling with cardboard and duct
tape to see if it would help. Maybe you could temporarily block part of
your inlet to see if it helps. That way you could reduce it a little at a
time to find the optimum size instead of reworking your cowl and finding it
didn't help. Good Luck
At 11:20 PM 10/10/2002 +1000, you wrote:
G'day Drew
Regards
Ian Donaldson
Hi Ian
same.
klehman
Post by klehman » Fri Feb 17, 2012 10:28 pm
Hi Ian
I thought I'd throw a little theory at you. Theory can't hurt when you
don't have a successful model to copy. As always I defer to any pratical
experience that others may offer.
My understanding is that simply reducing the intake area can not
possibly increase cooling unless it is done in such a way to capture
additional air. Air does love to bypass intakes and reverse back out
again, but just reducing the size of the intake is not likely to help
that. The reason for minimizing intake area is to reduce drag. The
guidelines for intake to exhaust area are also intended to minimize
drag.
The longer story is that you can't really force 100mph air through a
radiator. The pressure drop would be much higher than what is available.
The airflow through the core will likely be much less than half that
speed regardless of what the intake and exhaust look like. Therefore one
can aim for a small air intake that opens (gradually if possible) into a
plenum. The air slows in the plenum and the pressure increases. The air
pressure then drops as it flows past the rad. Ideally the air then
converges in another duct where it speeds up again hopefully exiting at
close to ambient pressure and speed.
So you need at least several inches of duct between the intake and the
rad to get any improvement at all (preferably more like a foot or
more). Adding an inch simply won't make any difference.
It sounds like you really only have the exit to play with. Again try to
arrange it so that the air smoothly accelerates without any sharp
corners like at the bottom of the firewall. Exhaust parallel to the
fuselage as much as possible. Exhaust air will not exhaust with any
significant downward velocity unless you have a large high drag lip that
causes many times higher drag than necessary. Even then the exhaust will
be turbulent slow vortices rather than smooth and fast. A cowl that
drops a couple of inches lower than the fuselage bottom is preferable to
a large lip. If you have to have a large lip to make things work you
could try a moveable cowl flap if you want to cruise a few MPH faster.
Drew Dalgleish wrote:
Hi Ian
G'day Drew
Regards
Post by Walter Klatt » Fri Feb 17, 2012 10:28 pm
Is it possible to make your outlet too big, thus
causing turbulence and poorer air flow out the exit?
[mailto:murphy-rebel@dcsol.com]On Behalf Of
klehman
Sent: Friday, October 11, 2002 4:24 PM
Hi Ian
can't hurt when you
area can not
way to capture
reverse back out
likely to help
reduce drag. The
to minimize
drag.
air through a
what is available.
than half that
like. Therefore one
possible) into a
increases. The air
the air then
intake and the
a foot or
difference.
with. Again try to
any sharp
parallel to the
exhaust with any
high drag lip that
the exhaust will
A cowl that
is preferable to
things work you
few MPH faster.
Hi Ian
G'day Drew
the hot air out.
Regards
Archives located at
klehman
Hmmm I don't really know. I can think of some extreme cases (for outlets
and inlets) where I think that is possible. Certainly Hanging a radiator
vertically below the fuselage doesn't work very well because most air
just goes around it. Ducts the size of the rad probably wouldn't help.
But for our purposes and for reasonable sized installations I would
guess that it is mostly just going to create a lot of extra drag. I've
never heard of a situation where too far open cowl flaps reduced
cooling.
klehman
Hi Ian
can't hurt when you
area can not
way to capture
reverse back out
likely to help
reduce drag. The
to minimize
drag.
air through a
what is available.
than half that
like. Therefore one
possible) into a
increases. The air
the air then
intake and the
a foot or
difference.
with. Again try to
any sharp
parallel to the
exhaust with any
high drag lip that
the exhaust will
A cowl that
is preferable to
things work you
few MPH faster.
Hi Ian
G'day Drew
the hot air out.
Ian Donaldson
G'day Ken
That theory did make interesting reading. As you say theory won't hurt!
Now I think that I will go with tidying up the exit and see what difference
that makes.
I just occurred to me that perhaps I could duct some fresh air from the
inlet and have
it blow directly on the oil bottle that is situated at the rear of the cowl.
May help!
Now just if I could just get some off work to get to the hangar......
Regards
Ian Donaldson
Hi Ian
drag.
