re batteries
Graeme & Britta Weck
re batteries
Post by Graeme & Britta Weck » Fri Feb 17, 2012 9:22 pm
Wayne,sorry I ment to add that i am open to any sugestions and not
totally fixed on UB13 so would like to hear more info from you
Regards
Graeme 647R
re batteries
Post by Wayne G. O'Shea » Fri Feb 17, 2012 9:22 pm
Okay Graeme, I will make a trip to the hanger and get right back to you on
the O/DIM's on the PC625, if I can find the box. Wife's out, so I won't get
the "what are you up too" lecture!
Sent: Friday, December 07, 2001 3:06 PM
Subject: re batteries
Regards
Graeme 647R
re batteries
Graeme, here are the specs on the Odyesey PC625.
I think you can also view their entire line at
http://www.absolutebattery.com/odyssey.htm
PC625
Length = 6.70"/170.2mm Width = 3.90"/99.1mm Height = 6.89"/175mm
Weight = 13.23lbs/6.0kg
Max pulse current = 625Amp for 5 seconds
CCA = 265Amp
Cap A 10 hour rate = 17Ah
Reserve Capacity 27 minutes
Approx short circuit amperage = 1000Amps
Retains in excess of 85% state of charge after 6 months storage at 25*C
Can be mounted in ANY orientation other than upside down.
Sent: Friday, December 07, 2001 3:49 PM
Subject: Re: re batteries
get
Regards
Graeme 647R
re batteries
Wayne,great info thanks, I see on the web site the PC625 is used on
kawasaki bikes which are very popular here.As soon as the shops open
this morning I off to see what I can find.
Thanks again will let you know how it turns out
Regards Graeme.
