[rebel-builders] Engine Location
Ted Waltman
What do you mean, Rick--engine location--as in offset (?) for straight
flight (i.e. smaller/no rudder trim tab needed in cruise)?
I don't recall ever seeing any document from Murphy re engine stuff.
Ted
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Rick
Muller
Sent: Sunday, October 30, 2011 2:10 PM
Subject: [rebel-builders] Engine Location
I recall that Murphy published a document that identifies the engine
location for the Moose/SR2500. I looked through the files section without
luck. Does anyone have this document?
Rick Muller
Rick.H.Muller@gmail.com
303 641 6623
Ted
Muller
Rick Muller
303 641 6623
karl hipp
I saw the name on the string--_engine location_--and I knew the answer
right away
"on the front"
Karl Hipp
right away
"on the front"
Karl Hipp
Ted
Muller
Rick Muller
303 641 6623
Jerald Folkerts
Rick,
Do you mean for weight and balance purposes?
SR #093
www.mykitlog.com/jfolkerts/
Muller
Sent: Sunday, October 30, 2011 3:10 PM
Rick Muller
303 641 6623
SR #093
Muller
Rick Muller
303 641 6623
gleeso1
On 31/10/2011 10:38 AM, karl hipp wrote:
here?<Grin>
Rebel804 downunder
Hey Karl, are sure you are not an Aussie, or did you just visit downI saw the name on the string--_engine location_--and I knew the answer
right away
"on the front"
Karl Hipp
here?<Grin>
Rebel804 downunder
karl hipp
I have been to OZ to visit with US pilot friends in the International
Comanche Society. --We had a convention on Hamilton Island a few years
ago with our Aussie members. --and yeah-- a silly/crazy streak seemed a
common trait among the blokes I met --not a mug or bludger in the
bunch--and the Sheila and I have a few cobbers as a result of the trip.
Karl Hipp
Karl Hipp
On 31/10/2011 10:38 AM, karl hipp wrote:Hey Karl, are sure you are not an Aussie, or did you just visit downI saw the name on the string--_engine location_--and I knew the answer
right away
"on the front"
Karl Hipp
here?<Grin>
Rebel804 downunder
gleeso1
On 31/10/2011 8:48 PM, karl hipp wrote:
Regards
John.
(while they are laughing at me, think of all the others they are leaving
alone) :-)
I can think of worse places than Hamilton IslandI have been to OZ to visit with US pilot friends in the International
Karl Hipp
Goodonya Mate, you'll do me, never mind these intelligent people. ;-)
Regards
John.
alone) :-)
On 10/31/2011 2:34 AM, gleeso1 wrote:On 31/10/2011 10:38 AM, karl hipp wrote:Hey Karl, are sure you are not an Aussie, or did you just visit downI saw the name on the string--_engine location_--and I knew the answer
right away
"on the front"
Karl Hipp
here?<Grin>
Rebel804 downunder
Rick Muller
It was a document that identified the location of the line of thrust
relative to the engine mounting holes along with where prop was relative to
the firewall. While I have everone's ear. I think it was intention was
for a Continental or Lycoming engine. So if you are using a different
engine there is the obvious CG of the engine that impacts weight and
balance. If the plain of the prop moves forward or aft 5" what is the
impact on performance?
Rick Muller
SR70
On Sun, Oct 30, 2011 at 2:18 PM, Ted Waltman <ted@vafm.org> wrote:
Rick Muller
303 641 6623
Rick Muller
SR70
--What do you mean, Rick--engine location--as in offset (?) for straight
Ted
Muller
Rick Muller
303 641 6623
Rick Muller
303 641 6623
Tom Packard
I remember the one page drawing and will go thru my files and post it if I can locate it.
Tom Packard
SR 043
________________________________
Sent: Monday, October 31, 2011 8:59 AM
Subject: Re: [rebel-builders] Engine Location
the firewall.
Tom Packard
SR 043
the firewall.
Tim Saxton
Rick,
I believe there is no engine offset for the SR/Moose using the MAM engine mount. It might be different for the Rebel, or maybe I'm thinking of the vertical stabilizer offset for the Rebel. But for the SR I believe there is zero offset for both. I'm using an IO-540 with the MAM engine mount so I have a near stock setup insofar as the MAM C of G diagram.
Tim
To: Tim Saxton
Sent: Monday, October 31, 2011 7:05 AM
Tim,
Thanks, this is the diagram I was looking for, appreciate you finding it and sending it along. I recall that there was also some discussion around this about a 1.5 degree off-set. If memory serves me well the line of thrust was to be 1.5 degrees right (?) of the center line of the airframe. Does anyone recall or is this my imagination?
Tim
To: Tim Saxton
Tim,
