Further to yesterdays post, the first IO-540 from Leavens will be available
in about 2 weeks, the rest will be about 2 months lead time from ordering.
For those that are curious they were originally TIO-540-A1A's with updraft
cylinders, and are being overhauled and sold with downdraft cylinders so
your SR won't have the tractor puller look to it!!!!
Leavens has the following O-320 engine available for your Rebel and an
(I)O-360 for someones Elite in the works. If interested contact me off
line! At this point I am presuming the O-360 is set up for a fixed pitch
prop (ie: NO floating counter weights but could be wrong).
I have attached Greg's e-mail to me below!
These are, again, Canadian dollars!
Irish Field Aviation
oifa@irishfield.on.ca
Sent: Thursday, January 24, 2002 7:35 AM
Subject: Re: O-320's
HI.
Have a 150 hp O-320-E ready to go. comes with a lw starter lw alt kit
etc......
I have it listed for $21,500 outright but would take $19,950 through you.
We are building a 360 ...tell me if you you want a carb or bendix fuel
injection..... It has an overhauled case, new sump,4 new rods, new 3 under
crank, first run lr spark plug steel cyl, slick or bendix mags $28,000 with
carb, $32,000 with fuel servo.
We also have a O-235, an O-470 both can be built anyway we want..........
Greg
