3500 Drag Brace
3500 Drag Brace
Post by Wayne G. O'Shea » Fri Feb 17, 2012 10:04 pm
I don't think it is intended to go back in Warren, from the instructions I
have, but I put it back anyway. No sense having rivet holes with nothing
behind them. Easy to reinstall by simply taking a lick off the front face,
where the bolt goes, that is the same thickness as the new steel corner
plates.
Sent: Tuesday, April 09, 2002 9:13 AM
Subject: Re: Corrosion (4130)
SNIP>>
BTW is the drag brace SB still required after doing the 3500 gear box
upgrade?
Warren
Dubai, UAE
SR 029
