[rebel-builders] clear fuel line
Post by Bob Patterson » Sun Feb 19, 2012 8:55 pm
Hi Jason !
The blue stuff IS translucent, and will work ... but it eventually
discolours too ... Should be good for a year or 2 though...
You haven't been running car gas have you ??? That's a no-no
for at least a few hundred hours ... and bad gas can discolour
tubing within a few DAYS !!!
I've tried Tygon, and several others - Canadian Tire stuff for
windshield wipers worked !! Just the luck of the draw - keep trying !!
THAT'S why I recommend installing a small shut-off valve at the
bottom of the sight guages - makes it a LOT easier to change
the tubing .... no need to run a tank dry !! ;-)
Glad to hear you are progressing so well - keep going ....
it's a looonnnnngggg winter !! ;-( Your insurance will drop
a whole bunch once you pass 100 hours solo !!! :-)
Maybe you need a trip to Sun 'n Fun in March !!! ;-)
bobp@prosumers.ca
bobp@pattersys.com
http://www.Pattersys.com
responsibility of the reader.
On Tuesday 27 September 2011 14:07:07 Rebecca Brownell wrote:
hello .could i trouble a few to let me know what they have used for clear
fuel sight tubes.whatever i have used so far has hardened over just a
couple months and started to seep at the fittings.has anyone used that
bing fuel line from aircraft spruce?it says its blue in color,doesn't say
if it is translucent.any words of wisdon greatly appreciated as always.
thanks so much
jason
817R
27hrs on the plane now!finished float rating yesterday!sweet
Rebecca Brownell
Post by Rebecca Brownell » Sun Feb 19, 2012 8:55 pm
thanks bob,no 100ll only.its not that it discolors,it starts to harden and
then leak at the compression fitting.i'll try the bing tubing
thanks
jason
On Tue, Sep 27, 2011 at 6:35 PM, Bob Patterson <bobp@prosumers.ca> wrote:
Hi Jason !
bobp@prosumers.ca
bobp@pattersys.com
http://www.Pattersys.com<http://www.pattersys.com/>
thanks so much
jason
817R
rhuzzey
Post by rhuzzey » Sun Feb 19, 2012 8:55 pm
I thought the polyurethane tube from aircraft spruce part no. 0585-071 would work.
That was what I was planning to use, correct me if I am wrong. I have not installed it yet.
Sent from my iPad
On 2011-09-27, at 4:35 PM, Bob Patterson <bobp@prosumers.ca> wrote:
Hi Jason !
bobp@prosumers.ca
bobp@pattersys.com
Post by Ken » Sun Feb 19, 2012 8:55 pm
Clear teflon tubing is still clear in year 6 with mogas. I believe I put
details in the archives. Inserts are needed if using brass compression
fittings with it although nylon fittings also work.
Congratulations on the float rating. That was pretty quick.
fuel sight tubes.whatever i have used so far has hardened over just a couple
months and started to seep at the fittings.has anyone used that bing fuel
line from aircraft spruce?it says its blue in color,doesn't say if it is
thanks so much
jason
817R
Bruce Whitaker
Post by Bruce Whitaker » Sun Feb 19, 2012 8:55 pm
Tygon tube.
Post by Wayne G. O'Shea » Sun Feb 19, 2012 8:55 pm
My experience with it is you will find stuff that works for 100LL and you'll
find stuff that works for auto fuel. You will not find anything that works
for both.
Sent: Tuesday, September 27, 2011 6:35 PM
Subject: Re: [rebel-builders] clear fuel line
Hi Jason !
bobp@prosumers.ca
bobp@pattersys.com
persons.
thanks so much
jason
817R
Sending again as I replied when server was down...
for both.
Hi Jason !
bobp@prosumers.ca
bobp@pattersys.com
persons.
drewjan
Post by drewjan » Sun Feb 19, 2012 8:55 pm
The stuff I'm using now is from the local Huskquvarna chainsaw dealer. It's held up very well for at least a couple years.
------Original Message------
Sender: mike.davis@dcsol.com
ReplyTo: rebel-builders@dcsol.com
Subject: [rebel-builders] clear fuel line
Sent: Sep 27, 2011 2:07 PM
thanks so much
jason
817R
Dan Pare
Post by Dan Pare » Sun Feb 19, 2012 8:55 pm
YOU CAN BY FROM BOMBARDIER DEALERSHIP CLEAR MARINE FUEL LINE LAST FOR EVER
Date: Thu, 29 Sep 2011 18:28:10 +0000
thanks so much
jason
817R
Try soaking a piece in a jar of 100LL for a bit and see what it does...
Sent: Friday, September 30, 2011 6:35 AM
Subject: RE: [rebel-builders] clear fuel line
couple
thanks so much
jason
817R
