Hi !
Rebel 603 is ready to take off. After nearly 3,7 years my Rebel is finished.I
bought the kit in Epinal France december 1997 from Brian Godden. It has a
springgear ,Lycoming 0-320 160 hp ,Lasar Ignition System,Airwolf filter system,
Warp 4 blade HP Prop 2 inchs massive aluminium prop-spacer,Insight Gem
610,electr.Turn&bank,electr. Attitude Indicator;VDO Motorinstr.;Icom
receiver,King Transponder,and a Flightcom System (german Ultralight scene).A
german Varta Gel Battery 12V 40Ah weight 30 lbs is movable mounted in the
tailcone also ELT fix.My empty weight is 1017lbs CofG 13,3 Inches battery in
most backward position.After modification of the brakes Rebel R 603 taxis very
nice (the Fixed plate BRK-6 touched the 7/8" Extrusion BRK 13). In order to get
the allowance to fly the german LBA (Luftfahrt Bundesamt equivalent of the US
NTSB? )wants a Loading test of my rebel to check out my assembling quality
,skill,kit qualities ?? :-( :-( By the way it will be one of the first flying
german rebels.
Test conditions: see drawning
1.I have to lift (hang up or support ) R 603 in the region of the left and right
upper wing strut end
2.I have to tie down the engine block
3.I have to load the tail feathers left and right 265lbs (120 kg) each side
totaly 530 lbs
4.I have to load the feahters different 265 lbs one side 176 lbs other side
5.I have to measure and record a test protocoll
to 1. : I intend to cut a wood plate (plywood) 1/2 " thick 4 feet x 5 feet from
rib 5 to rib 8 strenghten it with wood blocks 3" x 4" sandwich it with plywood
plate
to 2. : to tie down the engine block i want to put a leather sand bag over the
midle of the engine crankcase put a metall plate and a 4 " x 5 " wood block
cross over the sandbag ,fixing the woodblock by nylon ropes and concrete dowels
in the floor
to 3. :to load the tail feathers i want to cut plywood plates over the feathers
and put the load as near as possible to the fin
Load analysis: rear arm: 162 inches rear load 530 lbs 85550 inch-lbs
front arm: 52 " front " 1645 lbs?
support each side: 1017+1645+530 /2 = 3212/2 = 1606 lbs
nylon rope each side 1645 /2 = 823 Lbs
Any comments , corrections ,hints are welcome
Johannes Laubenthal R 603 Germany D-EOPZ registration number
