Tall Wheel Spring
Mike Davis
Tall Wheel Spring
Post by Mike Davis » Fri Feb 17, 2012 4:52 pm
Received: from the-benson-s (209-122-254-170.s170.tnt1.lnh.md.dialup.rcn.com
[209.122.254.170])
by smtp2.erols.com (8.8.8/8.8.5) with SMTP id TAA20807
for <murphy-rebel@dcsol.com>; Tue, 5 Jan 1999 19:36:50 -0500 (EST)
Message-ID: <004501be390c$22050e20$4bfc7ad1@the-benson-s>
Subject: Re: Tall Wheel Spring
Date: Tue, 5 Jan 1999 19:33:01 -0500
MIME-Version: 1.0
Content-Type: text/plain;
charset="iso-8859-1"
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook Express 4.72.3155.0
X-MimeOLE: Produced By Microsoft MimeOLE V4.72.3155.0
The fiberglass spring is 1 3/4" wide by 18 1/2" long and will fit the Scott
tail wheel. Scott has adapters for narrower springs.
Date: Tuesday, January 05, 1999 7:08 PM
Hi Lonnie
The Tail spring in my kit was an aluminum one(LG30-1) not fiberglass ,,,
seems
I heard that the fiberglass ones broke ??? but not sure about this.
I also plan on using a scott 3200 tail wheel but I dont have it yet so I
dont
know if it will fit on the aluminum spring ( about 1 5/8 width by 5/8
thick
What size is your spring??
Jim JimsRebel@aol.com
Mike Davis
Tall Wheel Spring
Received: from d.james (ba1p3.planeteer.com [204.50.144.36])
by toronto.planeteer.com (8.8.7/8.8.7) with ESMTP id DAA03260
for <murphy-rebel@dcsol.com>; Wed, 6 Jan 1999 03:29:27 GMT
Message-ID: <3692DC66.BBFE2A8B@planeteer.com>
Date: Tue, 05 Jan 1999 22:45:42 -0500
X-Mailer: Mozilla 4.01 [en] (Win95; I)
MIME-Version: 1.0
X-Priority: 3 (Normal)
References: <2d5f72cb.3692a82b@aol.com>
X-Corel-MessageType: EMail
I believe the early kits had aluminum tail springs. After the first few
customer rebels started flying it was found that the aluminum springs
were "straightening out" at the kink. Murophy switched later kits to
the composite spring. I have no heard any complaints about the
composite spring.
David James
Rebel 228
JimsRebel@aol.com wrote:
Hi Lonnie
,,, seems
I dont
5/8 thick
Mike Davis
Tall Wheel Spring
Received: from dialup.voyager.co.nz (ts1p08.net.ashburton.voyager.co.nz
[203.21.25.172]) by host02.net.voyager.co.nz (8.8.8/8.6.12) with ESMTP id
UAA28777 for <murphy-rebel@dcsol.com>; Wed, 6 Jan 1999 20:39:58 +1300 (NZDT)
Message-Id: <199901060739.UAA28777@host02.net.voyager.co.nz>
Date: Wed, 6 Jan 1999 20:40:23 +1300
X-Priority: 3
X-Mailer: Microsoft Internet Mail 4.70.1155
MIME-Version: 1.0
Content-Type: text/plain; charset=ISO-8859-1
Hi There,
I have got the latest aluminum tailwheel spring and the standard Murphy
tail wheel.
The spring is fine, but the Murphy tail wheel is not up to it if you intend
on going into
rougher airstrips, it takes an awful pounding with the solid rubber wheel
and transfers a lot of shocks up the fuse.
On rocky very narrow airstrips I have found that the Murphy supplied
tailwheel struggles to keep the aircraft straight in the final stages of
the landing, it tends to bounce and jump around a lot, I think a pneumatic
tyre on the tailwheel really is essential for this type of work. I have
managed to counter this tendency by keeping the tail high until the last
possible moment on landing on these types of airstrips..
The Scott 3200 tail wheel looks to be a very good choice although it will
tend to lift the tail a little higher for the landing attitude, I am
running the 850-6 tyres on the Rebel now so it wont make too much of a
difference.
Alister Yeoman
Date: Wednesday, January 06, 1999 1:02 PM
Hi Lonnie
seems
dont
thick
Mike Davis
Tall Wheel Spring
Received: from FLYBOY.MSCOMM.COM (annex2002.mscomm.com [208.153.232.11])
by mailserv1.mscomm.com (8.9.1/8.9.1) with SMTP id LAA02873
for <murphy-rebel@dcsol.com>; Wed, 6 Jan 1999 11:33:10 -0800 (PST)
Message-ID: <3693BA44.72D3@mscomm.com>
Date: Wed, 06 Jan 1999 11:32:30 -0800
Reply-To: flyboy@mscomm.com
X-Mailer: Mozilla 3.04Gold (Win95; I)
MIME-Version: 1.0
References: <E0zxkSS-0002PX-00@mail2.toronto.istar.net>
Bob Patterson wrote:
Hi Lonnie !
I'm on my second fibreglass tailspring (in 9 years !). They <do>
break - especially after sitting out in the sun for only 7 or 8 years ...
My old one was badly 'checked', and delaminated in 2 places, so
I finally retired it. I do know of ONE that was broken - by dropping the
Rebel from about 8 or 9 feet after a nose-over incident. The fibreglass
spring broke, and the rudder received a small dent.
I really like the fibreglass springs - they have more 'give', and
absorb more energy, but they are no longer available (the price tripled !)
If you are going to use fibreglass, though, you should SHORTEN it by
about 2" or more - the factory-supplied springs are a little too long
& wiggly. ====
The early aluminum tail springs were too thin, and went FLAT after
a few hours of pounding down the runway - the current versions are MUCH
thicker, so won't have that problem. They are, however, VERY stiff,
and don't provide a lot of shock absorbtion. Generally, they are OK
on HEAVIER Rebels, with heavier tailwheels, as the extra weight helps
bend them. I would still prefer the <shortened> fibreglass spring for
a lighter Rebel, with the Murphy tailwheel.(like my Rotax 912 powered
Rebel).
There is a width problem with either spring, as the Scott has
a wider opening, but there are spacers.
FWIW - the airport lore says:
"Maule tailwheels will develop a bad shimmy very quickly"
I have observed this personally on several aircraft - but maybe they
were just <very old> Maule's ....
-----------------------------orig.------------------------------
Scott
Hi Lonnie
seems
dont
thick
My Maule tail wheel is shimming very bad. Aprox 150 hrs.
If you have not already bought one get a Scott.
Rich bartman
Mike Davis
Tall Wheel Spring
Received: from [137.186.224.143] (helo=ms01-143.tor.istar.ca)
for murphy-rebel@dcsol.com
id 0zy3yH-00053L-00; Wed, 6 Jan 1999 20:10:45 -0500
Mime-Version: 1.0
Message-Id: <E0zy3yH-00053L-00@mail2.toronto.istar.net>
Date: Wed, 6 Jan 1999 20:10:45 -0500
I agree, Alister - the Scott 3200 is probably the best choice.
Scott also make a 2200 pneumatic tailwheel, which is probably a better
size for the Rebel, but they are relatively rare, and cost almost as much
as the 3200. (Parts are likely more common for the 3200 ...)
-------------------------------orig.---------------------------------
At 08:40 PM 1/6/99 +1300, you wrote:
Hi There,
tail wheel.
on going into
difference.
Alister Yeoman
Hi Lonnie
seems
dont
thick
Mike Davis
Tall Wheel Spring
Received: from RebelAir@aol.com
by imo24.mx.aol.com (IMOv18.1) id NZFNa03463
for <murphy-rebel@dcsol.com>; Fri, 8 Jan 1999 23:41:39 +1900 (EST)
Message-ID: <37498c32.3696de03@aol.com>
Date: Fri, 8 Jan 1999 23:41:39 EST
Mime-Version: 1.0
X-Mailer: AOL 3.0.i for Windows 95 sub 19
Hi There
I agree that the Scott 3200 will fit the fiberglas tailspring from MAM.
However, it does NOT fit the aluminium tailspring from MAM so beware.
Brian
Mike Davis
Tall Wheel Spring
by imo29.mx.aol.com (IMOv18.1) id 6QYKa01221
for <murphy-rebel@dcsol.com>; Fri, 8 Jan 1999 23:44:12 +1900 (EST)
Message-ID: <b86c35e0.3696de9c@aol.com>
Date: Fri, 8 Jan 1999 23:44:12 EST
Mime-Version: 1.0
You would have to shim it on each side as the Scott tailwheel is meant for a
1.75" tailspring. You can see information in the Aircraft Spruce catalogue.
They sell the Scott wheel, a number of tailsprings but not the exact size
for
the Scott.
Brian #328R
Mike Davis
Tall Wheel Spring
by imo19.mx.aol.com (IMOv18.1) id GHAMa18627
for <murphy-rebel@dcsol.com>; Fri, 8 Jan 1999 23:46:04 +1900 (EST)
Message-ID: <11b26876.3696df0c@aol.com>
Date: Fri, 8 Jan 1999 23:46:04 EST
Mime-Version: 1.0
Hi
Early, early kits I understand had aluminum tailsprings. Early kits like
mine, (#328), had fiberglas tailsprings. However, I now understand that
less
early kits now have aluminium springs once again.
Brian
Mike Davis
Tall Wheel Spring
Received: from nidlink.com (pm5-24.nidlink.com [216.18.141.31])
by enaila.nidlink.com (8.8.5/8.8.5) with ESMTP id VAA16207
for <murphy-rebel@dcsol.com>; Wed, 13 Jan 1999 21:19:01 -0800 (PST)
Message-ID: <369D7FF0.3F243AA8@nidlink.com>
Date: Wed, 13 Jan 1999 21:26:09 -0800
X-Mailer: Mozilla 4.5 [en] (Win95; I)
X-Accept-Language: en
MIME-Version: 1.0
References: <001401be38f1$1194f0c0$4bfc7ad1@the-benson-s>
Content-Type: multipart/alternative;
boundary="------------61951C844AD1790927FE8AE9"
--------------61951C844AD1790927FE8AE9
Content-Type: text/plain; charset=x-user-defined
Sorry I haven't answered this sooner.
I got the fiberglass spring with my kit. It flew with it and we found
it very "bouncey". The airplane dropped off a ladder while doing a
weight and balance and totally shattered it.
We replace the fiberglss with the older aluminum 6061 tail spring. It
flattened out in a matter of monthes.
We replaced the 6061 spring with the steel two leaf that they offered
for a time. It flattened out over the winter.
We replaced the steel leaf with the new 7075 spring. It has been on two
years now and works with no problems and hasn't flattened one bit.
We are using and have always used the Scott tailwheel.
Keith Kinden made a suggestion at the very beginning that I think is
valid. The wheel must be paralell with the ground to avoid chatter and
wild manuevers. The aluminum spring can just be squeezed in a vise to
flatten to the desired angle. All other styles require tapered shims.
The Scott is available in two spring widths. The one that is right will
work fine on all springs. I think it is the 1 1\2". All springs will
work with it.
And that is all I have to say about that.
Dave Bangle
Lonnie Benson wrote:
I have a Scott 3200 tail wheel for my Rebel. Should I use the MAM
supplied fiberglass spring or would I be better off using something
else? What are others using with their Scott and Maul tail wheels?
Content-Type: text/html; charset=x-user-defined
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
<body bgcolor="#FFFFFF">
<p>I got the fiberglass spring with my kit.&nbsp; It flew with it and we
found it very "bouncey".&nbsp; The airplane dropped off a ladder while
doing a weight and balance and totally shattered it.
<p>We replace the fiberglss with the older aluminum 6061 tail spring.&nbsp;
It flattened out in a matter of monthes.
<p>We replaced the 6061 spring with the steel two leaf that they offered
for a time.&nbsp; It flattened out over the winter.
<p>We replaced the steel leaf with the new 7075 spring.&nbsp; It has been
on two years now and works with no problems and hasn't flattened one bit.
<p>We are using and have always used the Scott tailwheel.
<p>Keith Kinden made a suggestion at the very beginning that I think is
valid.&nbsp; The wheel must be paralell with the ground to avoid chatter
and wild manuevers.&nbsp; The aluminum spring can just be squeezed in a
vise to flatten to the desired angle.&nbsp; All other styles require tapered
shims.
<p>The Scott is available in two spring widths.&nbsp; The one that is right
will work fine on all springs.&nbsp; I think it is the 1 1\2".&nbsp; All
springs will work with it.
<p>And that is all I have to say about that.
<p>Dave Bangle
<p>Lonnie Benson wrote:
<blockquote TYPE=CITE>&nbsp;<font color="#000000"><font size=-1>I have
a Scott 3200 tail wheel for my Rebel.&nbsp; Should I use the MAM supplied
fiberglass spring or would I be better off using something else?&nbsp;
wheels?</font></font></blockquote>
</body>
</html>
--------------61951C844AD1790927FE8AE9--
Mike Davis
Tall Wheel Spring
Received: from the-benson-s (209-122-252-160.s414.tnt1.lnh.md.dialup.rcn.com
[209.122.252.160])
by smtp1.erols.com (8.8.8/8.8.5) with SMTP id HAA13181
for <murphy-rebel@dcsol.com>; Thu, 14 Jan 1999 07:23:56 -0500 (EST)
Message-ID: <002001be3fb8$aff73a20$a0fc7ad1@the-benson-s>
Date: Thu, 14 Jan 1999 07:23:25 -0500
MIME-Version: 1.0
boundary="----=_NextPart_000_001D_01BE3F8E.C60B7C60"
X-Priority: 3
------=_NextPart_000_001D_01BE3F8E.C60B7C60
charset="x-user-defined"
Content-Transfer-Encoding: quoted-printable
Dave: =20
Thanks for the reply. Murphy is sending me a replacement for my =
fiberglass spring. The fiberglass spring is 1 3/4" wide and just fits =
my Scott 3200. When you said that the wheel must be parallel with the =
runway did you mean vertical? If not, could you explain further. In =
the June 1998 issue of LIGHT PLANE MAINTENANCE there was an article =
titled "Tailwheel Tips" that had some great drawings of the Scott 3200 =
tailwheel and some info on rigging tailwheels.
To: (Murphy Rebel) <murphy-rebel@dcsol.com>
Date: Thursday, January 14, 1999 12:20 AM
=20
=20
Sorry I haven't answered this sooner.=20
I got the fiberglass spring with my kit. It flew with it and we =
found it very "bouncey". The airplane dropped off a ladder while doing =
a weight and balance and totally shattered it.=20
We replace the fiberglss with the older aluminum 6061 tail spring. =
It flattened out in a matter of monthes.=20
We replaced the 6061 spring with the steel two leaf that they =
offered for a time. It flattened out over the winter.=20
We replaced the steel leaf with the new 7075 spring. It has been on =
two years now and works with no problems and hasn't flattened one bit.=20
We are using and have always used the Scott tailwheel.=20
Keith Kinden made a suggestion at the very beginning that I think is =
valid. The wheel must be paralell with the ground to avoid chatter and =
wild manuevers. The aluminum spring can just be squeezed in a vise to =
flatten to the desired angle. All other styles require tapered shims.=20
The Scott is available in two spring widths. The one that is right =
will work fine on all springs. I think it is the 1 1\2". All springs =
will work with it.=20
And that is all I have to say about that.=20
Dave Bangle=20
Lonnie Benson wrote:=20
I have a Scott 3200 tail wheel for my Rebel. Should I use the =
MAM supplied fiberglass spring or would I be better off using something =
<!DOCTYPE HTML PUBLIC "-//W3C//DTD W3 HTML//EN">
<HTML>
<HEAD>
<META content=3Dtext/html;charset=3Dx-user-defined =
http-equiv=3DContent-Type><!doctype html public "-//w3c//dtd html 4.0 =
transitional//en">
<META content=3D'"MSHTML 4.72.3612.1700"' name=3DGENERATOR>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial=20
size=3D2>Dave:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>Thanks for the reply.&nbsp; Murphy is =
sending me a=20
replacement for my fiberglass spring.&nbsp; The fiberglass spring is 1 =
3/4"=20
wide and just fits my Scott 3200.&nbsp; When you said that the wheel =
must be=20
parallel with the runway did you mean vertical?&nbsp; If not, could you =
explain=20
further.&nbsp; In the June 1998 issue of LIGHT PLANE MAINTENANCE&nbsp; =
there was=20
an article titled "Tailwheel Tips" that had some great =
drawings of the=20
Scott 3200 tailwheel and some info on rigging tailwheels.</FONT></DIV>
<BLOCKQUOTE=20
style=3D"BORDER-LEFT: #000000 solid 2px; MARGIN-LEFT: 5px; PADDING-LEFT: =
5px">
<DIV><FONT face=3DArial size=3D2><B>-----Original =
Message-----</B><BR><B>From:=20
</B>subersys <<A=20
href=3D"mailto:subersys@nidlink.com">subersys@nidlink.com</A>><BR><B>T=
o:=20
</B>(Murphy Rebel) <<A=20
href=3D"mailto:murphy-rebel@dcsol.com">murphy-rebel@dcsol.com</A>><BR>=
<B>Date:=20
</B>Thursday, January 14, 1999 12:20 AM<BR><B>Subject: </B>Re: Tall =
Wheel=20
Spring<BR><BR></DIV></FONT>Sorry I haven't answered this sooner.=20
<P>I got the fiberglass spring with my kit.&nbsp; It flew with it =
and we=20
found it very "bouncey".&nbsp; The airplane dropped off a =
ladder=20
while doing a weight and balance and totally shattered it.=20
<P>We replace the fiberglss with the older aluminum 6061 tail =
spring.&nbsp;=20
<P>We replaced the 6061 spring with the steel two leaf that they =
offered for=20
a time.&nbsp; It flattened out over the winter.=20
<P>We replaced the steel leaf with the new 7075 spring.&nbsp; It has =
been on=20
two years now and works with no problems and hasn't flattened one =
bit.=20
<P>We are using and have always used the Scott tailwheel.=20
<P>Keith Kinden made a suggestion at the very beginning that I think =
is=20
valid.&nbsp; The wheel must be paralell with the ground to avoid =
chatter and=20
wild manuevers.&nbsp; The aluminum spring can just be squeezed in a =
vise to=20
flatten to the desired angle.&nbsp; All other styles require tapered =
shims.=20
<P>The Scott is available in two spring widths.&nbsp; The one that =
is right=20
will work fine on all springs.&nbsp; I think it is the 1 =
1\2".&nbsp;=20
All springs will work with it.=20
<P>And that is all I have to say about that.=20
<P>Dave Bangle=20
<P>Lonnie Benson wrote:=20
<BLOCKQUOTE TYPE =3D CITE>&nbsp;<FONT color=3D#000000><FONT =
size=3D-1>I have a=20
Scott 3200 tail wheel for my Rebel.&nbsp; Should I use the MAM =
supplied=20
else?&nbsp;=20
What are others using with their Scott and Maul tail=20
wheels?</FONT></FONT></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_001D_01BE3F8E.C60B7C60--
Mike Davis
Tall Wheel Spring
Post by Mike Davis » Fri Feb 17, 2012 4:53 pm
Received: from nidlink.com (pm9-48.nidlink.com [216.18.141.103])
by enaila.nidlink.com (8.9.0/8.9.0) with ESMTP id PAA14129
for <murphy-rebel@dcsol.com>; Sat, 16 Jan 1999 15:58:15 -0800 (PST)
Message-ID: <36A12944.9C6B7B92@nidlink.com>
Date: Sat, 16 Jan 1999 16:05:24 -0800
MIME-Version: 1.0
References: <002001be3fb8$aff73a20$a0fc7ad1@the-benson-s>
boundary="------------232E5405A60A1195EED9CCC0"
--------------232E5405A60A1195EED9CCC0
Hi Lonny,
Dave: Thanks for the reply. Murphy is sending me a replacement for
my fiberglass spring. The fiberglass spring is 1 3/4" wide and just
fits my Scott 3200. When you said that the wheel must be parallel
with the runway did you mean vertical? If not, could you explain
further.
The top of the tailwheel rotates on a surface. This surface must be
parallel to the runway or the pivot action gets weird. It won't turn
freely in all attitudes if not parallel
<html>
Hi Lonny,
<blockquote TYPE=CITE>&nbsp;<font face="Arial"><font
size=-1>Dave:</font></font>&nbsp;<font face="Arial"><font size=-1>Thanks
for the reply.&nbsp; Murphy is sending me a replacement for my fiberglass
spring.&nbsp; The fiberglass spring is 1 3/4" wide and just fits my Scott
3200.&nbsp; When you said that the wheel must be parallel with the runway
did you mean vertical?&nbsp; If not, could you explain
further.</font></font><font face="Arial"><font size=-1></font></font>
<p><font face="Arial"><font size=-1>The top of the tailwheel rotates on
a surface.&nbsp; This surface must be parallel to the runway or the pivot
action gets weird.&nbsp; It won't turn freely in all attitudes if not
parallel</font></font></blockquote>
</body>
</html>
--------------232E5405A60A1195EED9CCC0--
