Your following message has been delivered to the 162 members of
the list murphy-rebel@dcsol.com at 17:03:08 on 7 Nov 2000.
Walter, it is the drilled axles and filling the entire wheel assembly with
grease, that makes the difference. If the wheel is not full of grease, it
will be full of water. If full of water, it works like a centrifuge and
washes the grease off of the bearings so they run bare, steel on steel! If
you keep the wheel right full of grease, the water can not get in! Howard's
were Chrome Plated right from the start (as supplied from MAM in the
Cleveland wheels) and the first set only lasted 3 months (about 6 landings
and take offs on land). Maybe the steel ones <would> hold up if the wheel
was full of grease, but I'm not going to take the chance. FWIW your
pre-built floats should come with Chrome plated bearings in the wheels
anyway (if MAM is still buying and supplying this wheel model). You will
know for sure when you pull the axles out, to drill them for grease nipples!
I don't know why MAM doesn't do this with the supplied axles. It only takes
about 20 minutes to drill the tee shaped grease channels and tap the pair
for grease nipples!
To: "(Murphy Rebel)" <murphy-rebel@dcsol.com>
Sent: Tuesday, November 07, 2000 9:00 AM
Subject: [Fwd: Re: Amphib Wheel Bearings]
plainLooks like my email had been dropped from the list server and I wasn't
getting any messages for a few days. I "joined" again, and am resending
this previous post, as I don't believe it got through.
It's a question for Wayne O., if you could just read below.
-------- Original Message --------
Subject: Re: Amphib Wheel Bearings
Date: Sun, 05 Nov 2000 10:34:46 -0800
Organization: @Home Network
Walter.Klatt@home.com is not allowed to post to the list.
Please contact mike.davis@dcsol.com if you have any problems.
Wayne, would you attribute the bearings lasting 3 years more to the use
of the chrome
plated upgrade or to the drilled axles? Has there been any experience
with drilled axles
using regular steel bearings?
"Wayne G. O'Shea" wrote:
Bob (and All),
Lots of places (including my local guy) stock the 08125 bearings in
anysteel, but since Howard's Chrome plated ones have lasted 3 years without
don'tproblem (since I drilled his axles to fill the wheels with grease), I
vswant to try plain steel ones like the disintigrated ones I removed from
FOKM. I would rather spend the extra $340 on bearings ($100.00/bearing
ifabout $15.00 for steel) than the labour TWICE per summer to change them
lookusing plain steel! Stainless may even be better if available, I should
*---------------------------------------------------------------------------into that and see if they are available (and at what cost)!
