by dcsol.com (wcSMTP v5.4.449.4)
with SMTP id 68675328; Fri, 20 Apr 2001 20:41:29 -0800
Received: (qmail 9448 invoked from network); 21 Apr 2001 04:41:05 -0000
Received: from unknown (HELO ip174.toronto78.dialup.canada.psi.net) (154.20.72.174)
by bretweir.total.net with SMTP; 21 Apr 2001 04:41:05 -0000
Mime-Version: 1.0
Content-Type: text/plain; charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Subject: Re: Cabin roof & skylights
Hi Wray !
The skylight info has changed a bit over the years. The doublers
are now available from MAM, and are pretty pieces with a joggle all
around. This is a MUCH better way to fasten than the old "rivet through
the Lexan" - the Lexan panels are glued in with a flexible adhesive
(Bostick 1100 ??), and the doublers are rivetted in place.
1/8" Lexan should do the trick - there is no problem with
Lexan in flat sheets, it only crazes if bent. Lexan is stronger than
Plexi, and MUCH easier to work, cut & fit. Laird Plastics have it
in various tints ... (You <could> use 1/16" .... )
I would not install the skylights directly behind the seats -
they just sunburn your neck. The front ovals (through the windshield),
the top set, and the rearmost set, are all useful.
-----------------------------------orig.------------------------------------
At 10:01 AM 4/13/01 -0700, you wrote:
gives the*-------------------------------------------------------------------------*
Ken the blurb I have on skylights doesn't actually give the dimensions. It
actual holelocation of the doublers=A0 ...is this a kit from Murphy? Do you know the
just flat?locations and size? Is there anything special about the doublers? Are they
thicknessone piece? inside and out? What thickness should they be. And what=
*-------------------------------------------------------------------------*plexiglass or ?
Perhaps this has all been discussed and is in the archives?
klehman@albedo.net wrote:
*-------------------------------------------------------------------------*=A0 The list archives are located at:
=A0 http://www.dcsol.com:81/public/default.htm
=A0 username: rebel=A0=A0=A0=A0 password: builder
like to putWray
Yes cut the skylights before rivetting and note the aft ones are NOT
symmetrical due to the aileron linkage.
I put all 8 in but I am going to blank the two that are in the third row
back from the front. Now that I've positioned the seats I realize that
they will just annoy me with the sun coming through them and won't
really add much visibility.
wrayt wrote:Thanks Drew=A0 I'll trim them today. Just had another thought I would
place.in some skylights and had planned on doing it after the roof was in=
skylights forPerhaps it's easier before hand?. Also those that have been using
TNX!a while what are your thoughts now on how many and in what locations?=
*-------------------------------------------------------------------------*=...Wray
list-server@dcsol.com=A0 You have received this message because you have subscribed to the
=A0 murphy-rebel mailing list.
=A0 To unsubscribe from this list, send an e-mail to:=
*-------------------------------------------------------------------------*=A0 with "unsubscribe murphy-rebel" in the body of the message.
=A0 For assistance contact mike.davis@dcsol.com
Wray Thompson ...Rebel 306 ...home page http://wrayt.tripod.com/
My ICQ number is 29764664
=A0
